Old 07-03-2013, 08:56 AM   #4501
Navin
Navin's Avatar
Oddometer: 8,162
Originally Posted by jesusgatos View Post
Clearance looks fine. Those flaps all get chewed-up on these bikes. Run it.
X 100, run it and don't worry. Enjoy the shorter wheelbase while you can!
Navin is offline   Reply With Quote
Old 07-03-2013, 10:06 AM   #4502
trailjammer
trailjammer's Avatar
Oddometer: 369
Originally Posted by Rickfenn1 View Post
Question.
Slowly rolling on throttle from idle to just off idle is really like an on off switch. When cruising at low speeds it's difficult to do slow maneuvering, it acts like the carb is too big for the bike. It's jerky and I can't put the power back on easily. Seems as if clutch in then back out is the only way to be smooth with it.
I've already have a JD jet kit and decent gearing 15/48. I set my chain adjustment correctly. Throttle cables are adjusted correctly.
Is this an adjustment issue in the carb or am I doing something wrong?
Say if I was ever looking to find the balance point on this bike in a wheelie....I'd be on my a** real fast trying to roll on and off idle lightly.
My throttle tube just started doing the same damn thing. Sucks! if you're riding down the road w/one hand on the throttle it can give you whiplash from on/off right in the first like 1/16th of throw. It didn't use to do that. I have about 8k miles on it. I thought maybe my throttle cables were getting messed up since it started after i went down in a deep silt bed in baja. I may have to look at thos G2 throttle tubes, too. d'oh.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 07-03-2013, 01:56 PM   #4503
Rickfenn1
Voltron
Oddometer: 26
Just picked up a G2 off of supermotojunkie classifieds. It is coming with the quicker response cam on it but you can just pull off then swap cams with a slower response one for $25. I'll let you know the changes.
Rickfenn1 is offline   Reply With Quote
Old 07-03-2013, 03:35 PM   #4504
fast4ward
Oddometer: 86
I bought the G2 cam system new off CL but have not installed it yet. It came with the 100, 200 and 400 cams. What is yours coming with ? Interested in a swap with one of my cams if it is the 50 ?
fast4ward is offline   Reply With Quote
Old 07-03-2013, 04:55 PM   #4505
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,865
I'm wondering if wear from a lot of hours might be causing a little misalignment that makes the stock throttle pulley (cam, whatever) bind in the housing. I had an "incident" when my throttle stuck shut. Not frozen, but sticky on closed throttle. It causes you to grab a handful when it breaks loose. I had just put a new TT X2 light on the bike, and grabbed an inadvertent handful coming up out of a gully. Took out a small tree, breaking my new headlight mask 1 hour after mounting it. A small squirt of lubricant into the throttle housing cured it temporarily.
Like you guys, I went ahead and installed the G2 tube with the 400 cam. That, along with the Rekluse, and the map switch set to "off", made her a real pussycat in the woods. Warp speed still a twist away, though.
Do you guys think maybe your throttle is a little "sticky" when fully closed?
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 07-03-2013, 09:57 PM   #4506
Joe
Debaser
Joe's Avatar
Oddometer: 1,747
Thanks. The flap looks pretty rough now after a few rides but no marks on the swing arm. I am going to leave as is until the chain is toast and then may go with a couple of extra links.
Joe is offline   Reply With Quote
Old 07-04-2013, 04:11 PM   #4507
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
so my mechanic has informed me that my 08 450 xcrw crank went bad and so far I need new crank and piston kit. hopefully the cylinder is good to go so I don't have to replate it. We haven't went into the bottom yet because I got to buy a flywheel puller since he didnt have the right size. any ideas of what else could be costing me? what may be waiting in the bottom end? the piston and cylinder are scorched by he said he is going to clean the cylinder and mic it and be sure it's good. while the cases are split I'm considering getting the aluminum oil gears, I replaced the stock with the updated ones and they even felt loose. I replaced all seals except one, the one near the front behind some gears near the oil jetting so I'm going to get that done too. just wanting to know what may await in the bottom end due to the crank.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 07-05-2013, 10:57 AM   #4508
xathor
Not actually Gnarly
Oddometer: 448
Does anyone have the torque specs for the head bolts and rocker arm bolts? Or better yet... A PDF service manual?
2014 KTM 690 Enduro R (21/18 & 17/17's)
2008 Subaru STi (e85 powered beast, ~500hp)
1998 Land Rover Discovery (daily driver)
Past: 800xc, WR250R, 450EXC-R, KLR
xathor is offline   Reply With Quote
Old 07-05-2013, 12:15 PM   #4509
fast4ward
Oddometer: 86
PM sent.
Old 07-06-2013, 11:50 AM   #4510
resqd1
Oddometer: 236
There was a guy on here that had a 530 with an aftermarket windscreen on it, I think his name was bond or something, anyone have any pictures of his bike? I am going to be laying down some road miles and thought a little wind protection would be nice. thanks
resqd1 is offline   Reply With Quote
Old 07-06-2013, 12:58 PM   #4511
Bungholio
Bungholio's Avatar
Oddometer: 738
Buy a Goldwing . :)
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is online now   Reply With Quote
Old 07-06-2013, 01:08 PM   #4512
resqd1
Oddometer: 236
Originally Posted by Bungholio View Post
Buy a Goldwing . :)
Stupid
Road miles are in between the trails, and from what I remember right, it was two bolts and his came off real easy, just clamped to the bars, then stick it behind you for the trails :)
Bungholio thanks for your great insight and help
Old 07-06-2013, 02:56 PM   #4513
Bungholio
Bungholio's Avatar
Oddometer: 738
Stupid
I couldn't resist.
Old 07-06-2013, 03:35 PM   #4514
resqd1
Oddometer: 236
I couldn't resist.
Figured as much, no offense taken, maybe others will read it now and get me some info :)
Old 07-06-2013, 04:10 PM   #4515
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Im glad you mentioned this,Ive been trying to figure out a backrest for the old lady on mine,and how do most guys hook up a trailer on these bikes?
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 02:03 PM.
