Old 08-05-2013, 03:53 PM   #4636
dualindalton
dualindalton's Avatar
Oddometer: 130
Originally Posted by Michhub View Post
When I had that happen I had a wire disconnected at the front brake switch....
Sounds like the problem lies somewhere in that area. Probably want get a chance to check it until this weekend but now I have a couple of good starting points. Thanks for the help.
dualindalton is offline   Reply With Quote
Old 08-05-2013, 05:43 PM   #4637
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Originally Posted by dualindalton View Post
I will start there and see if either switch is stuck. Hopefully that will be as far as I have to go.....if not I shall venture further. Thanks for the advice.
Actually, start with the wires at the switches to figure out which switch is stuck.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 08-05-2013, 06:00 PM   #4638
EsconDeasy
Ectomorph
EsconDeasy's Avatar
Oddometer: 1,486
My front micro switch started working backwards. When the lever was released, the brake light came on!
I removed it and use just the rear now
Is nothing scared!?
EsconDeasy is offline   Reply With Quote
Old 08-05-2013, 07:24 PM   #4639
fast4ward
Oddometer: 86
switch the connections and it'll work as designed. Someone likely crossed the wires at some point - previous owner ?
fast4ward is offline   Reply With Quote
Old 08-06-2013, 08:41 AM   #4640
mbrick
Oddometer: 135
Only if it has 3 connectors for normally closed and normally open modes. Merely switching the polarity shouldn't change this... ?
mbrick is offline   Reply With Quote
Old 08-06-2013, 08:52 AM   #4641
Bora20
Oddometer: 854
Yup, someone probably put them back on the wrong way.
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 08-06-2013, 01:06 PM   #4642
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Figured you had the logistics of the Loose Screw done, so you'd pop in here? I'll see you sometime Friday. I've had some delays that won't put me in Kamloops until the wee hours Friday morning. Hopefully I don't sleep in and miss some pre-ride action.
See you there!
Old 08-06-2013, 04:15 PM   #4643
dualindalton
Oddometer: 130
Thanks for all of the suggestions on the brake light. I'll be looking at all these areas to see if that is where the problem is.
Haven't had a chance to ride this bike much yet, but so far I am really liking this beast.
Old 08-06-2013, 08:22 PM   #4644
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
Quick question.
I want to run 14 / 52 gearing. Stock on my 2010 530 XC-W is 13 / 50. I don't like small counter-shaft sprockets. I think bigger ones wear longer.
The stock chain is 118 links. It looks like most chains I can buy are 120 links max. Do you think 120 links will fit with my 14/52 gearing?
What if you took Axl Rose down to Paradise City, but the grass was brown and under watered?
bigborefan is offline   Reply With Quote
Old 08-07-2013, 04:22 AM   #4645
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,086
Originally Posted by bigborefan View Post
Quick question.
14-52 will work perfect with 118 links....same combo Im running. Your good to go!
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 08-07-2013, 05:16 AM   #4646
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,600
Thx Hodaka, and welcome back.
Old 08-07-2013, 02:53 PM   #4647
WNC Rider
Oddometer: 14
Tire Question
I've got an 08 530 EXCR that I've worn the tires off after 800 miles. (the bike sat up for 4 years before I got it). There are ton of choices for tires out there. I'm looking for tires that get better mileage and work for a 80/20 - 70/30 mix of single track, Forest Service roads and asphalt.
Any experience or suggestions would be welcome.
WNC Rider is offline   Reply With Quote
Old 08-07-2013, 03:03 PM   #4648
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,086
Give the Dunlop 606's a try. They hook up pretty well, last a long time and have great grip on the road...they are also DOT legal. I use these for desert trips of 1500 miles or so and they are still 50% when I get back.
Hodakaguy
Old 08-07-2013, 03:13 PM   #4649
dualindalton
Oddometer: 130
I had the same experience on my 07 525 and am sure that will be the case on my new to me 2011 530. The best bang for the buck I could find were the Kenda Trackmaster. Always seemed to handle everything fairly well. Should be able to get a thousand to fifteen hundred miles from the rear and a little more than that from the front. That's what will be going on mine when the ones on it now wear out.
Frequent oil and tire changes.....it goes with the territory.
Old 08-07-2013, 03:55 PM   #4650
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 410
My goto rear tire is the Trackmaster II. Best bang for the buck out there. But, and it's a big but, I can destroy a rear in 500 miles. 700 tops. Tires are a commodity. Buy one that works well, use it. Buy another when necessary. I cannot comprehend sacrificing performance for the sake of saving a buck due to longevity on a KTM EXC.
Oh, and I'd suggest steering clear of the Trackmaster II fronts. Many better choices out there.
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Times are GMT -7.   It's 05:35 AM.
