06-18-2010, 08:19 AM
#15166 | |
Off the road again..
Oddometer: 2,130
On a somewhat related subject, some have mentioned an issue with stalling when pulling away when it's cold outside and on a bike that is not warmed up. Some thought it was the engine running rough because it was cold. I've never had that occur as a result of the engine stumbling because it's not warmed up, but only as result of the clutch plates being extremely grabby when it's cold outside (or the bike has sat for a while and not been ridden). When you start to let the clutch lever out to pull away, the plates don't slip as much as usual so the normal amount of throttle will not be sufficient to keep the bike from trying to stall since the plates grab all at once rather than gradually. The solution is to either let the bike warm up a bit longer (unnecessary, but makes it act more normal) or just be aware of it and be prepared to give it a little more gas and/or feather the clutch should the clutch plates grab too quick and you start to stall. After a couple start/stops and/or a little warmup time, the plates act normal and the grabby pull away disappears. Just thought I'd mention it.
For Sale: 2008 Suzuki VStrom DL650 in Bozeman, MT. |
06-18-2010, 08:27 AM
#15167 | |
Oddometer: 2,011
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold) Member AMA, NETRA, MVTR, CCCOFVT Stealth is good! Noise annoys! |
#15168 | |
Oddometer: 238
Has anyone priced a replacement seat to get a second pan? I don't want to completely give up my stock seat either. |
06-18-2010, 08:34 AM
#15169 | |
FunHog
Oddometer: 3,454
yes...
My book's website (Now Available) 2003 BMW F650 Dakar (Back from the Brink) 2003 Victory V92C + Velorex sidecar chassis + Harley sidecar body (Canine Chariot) ![]() 2010 WR250R (Twiggy)
06-18-2010, 09:32 AM
#15170 |
Goin' Somewhere
Oddometer: 1,267
Hey ....
I'm looked at the on-line OEM part diagrams over and over but I can figure out which diagram has the following part ... I'm looking for the white plastic loop that guides the top of the front brake line - it is mounted near the right side of the headlight .... Which OEM diagram has this part ?? Thanks ! ....
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - '09 DR650SE - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -- - '12 NC700X |
06-18-2010, 09:34 AM
#15171 | |
Amateur Explorer
Oddometer: 32
That is very informative and makes sense. On my ride in to work, I thought about the stalling issue. I came to a somewhat similar conclusion, but also thought about the fact that my bike sat around for many days, untouched. Blipping the throttle that early on may have asked for more fuel than was available, so the engine stalled.
I was only blipping it check the tension of the cables, but there is no reason I couldn't wait 30 seconds for the engine to warm up. I always warm my bikes up at least a minute while I put the rest of my gear on, it just makes me feel better inside to know that the oil is flowing before I get on the throttle ![]() Thanks for the info, Chadx. The cold morning clutch plate friction makes sense as well and would explain what I've been noticing. You're the man ![]() Quote:
06-18-2010, 10:00 AM
#15172 |
Navigate 2 Adventure
Oddometer: 2,106
Hey, that's DEEP
Heading out for a few rides in the next couple of weeks that will involve some DEEP stream crossings.......what do you guys/gals do to prepare besides carrying extra spark plugs?.......what do you do to prepare the bike besides applying liberal amounts of grease to seal the rim of the air filter, and liberal amounts of dielectric grease on all electrical components.
Just curious......that's all I've ever done in the past with my KTMs and I've been fine........
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
06-18-2010, 10:27 AM
#15173 | |
Oddometer: 177
Parts
Art |
06-18-2010, 10:59 AM
#15174 | |
Goin' Somewhere
Oddometer: 1,267
Originally Posted by GsVs
Hey .... I'm looked at the on-line OEM part diagrams over and over but I can figure out which diagram has the following part ... I'm looking for the white plastic loop that guides the top of the front brake line - it is mounted near the right side of the headlight .... Which OEM diagram has this part ?? Thanks ! .... shown in "front fork" Art Quote:
06-18-2010, 11:45 AM
#15175 | |
Adventuring Mystic
Oddometer: 1,070
06-18-2010, 12:03 PM
#15176 | |
Oddometer: 333
![]() They're blue, so they match the bike, and they have COOOOOKKKKIIIEEESSSS!!!!! Seriously though, ensure you have some silicone spray on your connections to keep out water and, if you're worried about mud building up, you can always spray a bit of PAM cooking oil onto the bike. It's light enough to come off with any decent wash job, but will stick well enough to keep most of the mud off. (yeah...it actually works well) Oh...and most importantly, never be the FIRST bike to take the crossing. let someone else go and see how deep the line is.
06-18-2010, 12:10 PM
#15177 | |
Oddometer: 2,106
06-18-2010, 01:11 PM
#15178 | |
Oddometer: 962
06-18-2010, 02:02 PM
#15179 |
Oddometer: 76
Wolfman Bags
Does Wolfman offer an immate discount?
Thanks,
Guns Are Cool! 2008 YAM WR250R-SOLD 2010 BMW F800GS Lava Orange |
06-18-2010, 03:47 PM
#15180 |
Adventuring Mystic
Oddometer: 1,070
nice cheeks
Anyone know what size Sweet Cheeks fit the stock seat best? Yes I can read the chart, but I'd rather hear it from someone using one on their WRR
