Old 08-17-2013, 06:04 PM   #4726
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 579
Originally Posted by J.Johnson View Post
Have any of you used the Blais Racing jet kit. A customer of mine swears it is the best money he ever spent. He had a JD kit and says the Blais is night and day difference.
Wanted to see if someone had a similar experience before I pull the trigger.
Sent with this high tech chingadera!
Does anybody know how the Blais kit differs from the JD kit? Just wondering if they have different jet sizes.
mflora98ss is offline   Reply With Quote
Old 08-17-2013, 07:31 PM   #4727
Bungholio
Bungholio's Avatar
Oddometer: 756
Probably the custom tapered needles in the JD kit.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 08-17-2013, 09:46 PM   #4728
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
I dont know the difference,but,the JD jet kit in my 530 works great,gets good mileage,fires up easily,warms up quick and off it goes.
Nice snappy power with no popping or problems.
Probably some jet kit installers dont take the time to dial things in,who ever jetted mine did good.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 08-18-2013, 05:07 AM   #4729
mflora98ss
Dual Sportin'
mflora98ss's Avatar
Oddometer: 579
What kind of fuel mileage are you getting? I'm getting around 30 mpg with the JD kit. I'm not sure if that's good or bad...she really rips though.
Old 08-18-2013, 06:00 AM   #4730
Foot dragger
singletracker
Oddometer: 12,867
If I can refrain from doing wheelies and broadsliding every minute or so I get mid 40's on mileage.
Its a hot rod,not a mileage machine.
To me its just a dirtbike with a plate, and that's how I tend to ride dirtbikes that make enough power to play with.
But it really doesnt do much worse then low 40's most all the time.
I need to put 1 size smaller pilot jet in as I have the fuel screw set on full lean,it runs so well as is I havent made time to mess with it.
The end of the muffler never has any black soot showing inside it so its not overly rich at most rpm ranges,it seems like most bigger 4 stroke singles my buddies own either pop or run kinda rich,who ever did the jets on mine got it pretty good,it runs about the same at higher altitude.
Old 08-18-2013, 07:02 AM   #4731
Bungholio
Bungholio's Avatar
Oddometer: 756
Same as foot dragger here, mid 40's all the time all around riding.
Old 08-18-2013, 08:29 AM   #4732
braymond
Oddometer: 7
Average about 45 mpg all around riding with the jd kit. Never has been lower than that. Like Foot Dragger said, "its a dirtbike with a plate" so ride it like you stole it. Fuel + tires = $$$$=FUN= priceless
braymond is offline   Reply With Quote
Old 08-18-2013, 09:25 AM   #4733
Foot dragger
singletracker
Oddometer: 12,867
I had mine out in Nevada recently,I sat back and let it run up a slightly uphill sandy straight road...........I look down its going 90 and still pulling good. Jeechrise they really dont lack for pulling power!
Mine is jet kit only with Q muffler. 14/50 gearing.
Old 08-19-2013, 04:25 PM   #4734
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,669
I run some jetting specs I got from the KTM dealer in Santa Cruz CA. I think I am a little fat, but she runs real nice, starts easily, no issues. I got a big tank and don't do any epic out west rides, so I am content with it.
How much you got in it? StreetBikeMike
bigborefan is offline   Reply With Quote
Old 08-19-2013, 07:45 PM   #4735
Honkey Cat
Tailights Fade!
Oddometer: 1,119
Jet kit
I did Not by JD jet kit I call Jeff Slavens he sold me a couple jets it was a total of about five dollars and in Colorado the ktm ran perfect from 6k to 13 k. Im from florida.
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 08-22-2013, 03:16 PM   #4736
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
need some help here guys. My 08 450 xcrw just had a full rebuild and was running until some smoke appeared. My mechanic traced it the crank shaft seal, he installed a new one the same way as the old which is also the one that has failed. question is should the seal have the inner spring facing toward the bike or the clutch cover? just wanting to check because I know some seals came from factory backwards. the one seal was facing with spring part inside the engine so he installed a new one which failed so now I got another new one waiting to figure this out.
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 08-22-2013, 09:58 PM   #4737
cactusone
Oddometer: 7
Spring faces the crank. I went to the 2009+ seal on my 08 after I replaced 2x, now no prob's. Some say it won't fit correctly but 60 hrs and works great, the 08 is pretty poor if you ask me the 09 is thicker.
cactusone is offline   Reply With Quote
Old 08-24-2013, 10:12 AM   #4738
antpatterson
XR650L_High_Runner
Oddometer: 378
So I have the bike back in my hands and got another issue. My mechanic said he did some research and found out that the crankcase breather hose is why oil is pushing back into my carb and to disconnect it. My dad and I have disconnected the hose from the crankcase and left the carb running to the top of the engine together with the t-joint blocked off. Now we have the hose from the crank blocked somewhat so that oil can get out because it keeps wanting to push out, is this normal? Is it because too much oil is in the engine?
XR80r
2008 XCRW450
Old 08-24-2013, 06:03 PM   #4739
dualindalton
dualindalton's Avatar
Oddometer: 131
shock spring help
I am ready to replace the rear shock spring and need a little guidance on what spring rate to go with. For reference I weigh-in at 190lbs, add riding gear that includes a camelback full of water adds another 15lbs and last are my wolfman saddle bags and tail bags with some tools and a few other essentials which puts another 20lbs for a total of 225lbs.
Is anybody weighing/carrying about the same load that could recommend a spring rate? I have looked at the race-tech site but their calculator only ask for rider weight without gear. Based on that it suggests going to the next heavier spring rate than stock.
Also does anyone have any opinions on straight rate vs. progressive springs? At 55 years old I'm no longer in race mode but do have those "moments" where twisting the throttle and acting like I'm 17 again do arise. I'm getting tired of having to straighten out my tag from bottoming out when the fun factor kicks in.
dualindalton is offline   Reply With Quote
Old 08-24-2013, 07:03 PM   #4740
fast4ward
Oddometer: 86
If you take a look at the RaceTech site, they have a calculator that figures out what spring rate you need based on your bike, your physical characteristics and the kind of riding you do.
fast4ward is offline   Reply With Quote
Times are GMT -7.   It's 03:50 AM.
