Old 07-11-2013, 04:11 AM   #4531
windyhill
Oddometer: 64
The stock CCT failed this past weekend, 219 hours and around 7k on the bike. Never had any problems with it, but it was very obvious from the sound of the engine that something was very wrong. I removed it, and found it completely collapsed, with no oil in it. The DJH ones are not available, so I've temporarily replaced it with another stock one.
Gonna change the oil and fire her up today, hopefully all else is ok.
windyhill is offline   Reply With Quote
Old 07-11-2013, 05:26 AM   #4532
jar944
jar944's Avatar
Oddometer: 698
Originally Posted by antpatterson View Post
so my mechanic has informed me that my 08 450 xcrw crank went bad and so far I need new crank and piston kit. hopefully the cylinder is good to go so I don't have to replate it. We haven't went into the bottom yet because I got to buy a flywheel puller since he didnt have the right size. any ideas of what else could be costing me? what may be waiting in the bottom end? the piston and cylinder are scorched by he said he is going to clean the cylinder and mic it and be sure it's good. while the cases are split I'm considering getting the aluminum oil gears, I replaced the stock with the updated ones and they even felt loose. I replaced all seals except one, the one near the front behind some gears near the oil jetting so I'm going to get that done too. just wanting to know what may await in the bottom end due to the crank.
So how was he able to tell you the "crank" went bad with it still in the engine?
03.6428 <---- ProX Rod kit part #
jar944 is offline   Reply With Quote
Old 07-16-2013, 12:39 PM   #4533
Krazyjohnny
Oddometer: 449
Valve check time again?
Under hard, higher RPM accelleration my 08' has a little hiccup. I am not high up enough to be bouncing off of the rev limiter, but think it is time to check the valves again? Any input?
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 07-16-2013, 01:55 PM   #4534
xathor
Not actually Gnarly
Oddometer: 445
You could do that but I would also check the spark plug.
Im about to go pick up all my parts that I ordered weeks ago and I should have everything to get this bike out of my living room!
2014 KTM 690 Enduro R (21/18 & 17/17's)
2008 Subaru STi (e85 powered beast, ~500hp)
1998 Land Rover Discovery (daily driver)
Past: 800xc, WR250R, 450EXC-R, KLR
xathor is offline   Reply With Quote
Old 07-16-2013, 02:22 PM   #4535
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Originally Posted by matloik View Post
Good. Your manhood remains intact.
I just don't get some of the 'conversions' some make to bikes to purpose them for something they are not built for. If someone really thinks they need a touring screen, maybe this bike isn't the bike for them. I would not want this bike if I wanted/needed to do any paved distance, e.g.
People DO have different ideas about these bikes,some never touch dirt.
They put a set of 17" wheels on and blast around the street.
As a longtime dirt thrasher I could think of a lot better streetbikes or even supermoto but to each their own.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-16-2013, 03:35 PM   #4536
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,966
I generally question what I view as wrongfully purposed bikes, or people that just love putting a pile of switches and crap all over their bikes (HDB top clamps for example), but to each their own.
I have only had my supermoto wheels on my bike for a total of a week or so, but I have to say, compared to all of the other bikes I have every had, the 530 with slicks is the best urban destroyer I have ever ridden. Makes me want to live in a large urban centre, just so I can justify owning that set of wheels.
From the aforementioned week, earlier in the spring.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 07-16-2013, 03:41 PM   #4537
Foot dragger
singletracker
Oddometer: 12,854
I try to keep my bikes kinda minimal,I dont even like putting a GPS on the handlebars unless I have to.
I dont want things distracting me or getting caught on brush or breaking off in crashes. No sharp objects pointing towards me on the front of the bike.
No rows of switches and blinking lights.
I also got one of those Clockworks tanks off an inmate,I like the thing,its a handy size and is narrow.
Fits my 09 200XCW also which is where it is now.
How far did you fly after impacting that snowbank?
Old 07-22-2013, 06:21 PM   #4538
dirtdiver
Oddometer: 2,039
I had a crank shaft go bad on my 530. $800 for the part alone.
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 07-22-2013, 06:46 PM   #4539
piercalif
Biciveloce
piercalif's Avatar
Oddometer: 411
By the time you done with the rebuilt is going to be around $2000
Piero
Carlsbad
piercalif is offline   Reply With Quote
Old 07-23-2013, 05:19 AM   #4540
mbrick
Oddometer: 140
Depends what is "wrong" with the crank. Needs a rod, few hundred bucks. Not actually the crank and only a main bearing, cheap.
Disintegrated with shrapnel everywhere, then maybe $2k.
mbrick screwed with this post 07-23-2013 at 05:43 AM
mbrick is offline   Reply With Quote
Old 07-24-2013, 06:42 PM   #4541
resqd1
Oddometer: 236
Quick picture request, I had a flat, then put my front wheel back on, now I am looking at the space between then hub and fork on the non brake side of the wheel and I can see part of the axle and it doesnt look right, I am hoping it is right and I am just losing it, can someone take a close up pic of theres and then I can compare it, thanks :)
resqd1 is offline   Reply With Quote
Old 07-24-2013, 06:57 PM   #4542
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,859
Quick phone pics...
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 07-24-2013, 07:00 PM   #4543
resqd1
Oddometer: 236
Thanks Michhub, I didnt screw anything up, looks the same, the space between the fork and the umm washer ribbed piece looked wierd like they should mate up like the other side.
Old 07-24-2013, 07:20 PM   #4544
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,966
The right side of the axle is a larger diameter and tightens up against the spacer in the wheel, and the large axle bolt on the left pulls everything together. After snugging the bolt (you may have to temporarily snug one of the pinch bolts to do this), loosen the pinch bolts and bounce the bike with front brake and pushing on the suspension. Everything with settle where it needs to be, then you can finish tightening everything. The gap is normal.
Old 07-24-2013, 07:25 PM   #4545
resqd1
Oddometer: 236
Thanks, yeah I looked at everything and it looked right, but it was weird to me, do you guys locktight the pinch bolts? The factory doesnt say anything about locktite so I wasnt sure, in my head I think you should
Times are GMT -7.   It's 12:20 AM.
