Old 01-26-2014, 03:56 AM   #5461
bkoz
bkoz's Avatar
Oddometer: 324
Originally Posted by Hodakaguy View Post
Well I received the 2012 500 rocker shafts a few days ago and finally got the chance to install them and compare them with the shafts out of my 530. They measured out the exact same but do have a new thin flat strip machined into the top of them. I also modified them a bit to get better more oil flow to the rocker arms.
Link to the How To here: CLICK HERE
Hodakaguy
Another great how to. My new rocker shafts are on order but I am still at work and haven't installed them yet.
I wonder how many rocker arm failures are related to oil burners/oil quality. The first thing to go in a low oil situation is the top end. Oil quality/overly extended oil changes could be part to the issues too. Just like VW and their TDI camshaft failures.
bkoz is offline   Reply With Quote
Old 01-26-2014, 07:57 AM   #5462
Beardoge
Oddometer: 374
I was going to replace the piston and rings with a wossner kit for my 09 530. The kits come with 94.96 - 97 - 98 size pistons. At a 12.5 compression ratio
Does anybody know the stock size piston as my book only says 95MM. And do you think that a 12.5 to 1 is a little too high over the 11.9 to 1 my book says.. I ride into areas that sometimes only have 87 but figure if I ride easy (half throttle) I should be okay with 87.
What do you guys think.
Beardoge is offline   Reply With Quote
Old 01-26-2014, 10:07 AM   #5463
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,092
Yeah I'm sure that plays into it heavily as well. I try to religiously keep the oil fresh in my bike, figure that's on the cheap side of keeping it happy
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 01-26-2014, 10:09 AM   #5464
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,092
You need to get the jug off the bike and measure it before ordering the piston. I have a friend running the Wossner in his 530 and it runs great on regular 87
Hodakaguy
Old 01-26-2014, 10:12 AM   #5465
Navin
Navin's Avatar
Oddometer: 8,082
Thumper Racing 570 kit is a great choice if the top end is tired. If you need to go down to the crank the 610 is AMAZING and you can merge the sumps while you are there anyway.
Navin is offline   Reply With Quote
Old 01-26-2014, 10:14 AM   #5466
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,092
Installed the new GatosBros Pinchy-Clamps on the 530 this morning. Pretty cool design that should help in preventing the hand guards from rotating in a crash. With the Pinchy-Clamps you still use the inner clamps provided with the hand guards and then the Pinchy-Clamps also clamp on to the outer part of the bars....giving you twice the clamping force to keep the hand guards in place.
Picture of my Fastway hand guards with the GatosBros C-clamps on the ends.
And a comparison between the C-clamps and the Pinchy-Clamps. You can see the Alan bolt on the Pinchy-Clamp used to clamp it to the bars.
And installed. Should make the hand guards nice and solid!
Hodakaguy
Old 01-26-2014, 10:20 AM   #5467
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,155
Originally Posted by Vicks View Post
Tried finding a Kibblewhite valve + spring kit for the 530Exc on their website but all they have is for the RFS bikes.
Any help ?
anybody ?
Vicks is offline   Reply With Quote
Old 01-26-2014, 03:32 PM   #5468
dieselcruiserhead
Oddometer: 1,453
I have the Gatos Bros underbar stabilizer mount (and 10mm riser). It's incredible / a work of art. And very well thought out in terms of adjustability, etc...
More photos here http://andreshoumatoff.smugmug.com/M...ys/i-ZvJqv5C/A
I'd have their clamps too but I have HDB guards. I'm considering getting rid of them and going back to RM ATV bars with Cycra guards because of these - they look awesome..
dieselcruiserhead is offline   Reply With Quote
Old 01-26-2014, 04:20 PM   #5469
Hypermofo
Oddometer: 275
Fab a new sleeve with the same OD/ID's but longer. Drill out the broken stud + frame to accept the longer sleeve. Have the sleeve welded to the frame from the backside.
Ah! Great idea! Thx bkoz! That may be the route i go.
