Old 10-09-2013, 06:55 PM   #4966
59ksmall
59ksmall's Avatar
Oddometer: 34
Thats the thing, this bike will do 100 fairly easy. Blows my mind.
And that is on Pirelli scorpions at 8 and 10 psi!
2010 KTM530 xc-w SixDays
1990 GSXR 750 slingshot
2003 SV650s (sold)
2007 DRZ400sm (sold)
59ksmall is offline   Reply With Quote
Old 10-09-2013, 07:40 PM   #4967
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,984
Originally Posted by 59ksmall View Post
Any suggestions for the sprocket/brake set-up for the 17in sm wheels?
Im either going to stick with the 13t CS, swap the current 50t to the new rear wheel and get another 50 or 52 for the dirt set-up. Or put a 14t up front. I will probably just leave the 13t and see how that does with the 50t on the sm wheels.
Not a chance! 13/50 is craaaazy low for 17" wheels. I'd have to look at mine, but I'm pretty sure it's 14/45. I have a shorter chain to swap. Not saying you can't ry it, but you'll be disappointed.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 10-09-2013, 07:59 PM   #4968
59ksmall
59ksmall's Avatar
Oddometer: 34
Thats what I was thinking. I will try it out though and see how it goes. I might even take some good video of it!
I guess I might have to shorten the chain because Im not sure if the adjuster could take up the slack for a smaller rear sprocket.
2003 SV650s (sold)
Old 10-09-2013, 09:19 PM   #4969
Navin
Navin's Avatar
Oddometer: 8,386
14/50 on the big wheels and 14/48 with the 17", the axle adjuster blocks can flip to make up 2 rear teeth, no chain adjustment necessary.
Navin is offline   Reply With Quote
Old 10-09-2013, 09:57 PM   #4970
59ksmall
59ksmall's Avatar
Oddometer: 34
Sweet! Thanks.
Found some rotors but not sure if they will fit. I know I will need a brake adapter. Any thoughts?
http://www.ebay.com/itm/320mm-Oversi...34d558&vxp=mtr
2003 SV650s (sold)
Old 10-10-2013, 01:20 AM   #4971
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,149
Will fit no problem. And the relocation bracket is a Ktm powerpart, for sale at Any dealer.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 10-10-2013, 08:09 AM   #4972
davesupreme
grand poobah
Oddometer: 1,643
i gotta factory '06 450 SMR... sprockets are 14/45, and anything else i tried wasn't as good.... 14/48 sounds too short for a 530, it'll probably pull less than a 45... you can get sprockets from RMATV for like $20, so easy to try....
davesupreme is offline   Reply With Quote
Old 10-10-2013, 09:48 AM   #4973
JTOP
Tree Top Flyer
Oddometer: 15
Wheels
I'm in the market for a spare rear wheel so I don't have to keep changing out my tire when I go to the dunes. Paddles are a PIA. Anyway, anyone know about WARP 9 wheels? Seem to be the most reasonable option out there at $380 for complete rear with disk and sprocket. 19" rears are lot cheaper, but that would mean having to buy a new paddle tire and not sure about the fit. My current setup doesn't leave much room between the tire and swing arm- altough I could probably add a link to slove that. Any ideas?
JTOP is offline   Reply With Quote
Old 10-10-2013, 10:49 AM   #4974
trailjammer
trailjammer's Avatar
Oddometer: 374
WARP 9's are the cheapest way to go and they work great if you're hitt'en the dunes all the time. Easy swap. Just make sure you have the same rear sprocket number of teeth and no adjustment necessary.
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 10-10-2013, 12:52 PM   #4975
900rider
Oddometer: 645
I run them on my 450exc that I supermoto'd. $1200 for a front, rear, tubes, tires, rotors, sprocket and caliper relocator. They have performed very well!
900rider is offline   Reply With Quote
Old 10-11-2013, 03:23 PM   #4976
Honkey Cat
Tailights Fade!
Oddometer: 1,118
just installed my dirt tricks chain tensioner, what a nice difference. Easy to install. You don't need to put at TDC. I apologize after listening I realized I sound nasally and realized my voice is annoying.
with stock chain tensioner
with dirt tricks installed
My favorite philosopher is Cha Ching !
Honkey Cat screwed with this post 10-11-2013 at 08:14 PM
Honkey Cat is offline   Reply With Quote
Old 10-11-2013, 06:57 PM   #4977
Weldit
Weldit's Avatar
Oddometer: 336
I knew you would be happy - same as me - now to address my oil useage !
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 10-14-2013, 01:25 PM   #4978
Krazyjohnny
Oddometer: 449
HID Headlight Project
Make some slow but sure progress due to other commitments getting in the way.
The parts from The Retrofit Source. Morimoto projector with Hi-Lo beam cut off, Their three-five ballast, bulb and wiring harness.
Modifying the stock housing after removing the lens.
Bulb and projector installed for a trial fit prior to JB Welding the projector into the housing.
Projector JB welded into the housing.
Projector in housing with the hi beam cut-off wires ran out of the lo-beam bulb socket.
That is as far as I have gotten. I am working on some stand-off brackets to allow for enough room for the bulb to extend out of the back and not hit the steering head stem. May be another week or so before I get anything else done. Headed to Arkansas for a sportbike ride this weekend.
President and Founder of
Superhero Proving Grounds
"Where dreams are made and egos are checked"
2013 Ducati Multistrada, 08' 530 EXCR, 09' Yamaha FZ-6
Krazyjohnny is offline   Reply With Quote
Old 10-14-2013, 02:21 PM   #4979
dieselcruiserhead
Oddometer: 1,462
Cool. I do the same thing except I use a "vibration proof" h4 bulb from PIAA for about $40 a bulb or 2 for $55. Never had one fail, pushing 3.5 years now on the same bulb with some crazy adventures... Use a $8 glue gun from Wal Mart and it works great... I alsop did it on a 8" Baja Designs light rather than the 7" retrofit...
http://andreshoumatoff.smugmug.com/M...onversions-KTM
On a second note, started getting the dreaded water pump weep, pretty severely now. But even with low water with the thermostat pulled it still runs super cool and the fan hardly triggers.
Wasn't aware it happened on the 08-11 like it does with the RFS engines. Started searching and found more more great article by Hodaka guy... basically have to replace a seal...
http://ridedualsport.com/forum/index.php?topic=2658.0
dieselcruiserhead is offline   Reply With Quote
Old 10-15-2013, 05:25 PM   #4980
Beardoge
Oddometer: 376
Well I'll be damned what a great idea !
I have no less than 4 new H4 bulbs laying around here for the snowmobiles, why the hell did I just buy the $15 halogen from sicass that's only a little brighter than the incandescent 35w the bike came with..... damn it..
Beardoge is offline   Reply With Quote
Times are GMT -7.   It's 06:05 AM.
