Old 02-17-2014, 12:15 PM   #5656
Stobie
Mr. Motivated
Stobie's Avatar
Oddometer: 1,863
Originally Posted by dieselcruiserhead View Post
cool I'll start with that. Crosses my mind that I never actually did sag measurements on this newish bike to me (bought last fall).
I was on .48 before on my old RFS and it was great. Also with 5 weight. But both have custom valving by POs.
Weight was heavier on the old 525 but had a smaller tank so might have been lighter up front. I think .50 will work well. I'll probably start with 7.5 or 10 weight possibly for now and then see what happens..
From there maybe work towards a revalving, but it 's really really close right now (it feels).
I've been told by a couple of tuners, James Siddall of Superplush for one, that heavier oil can cavitate and cause fade; and also affects rebound as much as compression, which may not be good. Just change the springs first and see if that's enough. I would agree with header on the choice of .50 rate, too, based on my own research for myself (6'4", 235# nekkid).
Also, I betcha it gets even more plush on small stuff with the stiffer springs, since you'll be running less preload and/or staying higher in the stroke.
Stobie
Problems cannot be solved at the same level of awareness that created them.
-Albert Einstein
Stobie is offline   Reply With Quote
Old 02-17-2014, 12:29 PM   #5657
header
Chris
header's Avatar
Oddometer: 1,746
Precisely
-Replace all seals, bearings, bushings, clean, re coat, etc. There can be no unwanted friction
-Find the springs to hold the bike up where you want it and where you want it to end up after a hit
-Revalve to control how fast you want the suspension to get to where the springs will stop it
When you buy a revalve your buying the research of the last one. Otherwise everything is pretty simple. Its getting it to work in everything that makes it tricky.
KTM 530exc
525exc refresh
header is offline   Reply With Quote
Old 02-17-2014, 01:16 PM   #5658
bkoz
bkoz's Avatar
Oddometer: 324
Originally Posted by Rickfenn1 View Post
Bottoming out isn't much of a problem since I've converted to the supermoto setup it's just real harsh on the small stuff to the point where if its a little bumpy in a corner the front will try and wash out (and has). I bought the bike last year with no manual and I'm almost positive the fork oil has never been changed so obviously anything will help at this point. I'll try 120mm.
Will a pin wrench like this one remove the fork cap. I might just buy the socket so I can torque it correctly. Although I've been a mechanic for 10 years so I understand how to tighten aluminum into aluminum. http://www.tormach.com/uploads/image...ner_wrench.jpg
If you have the pin wrench I wouldn't worry about the fork tool.
The trick is to loosen and tighten the cap while the fork is still on the bike.
Loosen the top triple clamp pinch bolts and leave the bottom pinch bolts tight.
Crack the cap loose. Remove the fork and service.
After servicing install the fork leg and torque the lower triple clamp pinch bolts. Torque the fork cap and then torque the upper pinch bolts.
The upper triple clamp pinch's the fork leg cap enough that it will not come loose. I leave my fork caps just snug.
bkoz is offline   Reply With Quote
Old 02-17-2014, 01:51 PM   #5659
bkoz
bkoz's Avatar
Oddometer: 324
Guys,
Need some tips on building a good, soft, plush suspension for my '10 Six Days.
Weight 240 nakid (big 6'5 guy). Big heavy 4.5 gallon tank. Otherwise, stock...
I'm on .46 springs with 5 weight oil, I think 110mm oil level? Small bump compliance is awesome. I'm just bottoming out and it's dropping a little too much versus my properly setup rear.
I still want small bump compliance but slightly more resistance and/or load carrying up front.
I'm thinking:
.48 or .50 fork springs, and then maybe a 10 weight oil??
Any other suggestions / tips?
Yes, for sure on the fork springs, probably the .50's.
As a bandaid until the springs come try adding more oil. Try 105mm and if that's not enough go to 100mm.
I would stay away from the heavier weight oil on these forks. The valving ports are tiny and increasing the oil weight may kill your small bump performance.