Does anyone know if the Promoto stand is made to work with or without the little part that sticks out? If it works w/o that might be easiest but it is spendy...
HM
__________________________________________
Hey, is my collar bone supposed to look like that?
Hypermofo is offline   Reply With Quote
Old 01-27-2014, 05:48 AM   #5470
bkoz
bkoz's Avatar
Oddometer: 324
Kibblewhite Valves
anybody ?
2 years ago Kibblewhite did not offer valves that I could find for the XC4 engines. Not enough demand. OEM was the only option I could find.
Things may have changed since then.
bkoz screwed with this post 01-27-2014 at 03:11 PM
Old 01-27-2014, 07:12 AM   #5471
bruceo
Oddometer: 164
HM
I had the same break as you, the pro moto kickstand does not use that nipple and solved the problem.
Sent from my iPad using Tapatalk HD
2012 KTM 990 Adventure R
2010 KTM 530 EXC
bruceo screwed with this post 01-27-2014 at 07:18 AM
bruceo is offline   Reply With Quote
Old 01-27-2014, 07:18 AM   #5472
BlackTDI
Oddometer: 7
Hello everyone. My name is Ben. I've been a long time lurker here but haven't joined officially until the other day. Usually I find myself here reading riding reports of South American adventures but today I'm looking for some help. The other day I was out riding and the bike was running top notch. The bike is an 08 530.
I had just done an oil/filter change and decided to take it out since the weather was great. Parked the bike for about 45 minutes to catch up with some buddies of mine at a great lookout at 4600'. Hopped back on to head home home and she didn't want to start. After multiple kicks+electric start she fired up but it ran like I was just about to hit reserve. I knew I wasn't low on fuel so i flipped it to reserve then back and finally the bike caught back up with itself.
At first I thought it might have been the elevation I'm at since it's jetted for sea level. Bike made it home fine but didn't want to start at all the next day. Took the seat and tank off and checked for spark...Nothing. So here I sit dead in the water. I have the trail tech stator/dc conversion kit installed and I can't find any specs online to test them. The primary winding on the coil tests a little high at .5Ω and should be between .25Ω and .35Ω and the secondary coil tests good at 6.2Ω and should be within 5Ω and 7.5Ω. so I'm pretty sure the coil isn't the culprit. I took the spark plug boot off to see what type of resistance reading I could get and it shows that its open. I can't get it to read anything and while doing a continuity my meter won't even beep, telling me its open somewhere.
I have tried turning it over holding the bare spark plug wire to the case and I get nothing. I even cut it back a 1/4'' to make sure I had a good connection but still nothing. I also checked the ignition pulse generator that should be at 100Ω +-20Ω and it reads open too. To make sure I was getting a good reading I took the blue plug and removed the red and green wires from it to ensure good contact but still nothing. Any help would be greatly appreciated. I'm going to try to contact Trail Tech this week to get the specs.
Thanks, Ben
BlackTDI is offline   Reply With Quote
Old 01-27-2014, 10:35 AM   #5473
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Everyone warned me the KTM MX style seat is brutal. After my Everglades ride, I found that to be true. Seat Concepts has a solution, and I modified my seat with their parts.
The Seat Concepts set-up is nice. Its still narrow up front where off-road control is needed while standing, and wide towards the rear where but cheeks are planted when sitting.
Lets get together stock seat and a few materials and a staple.
Stock seat shredded and new foam and cover about to go on
I was amazed at the level of detail in the stitching, also the top is gripping for control while seating, sides slick.
Wowsers I'm happy with the Seat Concepts product. Time to get some magic desert dust and magic FL mud all over this this
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL screwed with this post 01-27-2014 at 01:11 PM
steveWFL is offline   Reply With Quote
Old 01-27-2014, 10:52 AM   #5474
mountaincadre
Oddometer: 359
My arse hurts just looking at that.
mountaincadre is offline   Reply With Quote
Old 01-27-2014, 11:01 AM   #5475
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,800
Looks nice SteveWFL...
thinking about the same thing on mine. Nice job.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Times are GMT -7.   It's 03:53 AM.
