Old 10-30-2010, 01:37 PM   #736
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,090
Originally Posted by FlyingDutchman
Hodakaguy, how durable has the 8" light been? Can you swap the stocker back on for gnarly rides? I'm in the east and would love that light but ithink it would get destroyed the way I ride ,,,er, fall I guess
It's very durable, I use it for our long distance desert trips as well as on tight single track. The bike has been over on its side numerous times with no damage to the light. When you clean up the wiring to use this light you could make a pigtail where the stock light unit would plug back in making a quick change setup back to the stock unit. I just run this unit all the Time. I have a buddy that uses the same light on his 530 and he's never managed to damage it either....knock on wood
Here's a link to the thread showing how I dealt will all the wiring behind the stock light. http://www.advrider.com/forums/showt...ight=hodakaguy
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 10-30-2010, 02:23 PM   #737
osteo
Motion is Life
osteo's Avatar
Oddometer: 1,856
The PMXTECH is much better than stock that is for sure, but still not great. I had it for the P2D in 2008 and realized it is still way under powered for any kind of use that needs to see anything. if you purchase that bulb from a dealer it comes with a different bulb housing that withstands the heat. The new bracket (not really a bracket, but the black piece of plastic the bulb mounts to) is a fibrous grey plastic.
Regardless nothing compared to the Trail Tech X2's or that monster 8" Hodakaguy has!
Careful with the 8" Dutchman, pretty sure it is not street legal up here even though lots of guys have used them... but then again, I'm sure half the lights on vehicles these days are probably illegal.
D
"If it is small enough to eat in a single meal, don't worry about it, hit it!. If it is too large to eat in one sitting, get the hell away from it!" Jack Splash commenting on animals on the trail.
Rally Connex Adventures
Off-Road Adventures
Make It Stick Media
Adventure Has No Destination
08' KTM 450 EXC - The Half Beast -
04' Yamaha TTR250 (for the wife)
osteo is offline   Reply With Quote
Old 10-30-2010, 03:07 PM   #738
LukasM
Oddometer: 5,385
Originally Posted by osteo
When I ordered my fan for some reason the mounting bracket did not arrive.. so I made my own bracket as well. The fan sits pretty much on the rad, but I have not had any issues and give a fair bit more clearance for the tank.
D
Thanks. I just heard from a guy on KTMtalk that the fan itself might actually be the same, so I am going to take mine apart and try again. Hopefully it will give me the bit more clearance that I need.
Originally Posted by neduro
Yes, moved the whole rad up by taking plates off the standoffs on the frame, and relocating forward more at the bottom.
Steering lock was the weak point, it was definitely ducati-esque!
Right now it seems like I might be able keep the stock steering angle as my Mecasystem front fairing brackets are pretty narrow where the triples are - I assume that is the case with your new rally bike? Would be nice for tighter tracks and turning around.
Originally Posted by Brown Dog
Anybody Running a Cush Drive Rear Hub ??
I didnt on my 525 & was told this was why I ripped 4th gear out of the Tranny
I do know it makes the bike mucho smoother & helps chain slap
They do add quite a bit of weight but the 525 tends to eat countershafts and break hubs if you run on the pavement without. On the 450/530 XC4 it's not as critical since it has a dampened clutch hub.
D
If you want it to be street legal I would get the version with the high/low switchable H4 bulb in the 7" Hella housing, same Trailtech frame. Boatman on this forum came up with it, and Cyclops Motorsports now carries it. Add a cheap HID conversion kit (not legal) and you'll have a TON of light.
http://www.cyclopsadventuresports.co...products&id=94
Old 10-31-2010, 10:42 AM   #739
Bora20
Oddometer: 854
Leftover 530 EXC Champion Edition waiting for me in a crate...
...subscribed
Dan
2010 KTM 530 EXC Champion Edition - factory street legal
Pix - http://Bora20.smugmug.com/
Bora20 is offline   Reply With Quote
Old 10-31-2010, 06:25 PM   #740
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,940
Neduro . . . or anyone,
How's the Baja Designs Headlamp assy with H-4 bulb working
What watt bulb are you using in it.
Brown Dog screwed with this post 11-01-2010 at 02:10 PM
Brown Dog is offline   Reply With Quote
Old 10-31-2010, 07:10 PM   #741
Hodakaguy
Hodakaguy's Avatar
Oddometer: 2,090
...subscribed
Welcome Aboard, you'll love it!
Hodakaguy
Old 11-02-2010, 12:17 PM   #742
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
I am looking at a new 2009 530exc left over. What should it be worth?
Opinions are like butt holes. Everyone has one and there's is the only one that doesn't stink.
Xmoto is offline   Reply With Quote
Old 11-02-2010, 01:09 PM   #743
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,548
$7000.00 to $7500.00 would be a good price IMO.
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is offline   Reply With Quote
Old 11-02-2010, 01:31 PM   #744
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
Dealer wanted 7999. I offered 7000 but they wouldn't take it.
Old 11-03-2010, 01:42 PM   #745
Hockeygod
Hockeygod's Avatar
Oddometer: 740
What is it worth? It is worth whatever you are willing to spend and whatever they are willing to let it go for... your job is to try to keep the lines of communication going to help you find that magic number (or price range.)
Did you guys negotiate a bit? I.E. when you offered them $7k, did they come back with something under $8000 or did they (or you) quit negotiating?
2007 KTM 640 Adventure
2001 KX 100
1989 KDX 200
Various mountain and road bikes
No his mind is not for rent
To any god or government
Always hopeful, yet discontent
He knows changes aren't permanent
But change is...
Hockeygod is offline   Reply With Quote
Old 11-03-2010, 01:50 PM   #746
Xmoto
Death Race
Xmoto's Avatar
Oddometer: 2,107
They didn't want to talk anymore. I am going to look for a used one.
Old 11-03-2010, 02:27 PM   #747
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,548
You can get a 2010 Husaberg for $7999.00 from KTM-Parts.com. That would make a sweet Dual Sport bike.
Old 11-03-2010, 02:54 PM   #748
tahoeacr
tahoeacr's Avatar
Oddometer: 2,210
or 2009 for 5,995.00
tahoeacr is offline   Reply With Quote
Old 11-03-2010, 03:42 PM   #749
husky123
Oddometer: 1,454
Holy cow that is a good deal!
husky123 is offline   Reply With Quote
Old 11-03-2010, 05:06 PM   #750
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 836
You can get a KLR from me for 2K.
FlyingDutchman is offline   Reply With Quote
Times are GMT -7.   It's 04:01 AM.
