12-11-2008, 09:12 AM
#1501 | |
Fart Letter
Oddometer: 3,830
Now the race is on----the first to post a pic of it mounted. And then somebody run it out of gas to see just how far you can go. I'm going to try to run my stocker out of gas and see how far it will go---iffin' I can stand the cold weather---I got my plug installed for heated clothing----I'll see how the battery holds up. All my other bikes have a switch on the low beam so I can turn the headlight off if I want. I did this to the WR also--drilled a hole in the side of the plastic headlight housing and put a switch there. I"ve tapped in for my heated grips (haven't arrived yet) and my gps---so we'll see how the alternator and battery does with a load on it. My Husky only has a 230 watt alternator and I ran heated grips, heated vest, arm chaps and heated gloves with it with no problem. Of course I went to the battery for the heated clothing. For my heated grips and gps---I powered them off the same wire. I tapped into the hot wire going to the headlight switch. It is only hot when the bike is running---so if I leave my grips on they won't run the battery down. I use to run gp's to a tap that was hot all the time---not necessary now as my 276C has a rechargeable battery and will stay on. The headlight circuit has a 15 amp fuse and a wire big enough to support 15 amps. Figuring at 12 volts--the headlight will draw 5.4 amps on high beam---the heated grips draw 3 amps on high--the gps and tailight draw next to nothing---so I probably have about a 9 amp load on a 15 amp circuit---and if the volts go above 12 (which they will) I'll have even less. I'm goin' riding'---see if I can run the battery dead !!!
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" BigDogAdventures.com screwed with this post 12-11-2008 at 09:31 AM |
12-11-2008, 09:16 AM
#1502 | |
Oddometer: 407
12-11-2008, 09:18 AM
#1503 |
Oddometer: 407
te 610
bigdog,, you have to give us a take on what conditions you would rather be on the 610 vs the 250r. I see the 250r being about twice as reliable.. would you agree with that?
Thanks, |
12-11-2008, 11:26 AM
#1504 | |
Traffic target
Oddometer: 119
A riding trip is planned for next weekend, so I'll def be putting a 51t back on for that weekend. Gearing changes work for me b/c I truck my bike out the the dirt and back, so no compromises. Then I commute about 4 days a week, all fwy at 40 to 85mph, so the 13/43 works pretty well for that. I put the 14T front on for extended hwy trips. 300mi at 80mph with the 13/43 is very doable, but the 14t feels much easier on the bike. I don't mind the work, and I've got very little invested in parts. Long term, I want a second set of wheels, probably 17's for the street. Then dirt-only tires on the 18/21 with dirt-only gearing. |
12-11-2008, 12:08 PM
#1505 | |
Legend in his own mind
Oddometer: 1,623
Kawaskai Ninja 250 -- 67.5 miles Yamaha WR250R -- 69.1 miles Suzuki DRZ400SM -- 71.6 miles Honda 250 Rebel -- 80.7 miles The Yamaha had the most fuel sloshing around when it ran out. One bright fellow on this site speculated that the tank is deliberately shaped to keep some gas around the fuel pump for cooling. The DRZ was able to burn the whole gallon and leave the tank dry. Now that I looked that up I guess it doesn't have that much to do with seeing how far you can run on a full stock tank. By the way, BigDog, your posts with Gaspipe on the TAT are some of the best reading I've enjoyed on ADVrider, and I want you to know how much I appreciate all the work you guys did to chronicle that adventure in words and photographs. For those who missed it, Gaspipe rode a Honda XR650R and BigDog rode a Husqvarna TE610. It is a huge compliment to the WR250R that Mark has decided to add one to his stable.
Often wrong, but never in doubt. montesa_vr screwed with this post 12-11-2008 at 12:15 PM |
12-11-2008, 01:26 PM
#1506 |
Oddometer: 1,281
I don't buy that 69.1 mile figure for the WRR.