Heavy oil works great on damper rod forks but I believe that 5w is best on the cartridge style.
If you can't achieve what you want with the right fork springs and experimenting with oil heights its time to shuffle shims. That is the stage I am at with my fork.
Old 02-17-2014, 04:56 PM   #5660
steveWFL
steveWFL's Avatar
Oddometer: 1,344
KTM is done!
Well ok, a bike is never "done"
I'll always add to it, but at least it's ready for Moab, Death Valley, Mohave, and Baja. Then Blue Ridge/TAT this summer.
I'm forgetting stuff, but here's whats I recall I've done thus far
stator upgraded, converted to DC rectifier (for heated gear, auxiliary night lighting, fan, etc), radiator thermostat and OEM fan, 6.3 gal acerbis tank, Spot Satellite Locator Gen3, Promoto billet kickstand, "stevewfl" tugger strap, Scott's damper/billet submount, ironman sprockets - 14/49 gear ratio, KTM hardparts skidplate, wired (heated gear, tire pump, USB, GPS, Android), SeatConcepts seat, HDB handguards, mirrors, billet topmount bar with RAM and electrical switches, TM KTM chainguard, grips, headlight upgrade, Giant Loop luggage. I also opened it up and checked valve lash clearances. These silver Excel rims are the "spare" set.
Teressa is trying to turn me into a KTM fan-boi! Some of the Valentine's Day gifts
My usual outtake, the light upfront is ProFoto brand, there is another light hidden behind the bike firing into the wall for the bright contrast in the shots
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 02-17-2014, 05:56 PM   #5661
WVa Dualsport
WVa Dualsport's Avatar
Oddometer: 419
Originally Posted by Hank.SD View Post
What kind of a bracket arrangement do you have going on for both master cylinders? It looks pretty slick.
I took an old bark buster mount for 7/8th bars, reshaped it a little, and welded a 1 1/8 long section of (old, bent) handle bar to it. I got the initial idea from a thread over on KTMTalk. Works like a charm.
If you need more info I can take better pics.
2010 450 EXC
2012 DL1000 V-Strom
WVa Dualsport is offline   Reply With Quote
Old 02-17-2014, 06:34 PM   #5662
Hank.SD
Jet Measurer
Hank.SD's Avatar
Oddometer: 1,285
No, that's perfect thanks. I had a very similar idea using a 7/8" clamp collar, a short arm and another piece of 7/8" tubing.. A little extra real estate for all the crap we end up with on our bars.
Hank.SD is offline   Reply With Quote
Old 02-17-2014, 09:57 PM   #5663
neduro OP
Addict
neduro's Avatar
Oddometer: 11,974
I vote heavily against 10 weight oil, it will ruin small bump compliance. Definite loser in my opinion.
Springs- I'm guessing .50 or .52, depending on what tank you run, etc.
As for air gap, you need to think of it as a second spring. The metal spring is a linear curve where for every additional unit of force, you get an additional unit of movement. The air above the oil is a squared function, meaning that for every additional unit of movement, you get a squared unit of resistance to the next movement. So, it is very progressive and an excellent way to manage bottoming (and an excellent way to create midstroke harshness if you get it ramping up too soon).
If it were me, I'd start with more spring rather than less, and more air gap, rather than less. You can add more oil easily, through the air bleed hole, until you manage bottoming.
Two other notes: 1) it's easy to focus on bottoming as a problem, but to my way of thinking, it's better to set a bike up plush, and stay on the throttle through the 95% of trail situations that are choppy, and then slow down or change line for the 5% where you'll bottom, than it is to set a bike up stiff to manage that 5%, and have to deal with deflection and instability through the rest. 2) Do some structured testing. Set up a little track that has consistent obstacles you can hit repeatedly, and then make changes to geometry, clicker position, and even oil height until you understand the effects of the changes you make.
