Old 09-04-2013, 07:12 AM   #4816
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
Originally Posted by dirtdiver View Post
This is what DDjr and I did.
You really put that aluminum framework on the ft of your bike?Just to hold lights.
Thats different.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 09-04-2013, 07:26 AM   #4817
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,972
Originally Posted by Beardoge View Post
Whoa... I guess I better get some weights. Damn these bikes are powerful !
You don't need weights, it was more of a statement inforcing the necessity of rim locks, tire pressure, slipping of tires on the rim and ripping the stems off of tubes.
Thats different.
That's a kind way of putting it.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 09-04-2013, 09:20 AM   #4818
Subaru297
Oddometer: 117
I am sure you will get lots of reports either way but I am another person that removed both rim locks when I changed my first set of tires.
~4000kms later with around 20psi and my tubes haven't moved yet. I do leave the valve nuts off as well like Hodakaguy.
My guess is that anything above the high teens for PSI and you don't need rim locks. This does not apply to a tire filled with hundreds of sharp spikes though!
Cheers
Subaru297 is offline   Reply With Quote
Old 09-04-2013, 09:35 AM   #4819
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,972
Cheers
True. My old 640 didn't have rim locks, but rarely ran pressures below 20. No problem.
Old 09-05-2013, 02:54 PM   #4820
AB13
Oddometer: 1,068
lights
I ordered a Baja Squadron kit with dimmer and regulator today AB
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 09-06-2013, 11:01 AM   #4821
Beardoge
Oddometer: 374
Can you guys make a suggestion of some good websites to buy parts from. I got sicass and a few others but what i'm really looking for as silly as it sounds is a rack for the back.
Planning on doing some longer trips and am missing the rack on the back for tents and the like.
Beardoge is offline   Reply With Quote
Old 09-06-2013, 01:31 PM   #4822
Joe
Debaser
Joe's Avatar
Oddometer: 1,747
Try: http://seatconcepts.com/products#!/~...094&id=8231408
I have never tried one but the price seems pretty reasonable.
Joe is offline   Reply With Quote
Old 09-06-2013, 01:33 PM   #4823
Foot dragger
singletracker
Oddometer: 12,856
A rack always seems like the go-to thing for camping.........but,check out Giant-Loop,Wolfman and maybe others for strap on luggage that requires no rack. Putting a rack on a 530 can be done,it aint cheap and is usually a pain to take off and on.
Old 09-06-2013, 02:31 PM   #4824
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,093
Plus 1 on using a Giant Loop for luggage instead of a rack. Keeps your gear nice and secure and allows you to ride like a dirt bike even when fully loaded, nothing shifts or moves. Lots of pics of my 530 loaded for camping in my ride reports.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 09-06-2013, 03:20 PM   #4825
AB13
Oddometer: 1,068
wolfman
Wolfman Rollie system works great on that bike. AB:-)
Old 09-06-2013, 05:02 PM   #4826
bruceo
Oddometer: 164
Originally Posted by hodakaguy View Post
plus 1 on using a giant loop
hodakaguy
+1
2012 KTM 990 Adventure R
2010 KTM 530 EXC
bruceo is offline   Reply With Quote
Old 09-06-2013, 05:28 PM   #4827
dualindalton
dualindalton's Avatar
Oddometer: 130
Where's my oil?
When changing my oil today I only recovered 500ml. I recall seeing a post somewhere that suggested there may be some oil "trapped" inside the motor. This is the first oil change I've done on this bike and don't know how long it has been since the last change.
I put 600ml back in but now I'm concerned that I if that lost 100ml wasn't burnt but trapped then I could possibly now have 700ml in the motor.
I have to lean the bike pretty far to the right before I can see the oil drop down to the top of the glass.
My plan is to level the bike and then slowly remove oil until it is at the top of the sight glass.
Any thoughts or suggestions on where the oil went?
dualindalton screwed with this post 09-06-2013 at 05:38 PM
dualindalton is online now   Reply With Quote
Old 09-06-2013, 06:03 PM   #4828
resqd1
Oddometer: 236
intersted to hear on this too, mine was right at the bottom of the site glass and only drained out about 400ml, in the middle of gear swap and water pump fix, based on Hodaka write ups.
resqd1 is offline   Reply With Quote
Old 09-06-2013, 06:08 PM   #4829
wsmc831
wsmc831's Avatar
Oddometer: 760
I always found this to be a real pita on the 530. the sight glass is nearly worthless. My oil level seemed to vary quite a bit until I got rid of the oem rings/pistons, valve seals and oil pump stuff. I quit worrying about how much came out and just put the same amount in, whatever that was, 600ml or whatever. Miss the torque of the motor, sure don't miss the split oil.
97 TL1000S
2010 690 EnduroR
2013 500 Exc
wsmc831 is offline   Reply With Quote
Old 09-06-2013, 06:26 PM   #4830
dualindalton
Oddometer: 130
Trapped oil vs burnt oil are obviously two separate issues. I have not seen any oil residue any where on the bike that would suggest that it is either burning or blowing oil. My hope is that it is just the "trapped" oil. The other scenario means that I'm losing 100ml at some point between changes. Since this bike is new to me I will have to pay close attention as to the rate of loss between changes in relation to the miles ridden if it is in fact using oil. I'd rather it be just a case of having to remove a little to get it to the proper level. I can live with that!
Times are GMT -7.   It's 05:39 AM.