Yamaha factory specs show the stock tank with a 2.0 gal capacity. Personal experience this past weekend had mine going 78 miles between fill-ups per the onboard odometer and the reserve warning light never even lit up. Edit: Duh - if they only put 1.0 gals in a two gal tank maybe 69.1 MPH ain't too bad... |
12-11-2008, 02:35 PM
#1507 | |
Oddometer: 1,920
Take off the plastic on both sides, the seat, then the bolt at the top front of the tank, and the two bolts securing the rear of the tank to the rear subframe. Don't lose the little metal sleeves. The tank will lift up. Then you can disconnect the electrical connector to the fuel pump where it connects to the pump, and the fuel line - but disconnect the fuel line down at the top of the engine, where it connects to the metal fuel rail at the injector. Now you can lift tank, pump and all off the motorcycle. From underneath, the view from the bottom of the tank, the pump assembly looks like this: ![]() To remove the pump assembly from the tank, take off the big retaining ring. Then the whole thing just comes out. A pic of the pump assembly from the side - the larger vertical silver can is the pump itself, the smaller horizontal black and white plastic on top holds the regulator, and the tiny silver can is the low fuel sensor. The big flat bag on the left is the fuel filter. We doped this stuff out over on TT. ![]() There's nothing else in the tank. I don't know how they can drop "wings" down the sides with that pump where it is, and nothing else. The pump has no way to suck fuel up from lower than the pump base itself. But soon we will know for sure what they have come up with. /dh |
12-11-2008, 03:23 PM
#1508 | |
Bike-aholic
Oddometer: 2,060
And...keep thinking "Colorado 09" R² HF p.s. You're also delusional about "no farkles". $20 says you can't last 6 months pure stock! HighFive screwed with this post 12-11-2008 at 03:41 PM |
12-11-2008, 03:38 PM
#1509 | |
Bike-aholic
Oddometer: 2,060
Your plan sounds good....just keep some extra fuses (as always). I'm nervous about pulling from the headlight circuit cause I don't want any chance of blowing the headlight fuse (or worse). I've lost headlights on night rides twice! Its a MAJOR bummer!! So, I was thinking about tapping the hot lead from the key switch....what you think? HF
12-11-2008, 04:00 PM
#1510 | |
Fart Letter
Oddometer: 3,830
I'm guessing your right----I'm expecting to have no motor trouble for more than 40,000 miles--maybe way more. But nobody's done that----just what I feel. It just my gut feeling----the fit, finish and build quality of this thing is superb. I'm thinkin' it would be really rare circumstances I rather be on my 610---so rare I'm having a hard time coming up with some ???? Maybe passing semi's on the interstate ?????? Right now I'm thinking even tho at altitude the fuel injection will keep the jetting spot on---but there's still a lack of air and you will have a loss of power on any vehicle---except maybe a turbo that forces the air in. Loosing a little power on a 250 is not a good thing---but I will suffer thru that cause the dang thing shines so well everywhere else. Be interesting to see what it does at altitude---I've had horrible experiences at 13,000 ft. with carbed air cooled 4-strokes. I finally had to bring back a 400cc bike to climb Mt. Antero in Colorado----14,000 ft. If it hadn't been for gravity--my old XR250 would still be 3/4 the way up there
Mark Sampson Click here for BigDogs full length DVD movies http://bigdogadventures.com/Video.htm www.bigdogadventures.com Why in the heck did you buy a 250 ?? "Because they were all out of 175's" "The less the merrier" "I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens "The older I get--the bigger my rear sprocket gets" "It takes 12 HP to ride around the world--the rest is wheelspin" |
12-11-2008, 04:16 PM
#1511 |
Oddometer: 1,281
Last weekend on our DS ride down in Big Sur we had
altitude changes between sea level to 4000' up and down and the R²'s handled that without a hiccup. |
12-11-2008, 04:22 PM
#1512 | |
used to be -MiamiUly
Oddometer: 1,833
Fuel light comes on around 80- 88 miles into the tank. I did 106 miles on a tank- 26 of them were hard throttle on a dirt road, 60mph plus, some slower speeds through a flooded road, 50-70 mph on road/highway, maybe faster and some stop and go traffic thrown in. I really was hitting it hard from lights for the last several miles trying to go dry before stopping. Didn't stall out but when I gave in and fiiled it, the reciept said it took the full two gallons. So you could do better but that seems to be a realistic, mixed use, spirited riding low number for mpg. At no point was I trying to conserve gas to get a better number- just riding.
Okay it's a sportbike... but riding is not a sport, it's a necessity. Same goes for the Dual Sport.
12-11-2008, 04:42 PM
#1513 | |
Fart Letter
Oddometer: 3,830
12-11-2008, 07:30 PM
#1514 | |
Smiles when says dat
Oddometer: 12,701
And if I said I wasn't going to farkle it...I kinda meant the engine. I've got a list... I just have trepidation that I won't ride the thing enough. That'll hurt double. Meh, I'm just going to keep dreaming. It's keeping me going. I think the van is going to have to go out in the driveway.
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid |
12-11-2008, 07:50 PM
#1515 | |
Bouncing off Rocks!
Oddometer: 2,399
"If you're going through hell.......Keep going!" On Hiatus |
