11-15-2010, 07:16 AM
#796 |
Tuareg 2013
Oddometer: 11,342
Golden Spectro 20w-50 here, both sides. It's half the price of Motorex at my shop, and the clutch seems to have better feel.
For Sale: FJ60, Defender 90, Superduke Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible. Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills. |
11-15-2010, 07:18 AM
#797 |
Tuareg 2013
Oddometer: 11,342
Oh, and meant to do a quick update on the rebuild as well. Bike runs great as ever, and a couple weeks ago I did a fun 500 mile trip, documented here:
Worth checking out for the pictures that I did NOT take! Anyway, 500 miles later, the oil level did not measurably change. I feel confident in saying that things are sorted out.
11-15-2010, 09:31 AM
#798 |
North Georgia Dual Sportr
Oddometer: 1,695
I've ran Honda HP4 20w50 [gold bottle] in all 5 of my KTM's.
It meets the JASO T-903-MA specs
2008 KTM 690 ENDURO ![]() http://www.advrider.com/forums/showp...postcount=1784 http://www.advrider.com/forums/showp...postcount=8594 http://advrider.com/forums/showpost....&postcount=683http://www.youtube.com/watch?v=gnFCdoc_IDE Brown Dog screwed with this post 11-15-2010 at 05:01 PM |
11-16-2010, 11:05 AM
#799 |
Keep On Keeping On!
Oddometer: 1,856
winter jetting
Any of you guys ride on the ice? What do you rejet to for the winter.
“Do not be afraid; only believe.” |
11-19-2010, 05:48 AM
#800 |
Oddometer: 1,695
Will the Dampened Wheel assembly from a 625/640 bolt right on the 530
![]() keeping the brake rotor & sprocket aligned up ?? I'm thinking it will even though the 625/640 is right side drive with a wider rim.
2008 KTM 690 ENDURO ![]() http://www.advrider.com/forums/showp...postcount=1784 http://www.advrider.com/forums/showp...postcount=8594 http://advrider.com/forums/showpost....&postcount=683http://www.youtube.com/watch?v=gnFCdoc_IDE |
11-19-2010, 06:15 AM
#801 | |
Oddometer: 4,923
690 rear hubs will NOT fit, they are wider.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
11-19-2010, 06:49 AM
#802 |
Rally On
Oddometer: 4,583
200 hours on my '09.
It was consuming some oil, but nothing critical. Valves still in spec. Valve guide seals were on tight. Replaced anyway. Rings were needed, but not critically bad. All buttoned up and sounding nice. Love this bike! |
11-19-2010, 09:01 AM
#803 | |
Oddometer: 70
11-19-2010, 10:39 AM
#804 |
Oddometer: 1,695
Thanks guys for the wheel info.
I like the Cush Drive much better. Less chain slap, smoother & easier on the tranny for Dual Sporting
11-20-2010, 12:13 PM
#805 |
Oddometer: 1,860
Valve clearance question
Gents,
I checked my valve clearances today. Everything was within spec other than on the intake/near side. It was supposed to be between .1mm and .15mm. I could easily fit the .15mm in there and fairly easily fit the .17mm. My question is: Should I adjust this? Or is too loose still OK? My apologies if this seems like a bonehead question but I am new to valve checking. Checking the valves seems pretty easy, I will probably take it in to get adjusted. steve
04 CRF230F 06 CRF250x 08 KTM990 ADV/ABS Black 09 KTM 530 EXC |
11-20-2010, 12:24 PM
#806 |
Wanderer
Oddometer: 2,442
Too loose is better than too tight, but I'd probably shim it one step if you can fit a 0.17mm feeler in there.
If you can check them, you can shim them. It's only a few more bolts. Good writeup by an inmate here "Paochow". If you have a 530 you might have to modify one of the tank supports to remove the rockers. dc |
11-20-2010, 12:50 PM
#807 | |
Oddometer: 599
11-20-2010, 05:20 PM
#808 | |
Motion is Life
Oddometer: 1,856
D
"If it is small enough to eat in a single meal, don't worry about it, hit it!. If it is too large to eat in one sitting, get the hell away from it!" Jack Splash commenting on animals on the trail. Rally Connex Adventures Off-Road Adventures Make It Stick Media Adventure Has No Destination 08' KTM 450 EXC - The Half Beast - 04' Yamaha TTR250 (for the wife) |
11-20-2010, 06:07 PM
#809 |
Wanderer
Oddometer: 2,442
Hey Osteo - I was just thinking about you the other day, on that ride around algonquin - you had a set of the Wolfman enduro saddlebags and a little tail pack. I've been using the GL Coyote for the last couple of trips, but want to go back to a more traditional/modular/separated system.
Are you still using the little E-10 bags on your 450EXC and happy with them, or have you found a better/different solution? Thanks man! dc |
11-20-2010, 06:42 PM
#810 | |
Motion is Life
Oddometer: 1,856
a) the side packs moved around a bit - shifted to and fro no matter how tight I cinched them down. It was not enough to feel or notice during the ride, but I could tell as they wore away the decals I had on the side panels of the bike. I think they need a strap that straps it to the side panel vertically to keep everything tighter. I don't have a good side pic of my bike from the trip, this is the best I have: ![]() You can see how I cinched it down horizontally, but as I said I think vertically might be better. I do like it over-all though and would use it again. I also liked the multiple bags, you can separate stuff nicely. Oh - they are NOT waterproof, maybe water resistant for 3min in a good downpour but not waterproof, if you recall all that rain we had, all my crap got pretty much soaked if it wasn't in a plastic bag. D
