Old 06-12-2013, 02:53 PM   #4411
KMC1
Oddometer: 2,562
Yo,
What air pressure are you guys running for loose, rocky dry conditions?
Standard DOT knobbies, heavy duty tubes.
I'm a heavy guy....so I tend to run higher pressures to protect the wheels and prevent pinch flats......but I'm bouncing off everything and spinning everywhere.
Curious what you guys are running. I think I'm going to try a set of D606's
KMC1 is offline   Reply With Quote
Old 06-12-2013, 03:40 PM   #4412
Ericm900
Oddometer: 1
Long overdue ... thank you!
First post hope I get it right! I've been lurking for the past 2 years!! A huge thank is long overdue to all who contribute to this thread! The information, knowledge and enthusiasm is amazing and has made it so easy for me to get a truly well sorted light weight adventure bike that also does enduro. Much appreciated!
I bought my 2011 530 EXC new in Australia so no desmog was needed the key mods are:
- 14/50 sprockets (once they wear out I'll get the Dirttricks Ironman ones)
- Dirttricks cam chain tensioner
- Trail Tech stator
- auxiliary fan kit and water pump impeller upgrade
- 15L Safari tank
- upgraded rear spring
- Sicass rear flush mount indicators
- Scott's damper
- Corbin seat
- Akrapovic pipe (it was a promo item when I bought the bike so no cost)
- PMB rack
- Doubletake Mirrors (on order)
http://
Ericm900 is offline   Reply With Quote
Old 06-12-2013, 03:44 PM   #4413
Bungholio
Bungholio's Avatar
Oddometer: 659
I tend to run 12 - 15 front and rear for anything, mud, rocks, dry, wet. What is heavy? More than the bike? Im about 180, 200-210 with gear. Never had a flat.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 06-12-2013, 03:52 PM   #4414
KMC1
Oddometer: 2,562
Lol...yeah man...I'm at least 50lbs heavier than the bike!
But from my mountain biking experience I am "light on my wheels"....
That's really low pressure! Wow....I'm closer to 32psi front and 34psi rear...... No wonder I'm bouncing off everything!
Old 06-12-2013, 05:30 PM   #4415
Bungholio
Bungholio's Avatar
Oddometer: 659
Try 20 or so, not more than 24. I ran 18 in my dr650 and its about 100lbs heavier than the ktm. Seemed to work good for it.
Old 06-12-2013, 07:05 PM   #4416
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,860
Originally Posted by KMC1 View Post
Yo,
12-15 here too... until recently. I'm now running bib-mousses.
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 06-12-2013, 09:01 PM   #4417
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,949
I saw a pic of one your mousses. Was that spot caused by heat? I can't imagine you wasting any time slabbing when it looks like you have some stellar riding seemingly in your backyard.
My work schedule has changed for the worst this summer, so the only rinding I'm going to be doing this summer is 130+km/h. Poor bike. I have a rigorous winter ice racing schedule planned for it as well. All WOT.
Got the other bikes out for some WFOT as well. My purdy lil' wife lacks the confidence on such a scary machine.
The orange one is reserved for me.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 06-12-2013, 09:06 PM   #4418
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,860
The one spot on the mousse was more likely caused by a pinch. I ride a little slab, but not much, and not at high speeds or temps that would cause a problem; at least not to date. If I'd had an old mousse, I would have cut that section out and piece a good segment in. So far so good, though! I really like how they feel in rough rocky stuff; you can just charge stuff without worry, and without deflection. Of course, that's probably how I got the pinch tear.
Old 06-12-2013, 09:11 PM   #4419
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 43,860
I love the bikes, BTW!
Old 06-12-2013, 09:27 PM   #4420
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,949
Speed and fear are relative to equipment. These things only do 25 mph, but with square profiled tires and bolted together sheet metal frames, trust me, when ridden to the max (like only an idiot would do), they can be quite exciting. The head tube is the only welded component. My own Solex is the parts bike for these two that belong to a good friend, but I have a '69 PC50, and it's fun, but waaay too refined. It has suspension and brakes, and is a bit faster than the frenchies.
Old 06-13-2013, 07:35 AM   #4421
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,850
32/34psi............
I tried a little over 20 ft and rear in my DR650 once due to rocks and weight of bike. I had to stop and let some air out,there's no way to steer a bike in dirt/rocks with high air pressure.
Just a few lbs makes a difference,around 17 was ridable.
I run 5 psi with the Tubliss rear trials tire on my 200XCW for local singletrack,it will climb anything I point it at with near 0 wheelspin and goes through rocks straight as can be.
It routinely goes by other guys with knobby tires who havent tried the Trials tire yet. But,Knobs are great for some stuff,Trials tire great for others.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 06-13-2013, 07:36 AM   #4422
Foot dragger
singletracker
Oddometer: 12,850
Sweet Ass Moped and nice riding gear!
Old 06-13-2013, 12:57 PM   #4423
Greg555
Oddometer: 32
Lights are on eBay as requested
Got 4 left from my first order
http://www.ebay.com/itm/330939601165...witem=&vxp=mtr
Greg
Greg555 screwed with this post 06-13-2013 at 01:02 PM
Greg555 is offline   Reply With Quote
Old 06-15-2013, 07:38 PM   #4424
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 400
Oh my God. I run 14 front, 12 to 14 rear with knobbies. One rim lock front, two on the rear. Never had a pinch flat that way. Now I'm running my first MT 43 rear. With it I'm running a extra heavy tube, and 8 psi on road and off. Crazy traction.
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 06-15-2013, 08:06 PM   #4425
Bungholio
Bungholio's Avatar
Oddometer: 659
Cry New Motoz Tyres
Just finished installing a set of Motoz Tractionator tyres on my 530. what a pain. I got their HD tubes as well and boy was it a job. At least they weren't the UHD tubes, only the 3mm thick ones. If I have a flat with these things I'm not sure I could tell. Only put in 1 rim lock-I have been using 2 in each tire-because I just couldn't get the other one in. I think with it flat it will feel like about 6lbs of air, so if I ever have a problem on the trail then I can just ride out on it and not worry about fixing. Had to inflate and deflate about 6 times for each tyre to get the bead to fully seat. They look to be pretty decent tyres and they have great reviews so far. Gotta try em on trails soon.
Times are GMT -7.   It's 06:31 AM.
