Old 04-27-2011, 02:36 PM   #1471
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,898
That 500 is purdy, but if it is an EXC where are the mirrors and turn signals.
However I'm partial to the black frame, black forks of my 08.
We need more details. Maybe a new thread.
Turns out I like the rain, easier to Spin, Skid and Slide.
Log Riding 101
NWBoarder is offline   Reply With Quote
Old 04-27-2011, 02:41 PM   #1472
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,851
Don't get too excited...the link properties say it's a factory 350...just sayin'...
http://blogp3racing.com.br/wp-content/uploads/2010/11/350_f_exc_factory.jpg
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub is offline   Reply With Quote
Old 04-27-2011, 02:48 PM   #1473
malcolmzilla
Oddometer: 58
Thanks Barrie , removing the valve cover did the trick, a bit of wrestling but better than removing the transfer case!
malcolmzilla is online now   Reply With Quote
Old 04-27-2011, 02:49 PM   #1474
Bob599
Bob599
Bob599's Avatar
Oddometer: 285
Did a google search and Gear 4 Direct has pricing listed for the whole new EXC Range! I'm sure the previous post was just a joke but how nice would a 2quart oil capacity be!
125EXC.....5595
200EXC.....5795
250EXC.....6295
300EXC.....6495
250EXC-F...6795
350EXC-F...6895
450EXC-F...6995
500EXC-F...7095
2006 KTM 950 ADV
2011 KTM 530 EXC
Bob599 is online now   Reply With Quote
Old 04-27-2011, 03:26 PM   #1475
FlyingDutchman
Dirt Biker
FlyingDutchman's Avatar
Oddometer: 841
http://blogp3racing.com.br/wp-conten...xc_factory.jpg
That may be but the 500 exc will be here next year. Lots of info out there...Knighter is racing it.
Don't worry they will install those crappy mirrors at the dealer.
FlyingDutchman is offline   Reply With Quote
Old 04-27-2011, 03:46 PM   #1476
NWBoarder
Whitmeister
NWBoarder's Avatar
Oddometer: 1,898
Slightly Different topic:
My 2004 200 EXC has the old style (large) speedo with the Tripmaster bar mounted controls, and can display the Trip2 and Clock at the same time. This is very handy for timed enduros, because you can roll forward and back the odo in tenths.
I've searched, I've read through the manual, and this thread. Great stuff.
The manual shows how to change the display options, but it only seems to change the right half of the display. The speed is always present on the left half of the display. Did I miss something?
I would like to display the Clock and the Trip2 at the same time. I don't usually care about the speed.
Log Riding 101
Old 04-27-2011, 05:32 PM   #1477
Navin
Navin's Avatar
Oddometer: 7,840
Single sump, thinner engine. Probably FI. I'd not wait though, even now I'd run for a 530. Why waste time you could be riding and all the current bikes flaws are ironed out and/or easy to fix.
Navin is online now   Reply With Quote
Old 04-27-2011, 05:51 PM   #1478
Visigothic
Visigothic's Avatar
Oddometer: 185
Originally Posted by Visigothic View Post
If so I'll bet it has a 150w stator, redesigned case and single enlarged oil sump that holds 2.1 quarts of oil.
Yes it was a hinting joke to KTM , but a joke none the less.
My question is there really a 500exc coming?
I notice the bike in the photo has dual over head cams so shim under bucket, a real PITA to adj. Still has PDS shock system no link. Hmmmm? 350sxf link or 350exc no link.
Visigothic screwed with this post 04-27-2011 at 06:00 PM
Visigothic is offline   Reply With Quote
Old 04-27-2011, 05:56 PM   #1479
Navin
Navin's Avatar
Oddometer: 7,840
Thats not it but it (exc500) is currently running the WEC if I'm not mistaken. I've seen a few pics on other forums, different side case covers and smaller cases. Look for David Knight pics.
Old 04-27-2011, 06:04 PM   #1480
Visigothic
Visigothic's Avatar
Oddometer: 185
I find it odd that they didn't go the other way as in 570 exc like the HUSA but hey. Is it the same basic motor I wonder ? Maybe they got the bugs worked out of it. The different side cases may add more oil capacity who knows. Only idiot would lessen the oil capacity on a bike with too little already.
Visigothic screwed with this post 04-27-2011 at 06:17 PM
Old 04-27-2011, 06:08 PM   #1481
Navin
Navin's Avatar
Oddometer: 7,840
More than a few pics here:
http://www.knighter.net/index.php?op...ery&Itemid=400
Navin screwed with this post 04-27-2011 at 06:31 PM
Old 04-27-2011, 06:37 PM   #1482
Visigothic
Visigothic's Avatar
Oddometer: 185
New 500cc motor spied!
Yep new motor, look close at it, water pump clutch cover etc.. I'm guessing a single sump, notice how the bottom of the cases are level front to back unlike the xc-4 where the trans is higher than the power section. It still doesn't mean it holds much oil though. Just a hunchNew frame from the 350exc also. This looks like a lighter weight machine than the current 530. From the other photos it looks like it could be the same cylinder and head but the tank is in the view. I wonder if it has the Super reliable KTM EFI , looks like it might. 3 steps forward 4 steps back.
Visigothic screwed with this post 04-28-2011 at 11:32 AM
Old 04-28-2011, 06:49 AM   #1483
MarkFloden
DXB Buffoon, Qatar
MarkFloden's Avatar
Oddometer: 0
replacing countersprocket oil seal
Hi guys
Here is my problem:
2010 KTM530EXC leaking I think from the countershaft oil seal.
Only a little oil but still.
So I bought the parts, oil seal and o ring.
I have the sprocket and spacer off but my question is how do I remove the existing seal in the proper correct way. I tried to just lift it out but it looks like some force might be required in which case I want to make sure I am doing it right.
The new piece
The old piece that needs to be removed.
Any hints as to how to remove it?
My Current Rides:
KTM rides: 06 950SM, '10 530EXC, '10 690ER, '11 530EXC.
Buell and Harley rides: '06 XB12Ss, '10 1125r, '08 VRSCAW
MarkFloden is offline   Reply With Quote
Old 04-28-2011, 07:00 AM   #1484
Capp
Resident
Oddometer: 88
Get a seal puller, pops right out.....
2013 KTM 350 EXC-F
Capp is offline   Reply With Quote
Old 04-28-2011, 08:43 AM   #1485
MarkFloden
DXB Buffoon, Qatar
MarkFloden's Avatar
Oddometer: 0
Thanks so I checked online to see what these seal pullers were like. Turns out they look more like little claw hammers than what I expected them to look like (like a bearing puller). So it is kind of hard to get tools here, I realised that the torx keys I have would do that job and sure enough. Old seal out and new seal in. Thanks mate.
Cheers,
Mark
My Current Rides:
Times are GMT -7.   It's 12:01 PM.
