Old 01-30-2014, 12:18 PM   #5566
AB13
Oddometer: 1,010
Originally Posted by Sting View Post
Cool. A butt-Dino is what they are called on the Veter forums. :-) Motown, an engineer over on the trials forum calls this "machine awareness." Enjoy!
Actually mines a Dyno Jet 250i in a INC room. It helps divide backyard mechanic's from professional ones it doesn't lie speculate or stretch the truth kinda like math. AB
Just joined for the sticker.
AB13 is offline   Reply With Quote
Old 01-30-2014, 07:31 PM   #5567
the_real_wild1
Oddometer: 146
That reminds me. I need to buy a couple sets of heated grips. One for the 530 and the other for the can am.
the_real_wild1 is offline   Reply With Quote
Old 01-31-2014, 09:00 AM   #5568
stingraysktm
stingraysktm's Avatar
Oddometer: 24
21.5 liter KTM tank install question. I'm adding the tank to a 2010 530 XC-W and was wondering how others are mounting the rubber tank rollers that the instructions show attaching to the radiators. Do they mount to the tabs for the stock tank shrouds (which would leave the rollers rotated 90) or maybe the lower tab for the stock radiator guard?
stingraysktm is offline   Reply With Quote
Old 01-31-2014, 04:39 PM   #5569
dualindalton
dualindalton's Avatar
Oddometer: 130
stingraysktm, assuming that you have the KTM branded or the Acerbis tank, the tank rollers (pucks) as far as I know don't attach to the radiator. The package, I'm guessing, came with 2 rollers and two machined screws. The stock rollers will have to be removed and replaced with the new ones. The roller on the left side uses a spacer that want allow the tank to fully seat. The roller that came in your package along with the shorter screw pulls the roller in just a little closer to the frame. The roller on the right side may fit with the stock roller but I replaced it with the one provided. The tank should fall into place after you change the rollers.
I hope this is what you where asking about, if not maybe someone else will come to your aid.
The world went and got itself in a damn big hurry~Brooks Hamlet~
dualindalton is offline   Reply With Quote
Old 01-31-2014, 04:54 PM   #5570
dualindalton
Oddometer: 130
Originally Posted by steveWFL View Post
Hodakaguy, the fuel lines you used on the Acerbis 6.3 tank and the air fitting, was it 1/4 " line or 5/16th?
Also, where did you find the heat shield material used over your fuel line?
I went shopping today and struggled a bit
Not Hodakaguy, but I used 1/4" Motion Pro fuel line. Fit was "slightly" tight but a dab of grease and it slid right on.
Checked at all of the big Automotive stores for the T-fitting to no avail. Went to a industrial bearing store, low and behold the guy had a bin full of them. Looks just like the one in Hodakaguys pic and was only $3.19.
None of the Auto stores stocked the heat shield but it is available on line at AutoZone.
Old 01-31-2014, 05:01 PM   #5571
dieselcruiserhead
Oddometer: 1,417
Can someone post the photo of the 21.5L tank? I don't recall there being a 5.5 gallon tank for the 08-11 unless I somehow missed this?
thanks, a
andreshoumatoff.smugmug.com
Grand Staircase Escalante Road Reports
Cycles South Vintage Moto Trek Movie - check out all 7 parts
dieselcruiserhead is offline   Reply With Quote
Old 01-31-2014, 05:16 PM   #5572
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,108
Not sure if this is what your talking about but.....
On the large desert tank the two rubber bumpers attach to the back of the lower radiator tab and the tank rests on the rubber bumpers once installed.
Here's a couple pics of how they mount up.
Rubber bumpers mounted to lower tab, facing backwards.
The bumpers rest on the tank here (black arrow)
And mounted up.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 01-31-2014, 05:17 PM   #5573
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,108
Same setup I'm running
Hodakaguy
Old 01-31-2014, 05:23 PM   #5574
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,108
thanks, a
I believe the KTM Hard parts tank was listed as a 21L tank (Link here: CLICK HERE) where the Acerbis version is listed at a 23L tank, even though Acerbis makes the hard parts tank for KTM.
I've owned both and prefer the KTM tank just because I like the 1/4 turn stock cap
Old 01-31-2014, 05:32 PM   #5575
stingraysktm
Oddometer: 24
Dualindalton, thanks for the reply. It is a KTM tank but of course made by Acerbis. The tank slid right on with the stock frame sliders so didn't really see an issue there. The directions do show sliders going on the radiators too and there are indentions in the molding of the tank in that same area.
Here's a pic of the 21.5 L tank.
It will probably be okay leaving it like it is, just wanted to see if others had came across this issue and what they did.
Old 01-31-2014, 05:38 PM   #5576
stingraysktm
Oddometer: 24
Hodakaguy, that will work for me! Thanks.
Also the stock gas cap is tight as hell. Does it loosen up overtime?
Old 01-31-2014, 05:41 PM   #5577
dualindalton
Oddometer: 130
And mounted up.
Hodakaguy
Guess I could have stirred stingraysktm wrong. Thanks for the clarification.
I did replace the stock pucks with the ones provided. The tank just wouldn't line up with the stock ones. Thought for a while that wiring on both sides were the culprit but after some re-reouting and zip tying the tank still didn't want to seat properly. Changed out the pucks and it fell into place.
I will have to pull it off tomorrow and reevaluate my procedure.
Old 01-31-2014, 05:54 PM   #5578
dualindalton
Oddometer: 130
Yep sorry about the confusion on my part. My bad. Now just got to find out what is keeping my tank from going on. Oh well, just glad it finally warmed up enough to be in the garage taking on some past due projects.
Nice EXC.
Old 01-31-2014, 06:02 PM   #5579
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,108
Nice EXC.
Usual culprits are the cables that run above the rubber bumpers sticking out each side of the frame that the tank sits on. The cables can pop out and get pinched between the tank and the bumpers.
Even when those are clear the bumpers sometimes want to hang up on the tank, with a little patients you can work the tank back and forth and get them to seat down on the bumpers.
Hodakaguy
Old 01-31-2014, 06:10 PM   #5580
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,849
Ive heard that the cap tension can be varied by adjusting screws on the underside of the cap,Hodaka guy probably has a handle on this,
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 12:24 AM.
