Old 07-24-2013, 08:03 PM   #4546
Honkey Cat
Tailights Fade!
Oddometer: 1,114
Originally Posted by resqd1 View Post
Thanks, yeah I looked at everything and it looked right, but it was weird to me, do you guys locktight the pinch bolts? The factory doesnt say anything about locktite so I wasnt sure, in my head I think you should
Yiu do not need to use loctite on pinch bolts but make sure you adj the axel correctly
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 07-25-2013, 09:41 AM   #4547
resqd1
Oddometer: 236
Anyone running a fender brace on there 530? Guys talk about having two tubes and tools etc in a front fender bag, I put some tools in the bag and went for a ride on the street and the fender was all over the place, I plan on taking out some tools and puting a tube in there, but worry about desert riding and breaking the fender. It looks like at one point ktm used to make a brace, but doesnt anymore, any diy things out there? AM I just dumb and the fender will be fine?
resqd1 is offline   Reply With Quote
Old 07-25-2013, 09:56 AM   #4548
trailjammer
trailjammer's Avatar
Oddometer: 370
The 530 front fender is pretty weak. Especially if you are running an aftermarket brand like Cycra. OEM is a little stiffer but you're lucky if you can carry a tube and levers. Mine rubbed all over the tire on every little bump. The best bet is to run the supermoto front fender since it's a little shorter and a lot stiffer.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 07-25-2013, 11:58 AM   #4549
StuInFH
Oddometer: 426
I realize you already have a fender bag, but I went with the Wolfman bag that straps right under the light crossways, rather than those that are parallel to the fender because I see those flapping up and down a lot. I'm thinking it exerts a lot less leverage cuz I have no problem with OEM fender and stuff in the bag. Downside is that it slightly marred the lower area of the plastic lens from a bit of rubbing when I had it really stuffed. And the straps loop behind the forktubes, so it isn't coming off.
StuInFH is offline   Reply With Quote
Old 07-25-2013, 12:21 PM   #4550
resqd1
Oddometer: 236
Stock fender, yeah already have the moose dual sport bag
Old 07-25-2013, 02:34 PM   #4551
xathor
Not actually Gnarly
Oddometer: 448
Finished rebuilding mine in my living room and she runs like a raped ape!
I did the stator and clutch covers with many light layers of bedliner spray.
And finally... the reason for the rebuild!
2014 KTM 690 Enduro R (21/18 & 17/17's)
2008 Subaru STi (e85 powered beast, ~500hp)
1998 Land Rover Discovery (daily driver)
Past: 800xc, WR250R, 450EXC-R, KLR
xathor is offline   Reply With Quote
Old 07-25-2013, 02:56 PM   #4552
fast4ward
Oddometer: 86
Cool Xathor - what did you end up replacing in the engine ?
fast4ward is offline   Reply With Quote
Old 07-25-2013, 03:43 PM   #4553
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,974
Not the cam. That is still the '08 cam.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 07-25-2013, 06:51 PM   #4554
xathor
Not actually Gnarly
Oddometer: 448
I ended up replacing the intake and exhaust valve seals, replaced the piston with a Wossner replacement and installed a dirt tricks cam chain tensioner. I also replaced all the gaskets I came across. I had the head cleaned and the valve seats looked great.
While I was at it I did a lot of general clean up.
Oh yeah, I also installed a 100 watt stator.
I had a lot of fun working on it but I think I am going to sell it. It's a blast to ride and does 4th gear wheelies but I have been browsing the "some assembly required" sub forum and have a desire to build a CB or airhead based scrambler.
Old 07-25-2013, 06:53 PM   #4555
xathor
Not actually Gnarly
Oddometer: 448
Never had an issue with the starter or kick start. The ADC works as intended so I don't see a need to replace it.
Old 07-25-2013, 07:31 PM   #4556
Storm Howlet
The Storm Owl
Storm Howlet's Avatar
Oddometer: 31
Here is the one I use: http://www.dirt-bike-gear.com/stb.html
I don't put tools in mine, just a front tube and co2 filler kit.
the one StuInFH mentioned sounds similar
2010 KTM 530 EXC Champions Edition
1999 KTM 200 EXC
Storm Howlet is offline   Reply With Quote
Old 07-25-2013, 09:26 PM   #4557
resqd1
Oddometer: 236
But no brace? I am looking for a brace, not a bag, thanks for the info though
Old 07-26-2013, 12:44 AM   #4558
mbrick
Oddometer: 146
Nice rebuild pics!
How could you tell the oil ring was disintegrated? Started burning more oil?
mbrick is offline   Reply With Quote
Old 07-26-2013, 01:21 AM   #4559
LukasM
Oddometer: 5,426
The KTM brace was only for the older fenders, you might run into clearance issues at the bottom of the newer style mask.
However Pro-Carbon based out of the UK make a carbon fiber one for the newer fenders I believe.
Acerbis also has a universal one out of aluminum that you could probably sandwich between the bottom of the lower triple and the fender.
Old 07-26-2013, 06:09 AM   #4560
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,863
Loc-Tite is used on steel bolt to steel threads,grease is used on steel bolt to aluminum threads.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 02:02 PM.
