Old 04-17-2011, 07:05 PM   #1441
5 speed
Oddometer: 950
Yea, I have a steering stabilizer,first one I have had and dont think I will ever have a bike without one. World of difference, especially in sand. Bike tracks straight even at 95mph. You should check the steering head bearings and if you have balanced your wheel with weights and are sure its true, i would also check the forks and make sure they are not binding in the triple clamps. You can do a search as I know I have read the process to properly torque them.
5 speed is offline   Reply With Quote
Old 04-17-2011, 10:25 PM   #1442
malcolmzilla
Oddometer: 60
Originally Posted by barrier View Post
Hey Malcolm, engine should go in from the right without any problem. Just remove the cam cover.
If you have any questions please just ask!
Regards, Barrie.
Thanks Barrie, I will give that a try .
Today I welded up a wheel truing stand and laced and trued the front AWD hub to the stock rim. Turned out not bad for my 1st attempt. I will start assembly this week.
malcolmzilla is offline   Reply With Quote
Old 04-18-2011, 01:34 PM   #1443
BeezaBoy
BeezaBoy's Avatar
Oddometer: 128
Fuel Tanks
Anyone know if there is any physical difference between the KTM hardparts 13L tank and the Acerbis branded 13L?
I know they are both made by Acerbis (I think I know anyway). I've always been into the "official" hardparts, but it's easier and less expensive for me to purchase the Acerbis one.
This is going on a '11 450 EXC.
Thanks, and sorry if this specifically has been posted before.
-Tom
BeezaBoy is offline   Reply With Quote
Old 04-18-2011, 01:38 PM   #1444
offrdr1975
offrdr1975's Avatar
Oddometer: 113
The only difference is the gas cap.
The only difference I am aware of is the gas cap. The hardparts tank uses the stock1/4 turn cap and the acerbis uses a screw on cap. I have the acerbis tank on my bike an am very happy with it.
I was going faster then I had ever went in my whole life, then I fell off.
offrdr1975 is offline   Reply With Quote
Old 04-18-2011, 03:54 PM   #1445
oinky1982
Oddometer: 23
NO I don't have stering stabilizer and no my wheel not been balance but on road is it ok the problem is only on not paved road
thanks for your help,
I've ride today and can't belive this things do wheely at 100km/h just turning the trottle
oinky1982 is offline   Reply With Quote
Old 04-18-2011, 05:32 PM   #1446
Visigothic
Visigothic's Avatar
Oddometer: 186
Husa 570 top on a KTM 530 lower
Does anyone know just for kicks if the Husa 570 top is the same as the hard parts 530 to 570 stroker it. Would they have the same compression , bore etc.?
Hence other than the different stuff you would have an equal performing bike.
Visigothic screwed with this post 04-18-2011 at 05:54 PM
Visigothic is offline   Reply With Quote
Old 04-18-2011, 09:01 PM   #1447
dirtdiver
Oddometer: 2,039
Is there much $$ + time involved to get the bike dialed in for a 210 pound rider? I like the stock handling but I am getting to the point where I often load the bike up to 210 pounds of payload.
in other words, if I change the springs will I need to change other bits to get the bike to handle like it does stock for a 170 pound rider? Or just springs?
Is this job do-able for a few hundred dollars or more like $1K? Assuming I pay for it to be done.
steve
04 CRF230F
08 KTM990 ADV/ABS Black
09 KTM 530 EXC
2014 KTM 500EXC
dirtdiver is online now   Reply With Quote
Old 04-18-2011, 09:07 PM   #1448
dirtdiver
Oddometer: 2,039
I was thinking about the BMW but now have kind of lost the enthusiasm. As my son pointed out: we really like the 530 + we already know the idiosyncrasies on the ktm's. It is fairly daunting to think of starting over on the learning curve of a new bike. Not learning to ride, rather the learning about the parts to replace, the parts to fix, the setup, the details of what works and what doesn't. I think we will hang loose and keep looking for another 530 to pop up. So, thanks for indulging me on this.
steve
Originally Posted by Country Doc View Post
It's a great bike, Steve. It has it's idiosyncracies like the KTM's, but has proven to be very reliable. Perhaps less of a "race weapon" than the KTM (although lots of races have been won on the 450), it angles slightly towards the longer distance/rally events perhaps rather than hard-core singletrack/endurocross/etc.
