Old 11-21-2010, 11:51 AM   #811
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,596
I used the WM Enduro Saddlebags and Enduro Duffel for 1600 miles of the TAT. I had no issues with mine. I had them attached to a 690 Enduro. The 690 is wide in the rear, so maybe that helps. I added a layer of black vinyl graphic material I had laying around to prevent them rubbing my plastic. Like Osteo I only used them the one time. I had them pretty full as well. I kept the side bags attached and took the duffel into the hotel room at night. I like them.
I bought a Giant Loop as well from Trailtricks.It was customized for the 690, but I didn't care for the way it mounted. Javier had modified the bag to work on the 690. I ended up returning the bag. I was impressed with the build quality of the GL bag though. It just didn't work out on the 690, which is an odd bike in some ways.
2010 KTM 530 XC-W / 2009 KTM 950SE / 2005.5 KTM 950 ADV (aka the dirt Harley)
“Anyone who believes in indefinite growth in anything physical, on a physically finite planet, is either mad or an economist.” -- Kenneth E. Boulding
bigborefan is offline   Reply With Quote
Old 11-21-2010, 04:44 PM   #812
Brown Dog
North Georgia Dual Sportr
Brown Dog's Avatar
Oddometer: 1,943
Originally Posted by miksu
I've been using a borrowed 640 wheel on my rfs and it is identical to the current cush hub ...
Does the cush drive hub make your bike smoother & less chain slap in your opinion ??
Brown Dog is offline   Reply With Quote
Old 11-21-2010, 11:22 PM   #813
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 843
Ehh Ned,
I notice you are using an FMF pipe now. Didn't you have the Akropovic on your previous bikes? Ever had the db's or hp measured? How do they compare duarability wise?
How do they compare? Could you post a review ..maybe compared to the uncorked stocker?
Thanks, in advance.
FlyingDutchman is offline   Reply With Quote
Old 11-21-2010, 11:41 PM   #814
Mil T
Mil T's Avatar
Oddometer: 624
Originally Posted by FlyingDutchman
Are you not worried that it's too slippery for the clutch? ( since Mobil 1 lacks the JASO-MA spec.)
...Not that I think the DOT spec'd. knobbies are any safer than the rest either
mobil 1 4-stroke racing oil 15-40 for me and it does meet the JASO-MA spec. It's on the bottle. $9.00 at Wally World Same with Castrol Racing 4-stroke oil.
Mil T
Iron Horse Cowboy
Mil T is offline   Reply With Quote
Old 11-22-2010, 02:03 AM   #815
LC8TY
must......find.......fuel
LC8TY's Avatar
Oddometer: 2,297
RAD cush hub, excel rim and stainless spokes on the rear of my 530 and from riding it I can't feel any difference. It does work though, there are wear marks on the hub (where the spokes are) from the sprocket bolts.
Some men like the fish'n,
Some men like the foul'n,
Some men like to hear........
to hear the cannonball a roar'n!
LC8TY is offline   Reply With Quote
Old 11-22-2010, 03:17 AM   #816
miksu
Oddometer: 70
How can you not notice the difference while riding? Although I have an RFS not 530, but I can ride two gears higher and still be smooth on pavement. I hate to ride without it because I have to rev the engine all the time to keep it smooth. Of course on dirt the difference is not that big bit still clearly noticeable. For example shifting without clutch is very easy with undamped hub because chain slaps around and pull is inconsistent while with the cush hub pull is so smooth gear won't "drop" without using clutch. That alone convinces me that cush hub does save transmission, chain, sprockets and everything.
miksu is offline   Reply With Quote
Old 11-22-2010, 10:57 AM   #817
Leverbender
Adventure Now
Oddometer: 37
Sicass turn signals
I put new sicass LED front turn signals on my EXC this past weekend. And replaced the little black box behind the headlight per instructions from the folks at 3Bros Racing. Now when I hit the turn signal switch - either left or right - all four (front & back) signals come on and blink.
I have flush mounted LEDs on the rear. And I tried the stock black box, but when I used that one they all just came on and stayed on (no blinking). With the stock fronts and LED rears, everything worked fine.
Anybody have any ideas?
Leverbender is offline   Reply With Quote
Old 11-22-2010, 11:39 AM   #818
GearedUp
GearedUp's Avatar
Oddometer: 828
If you have LED signals front and rear you need some diodes to isolate the indicator lamp. Sicass has an indicator wire kit for $6.98 that will fix this problem. Part # 22-299
08 KLR 650
10 KTM 530 EXC
14 KTM Adventure 1190R
GearedUp is offline   Reply With Quote
Old 11-22-2010, 11:46 AM   #819
Leverbender
Adventure Now
Oddometer: 37
Diodes
Thanks, Geared. I hate doing electrical work.
Old 11-23-2010, 01:15 PM   #820
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
Just a couple of fun shots from the weekend:
Loving this bike!
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 11-23-2010, 03:50 PM   #821
bigborefan
Making new friends
bigborefan's Avatar
Oddometer: 1,596
They always say it's steeper than it looks. I hope not, because that already looks vertical.
I am jealous of you Ned.
Old 11-23-2010, 06:37 PM   #822
Chowdown
Texas Aussie
Oddometer: 141
so if you had to choose Ned, 530exc or fe570 ?
Chowdown is offline   Reply With Quote
Old 11-23-2010, 06:45 PM   #823
neduro OP
Addict
neduro's Avatar
Oddometer: 11,957
530, no question.
Can't get comfortable on my FE450, not saying it's a bad bike but I'm struggling to find a balance between stability and agility, right now it's pretty anxious, hard to feel settled on.
Old 11-23-2010, 06:53 PM   #824
Brown Dog
Brown Dog's Avatar
Oddometer: 1,943
Originally Posted by neduro
530, no question . . .
I like the Extra 55 CC's of the Berg for Dual Sporting, BUT I just couldn't make myself buy one
because of the Prooven KTM Reliability & all of the bolt on goodies for it
Old 11-23-2010, 07:03 PM   #825
Brown Dog
Brown Dog's Avatar
Oddometer: 1,943
How many US $ Dollars
RAD cush hub, excel rim and stainless spokes on the rear of my 530 ...
Times are GMT -7.   It's 06:06 PM.
