Old 08-25-2013, 05:39 AM   #4741
dualindalton
dualindalton's Avatar
Oddometer: 131
Originally Posted by fast4ward View Post
If you take a look at the RaceTech site, they have a calculator that figures out what spring rate you need based on your bike, your physical characteristics and the kind of riding you do.
I used the calculator on the RaaceTech site. Just wondering how or if someone would need to compensate for the added weight of riding gear and any other extra weight to determine the spring rate since the calculator asks for rider weight "without gear".
Maybe someone else will chime in and tell what criteria they use when choosing a new / heavier spring.
dualindalton is offline   Reply With Quote
Old 08-25-2013, 10:46 AM   #4742
antpatterson
XR650L_High_Runner
antpatterson's Avatar
Oddometer: 378
Any advice on the crank case hose blowing oil out would be helpful. I disconnected it from the carb and it is just pushing oil now minus fowling the plug. Is it too much oil or something else?
2009 XR650L (100+k miles)
2008 Qlink XP200 (60k miles)
2006 CRF250r (traded)
XR80r
2008 XCRW450
antpatterson is offline   Reply With Quote
Old 08-25-2013, 11:08 AM   #4743
xathor
Not actually Gnarly
Oddometer: 451
Just thinking about it logically... The only reason the hose is there is to evacuate the oily vapors. The oily vapors are there because of blow-by. The only oil that gets up there is from the oil squirter that lubes the camshaft and any oil that walks up the cam chain, minus oil that accumulates because of the blow by vapors.
If you have a little oil coming out of the vent, completely normal in almost all four stroke motors. A lot of oil means you over filled it or you have a ton of blow by.
2014 KTM 690 Enduro R (21/18 & 17/17's)
2008 Subaru STi (e85 powered beast, ~500hp)
1998 Land Rover Discovery (daily driver)
Past: 800xc, WR250R, 450EXC-R, KLR
xathor is offline   Reply With Quote
Old 08-25-2013, 02:07 PM   #4744
Bungholio
Bungholio's Avatar
Oddometer: 755
There is enough preload adjustment after you get the correct spring, to compensate for gear, unless you are carrying an 80lb pack on your back all the time. Riding gear weight, maybe 10lbs, is compensated when you set sag with gear on.
Sent from my Galaxy Nexus using Tapatalk 2
Bungholio is offline   Reply With Quote
Old 08-25-2013, 03:02 PM   #4745
fast4ward
Oddometer: 86
exactly!
fast4ward is offline   Reply With Quote
Old 08-25-2013, 07:27 PM   #4746
cactusone
Oddometer: 7
Do not fill past 3/4's up the site glass.
cactusone is offline   Reply With Quote
Old 08-25-2013, 10:08 PM   #4747
dirtdiver
Oddometer: 2,039
fuze?
Guys, does the 530 have a main fuse? I was riding my bike today in the rain and all of a sudden my electrical died. The battery shows fully charged but I get no lights or starter.
I looked at that little fuse block near the battery and those two 10a fuses were good. I know that there has got to be something other than those small 10amp fuses.
Any help?
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is offline   Reply With Quote
Old 08-25-2013, 11:40 PM   #4748
smacka
Tripper head
smacka's Avatar
Oddometer: 44
The manual shows only the 10 amp fuse to which you refer.
If that is okay can I suggest that you check the earth strap from the negative battery terminal.
Later,
Smacka
smacka is online now   Reply With Quote
Old 08-26-2013, 06:56 AM   #4749
dirtdiver
Oddometer: 2,039
Later,
Smacka
That is a good idea. Also i will recheck the fuse connectors.
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Old 08-26-2013, 03:57 PM   #4750
dualindalton
Oddometer: 131
Makes sense....thanks for the clarification.
Old 08-26-2013, 06:32 PM   #4751
Beardoge
Oddometer: 375
Hello everyone I just recently purchased a 09 530 EXC with only 400 miles on it. While I'm certainly not looking for a oil debate.
But is there a consensus on what oil is generally used.
The previous owner Had a synthetic blend Castrol 20w50 in the engine and some sort of 80weight in the trans.
But the owners manual says to use a 10w40 in both the engine and the trans is this what I should use ?
Also the owners manual says to use 95 octane gas but I'm not sure it that's a European number or not, the best that's around here is 93 with occasional 91 which should be good enough.
And is there any mods that need to be done? It has a fan kit with overflow bottle, skid plate, desmogged, dj jet kit, and a ktm by fmf muffler on it and it seems to run good maybe a bit rich but good enough I suppose.
One more what's one of the better websites to get KTM parts off ?
Thank you for any replies, looking forward to learning all about these bikes which I have never owned before.
Beardoge is offline   Reply With Quote
Old 08-26-2013, 06:52 PM   #4752
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,095
Pretty much run whatever gives you that warm fuzzy feeling. With that said I run Mobil 1 15W-50 for high performance engines (has the small race flags in the corner of the bottle) in both the engine and the trans. Ran this oil for thousands of miles. Another plus is its available at some Walmarts in a 5 qt jug for $22!
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 08-27-2013, 04:13 AM   #4753
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,866
The Race Tech spring calculator seems to give numbers pretty far toward the stiff side of the scale. Some people would say "off" the stiff side of the scale.
Enduro Engineering's spring chart (link) is pretty much in-line with the recommendations of the tuners around this area.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 08-27-2013, 06:53 AM   #4754
ChrisK7
ChrisK7's Avatar
Oddometer: 254
Hodakaguy
I agree with Hodakaguy. Pretty much what I've been doing with mine.
'14 KTM Adventure 1190R 12 KTM 990 SMT ,09 KTM 530 EXC (plated), 09 Kawasaki Brute Force 750
ChrisK7 is offline   Reply With Quote
Old 08-27-2013, 07:52 AM   #4755
Bungholio
Bungholio's Avatar
Oddometer: 755
I had the racetech recommend Springs installed and am perfectly satisfied with the results, 180lb, intermediate trail rider. Progressive rear spring and straight rate front. Be honest about your skill level and type of riding.
Times are GMT -7.   It's 12:57 AM.