Lots of good info in the G450X thread here in Thumpers. I wouldn't hesitate to buy one if I was in the market for another four-stroke off-road bike.
dc
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Old 04-18-2011, 09:22 PM   #1449
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 870
Why can't you PM this?
steve
FlyingDutchman is online now   Reply With Quote
Old 04-18-2011, 09:53 PM   #1450
FlyingDutchman
Dirt Biker
Oddometer: 870
steve
I liked my stock suspension, and handling inspite of 270lb carcass. Just had the preload cranked by the dealer prior to delivery.
After 15hrs on it, I decided to spring my rear shock to my 270lb spec...their biggest straight rate spring. I raced it once and noticed the improvement in accelleration most. I took it to the air a bit for the first time, too. No bottoming in the back end.
After the race, I noticed that I had bottomed the fork, so I replaced the springs which I'd purchased but not installed. It improved the diving in the front when braking. Then I dialed in some recommended specs.
It's been great, especially at high speed. While a bit stiff in the slow, rooty stuff, the decrease in pogo effect when accellerating and braking is the most noticeable improvement.
So the EE springs set me back $250ish. 60 for a special wrenches...I installed them myself with the help of EE, Scott Rocher Sales and the internet. Six beers labour. Very cost effective modification.
While you are in the forks swap the fork oil too, but not necessary if you are careful.
They say suspension is the best mod you can do, and I agree.
I don't know about this valving stuff, so I stayed with stock for now. Maybe when the fork seals go or something...
FlyingDutchman screwed with this post 04-20-2011 at 11:39 AM
Old 04-19-2011, 10:41 AM   #1451
neduro OP
Addict
neduro's Avatar
Oddometer: 12,053
Generally speaking, changes in weight require changes in spring more so than damping. I think you'd want 48 or 50 fork springs, and an 8.0 rear spring, and that's about it, so call it $100 per end in springs and an hour of time to install them both.
Doubletake Mirrors- Folding D/S mirror that is both useful and indestructible.
Dual Sport Riding Techniques DVDs: Clear instructional DVDs to improve off-road skills.
neduro is offline   Reply With Quote
Old 04-20-2011, 02:03 PM   #1452
oinky1982
Oddometer: 23
Yes same part than the 570 husaberg, for performing don't know never try a husaberg, but I can tell, the 570 kit in the 530 it's......torque monster
Question everybody about exaust, I would like to upgrade it, I want some thing not noizy, and with performance ????? any sugestion
Old 04-20-2011, 03:41 PM   #1453
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,945
steve
+1
Money well spent!
I rode my 200 EXC for 3 yrs and only clicked the clickers. I'm probably 225+ w/ gear on.
I finally had Alex from Konflict Motorsports (inmate here, and specializes in KTMs) (shameless plug) re-spring for my weight, but I was too cheap to revalve at the same time. A couple rides later I decided to have him revalve because it was too harsh in the first part of the stroke, and was fatiguing me. Made a huge difference.
First Enduro of the year was on Sunday, and I would say that the suspension is the best part of the bike now.
I'm very happy with the suspension and the service! In my opinion it hepls to have someone that will work with you and listen to the type of riding you do.
You can go to all the suspension schools you want, but in the end a lot comes down to testing. I've observed re-valves, and its an Art, IHMO.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 04-20-2011, 03:49 PM   #1454
Navin
Navin's Avatar
Oddometer: 8,487
I just went from stock modded to a FMF Q4, revs out better, more top, no loss on bottom. Still quiet too, a little louder but not bad.
Navin is offline   Reply With Quote
Old 04-20-2011, 08:20 PM   #1455
dirtdiver
Oddometer: 2,039
Good to know, thanks! Thanks Ned too. A couple hundred $ is an easy fix.
steve
Originally Posted by NWBoarder View Post
+1
Money well spent!
04 CRF230F
09 KTM 530 EXC
2014 KTM 500EXC
Times are GMT -7.   It's 08:49 PM.