SPAM: I wrote a book about this, and in my admittedly biased opinion, it does a pretty good job of laying out the fundamentals and how to test for improvement.
Only one thing is certain, suspension is complex and difficult to understand, and if you don't take a structured approach, you'll go in circles!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 02-17-2014, 10:05 PM   #5664
trailjammer
trailjammer's Avatar
Oddometer: 369
Great pictures of your 530 SteveWFL! That bike is clean! You could eat off it! Check out Trailjammer Designs Case Savers in the vendor thread before all your big trips. Get some protection on that case. Great V-day gifts too. :)
TRAILJAMMER DESIGNS -KTM/Berg/YAMAHA PROTECTION! www.facebook.com/trailjammer408
www.trailjammerdesigns.com
trailjammer is offline   Reply With Quote
Old 02-17-2014, 10:07 PM   #5665
dieselcruiserhead
Oddometer: 1,452
Has anyone run the 518 kit on their 450? I hydrolocked on Saturday with a river crossing gone bad, checked tonight on why its having trouble holding an idel and looks like I lost my ring seal. Thinking about going up to 518 while I'm at it.. Folks rant and rave about them supposedly, also supposedly revs much faster than the 530s (510cc) with the shorter stroke of the 08+ 450s.. There are times I love the 450 and times I really miss the old super torquey 02 510. Thinking this 518 will be a good compromise, possibly..
dieselcruiserhead screwed with this post 02-17-2014 at 10:20 PM
dieselcruiserhead is offline   Reply With Quote
Old 02-17-2014, 10:19 PM   #5666
dieselcruiserhead
Oddometer: 1,452
thx for the advice, appreciated... It will be the .50 springs and I'll continue with 5 weight. With the .46 right now it is close and super plush. Exactly what you're recommending is what I have been doing. It is just that 5% that is affecting it and it's a little squirrely versus the old bike from a little too much softness up front...
Old 02-18-2014, 05:11 AM   #5667
davesupreme
grand poobah
Oddometer: 1,565
there's probably some stuff on it around here someplace, but the fork oil weight/viscosity isn't like it is for SAE oils for engines... 5wt doesn't really mean much, cause the manufacturerererere's... can call it pretty much anything they want... google it and you'll find some tables where the oil is actually tested at temperatures, and then make a decision....
alotta tuners seem to use the Maxima racing 5wt, and it's pretty cheap... I changed from that to the Silkolene 2.5wt RSF fluid, and I liked it, seemed smoother.... i'm too cheap to try the Racetech Super Slick stuff, but I might next time....
davesupreme is offline   Reply With Quote
Old 02-18-2014, 05:39 AM   #5668
Bungholio
Bungholio's Avatar
Oddometer: 727
My suspension guy told me if you're not bottoming occasionally you're not using all the suspension and it is not set correctly for you. Of course if you merely putter down gravel roads, that's not likely to happen.
And by occasionally I think he means only the most extreme landings/hits, maybe once or twice an outing.
Bungholio screwed with this post 02-18-2014 at 10:38 PM
Bungholio is online now   Reply With Quote
Old 02-18-2014, 05:51 AM   #5669
davesupreme
grand poobah
Oddometer: 1,565
i'm callin' bullhokkey on that one!... front suspension is about geometry.... you get really soft in front, then do a buncha sand whoops... see what happens...
Old 02-18-2014, 06:55 AM   #5670
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,800
Eek Wellllllllllllllll............
All this talk about 10w oil has me doubting myself but I'm glad it opened up the discussion. You guys have the experience so it seems I've probably made a mistake. It's done now so I'll give it a try but if I'm not happy with where I'm at, it'll be the first thing I'll change. The front fork spring have been change to .50 and the rear spring is a 9.6. with my weight clothed and hauling what I normally do on day rides I estimate the weight I'm trying to tune for to be in the 300-310lb range. Springs are done so the rest is just tuning to that weight and the riding I do, it's an ongoing proceedure.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Times are GMT -7.   It's 10:18 PM.
