Old 12-14-2008, 08:20 PM   #1576
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,193
Originally Posted by YamWOW!
Here's some pictures of my latest farkles. Our friend Stuckinmud has a powdercoating setup so I decided to shoot some of the parts Yamaha Blue.
More mods (Pimpin) to come!
YamWOW!
Very nicely done YamWOW! Where are you in the PNW? That's a nice NW ADV sticker, is it possible to get one?
cyborg is offline   Reply With Quote
Old 12-14-2008, 08:49 PM   #1577
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Double Yam-Wow WOW! Very nice powder coat job. Pimp On!
HF
HighFive is offline   Reply With Quote
Old 12-15-2008, 12:48 AM   #1578
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,722
HF
Double +1. Tho, black..hard to resist black.
MoBill is offline   Reply With Quote
Old 12-15-2008, 05:41 AM   #1579
wide open
in second gear
wide open's Avatar
Oddometer: 356
Originally Posted by BigDogAdventures.com
---got on top of my favorite hill and got this sunset shot.
That one is definitely worth a thousand words!
Good news on the electrics, too. Gracias.
wide open is offline   Reply With Quote
Old 12-15-2008, 08:45 AM   #1580
Hodakaguy
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,108
Shoot me a PM and I'll email you the file, you can take it to any local sign shop and they can cut it for you. I have a graphics plotter but to get the two colors we have to cut two stickers, then re-align the parts all back up. A little labor intensive. They should be real cheap to have cut.
Thanks,
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is offline   Reply With Quote
Old 12-15-2008, 08:32 PM   #1581
zrider
zrider's Avatar
Oddometer: 67
I was thinking the same thing!.....
Zac
Funs Starting Again!!!
WR250R, TE510, 90 OW02, R1, 97 Cherokee
86 FJ600, 87 FZR1000, 88 OW01,77 CCM 550 3speed, 78 CR250, 75 Husky 360WR, 76 CCM 610, Triumph Tiger Cub 200
75 Pursang 250, Greeves, 74 CR125, RD360, CT175, Hodaka, Honda SL90
zrider is offline   Reply With Quote
Old 12-16-2008, 02:03 AM   #1582
FOCKER
Northwest Adventure Rider
FOCKER's Avatar
Oddometer: 154
Some of you Northwesterners might like this one as well. It's the 1st one I created.
You won't want to make it any smaller than 6" wide.
Click for larger image.
FOCKER is offline   Reply With Quote
Old 12-16-2008, 09:10 AM   #1583
Strog
Geek on two wheels
Strog's Avatar
Oddometer: 406
I ran this through a vector program to clean up the aliasing (aka jagged edges) and saved it as an eps file. An eps file can be resized and look the same. A lot of vinyl cutters can take this as an input too.
nw03di3.eps
Here's a preview without the jagged edges:
(not bad for a techie but maybe a graphics guy could clean it up more )
Dale S.
Strog is offline   Reply With Quote
Old 12-16-2008, 09:15 AM   #1584
MoBill
MoBill's Avatar
Oddometer: 13,722
Keeeewl. Want. NJ Want.
Old 12-16-2008, 09:36 AM   #1585
cyborg
cyborg's Avatar
Oddometer: 5,193
Thanks,
Hodakaguy
PM sent
Old 12-16-2008, 10:02 AM   #1586
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,728
Highfive - Sound Test Results
Well, the howling wind finally died last night and I was able to complete my sound measurements this morning. By the way, I'm not sure how the rest of the country faired, but some kind of double bad Northern blew through Oklahoma like a freight train. Sunday afternoon it was a balmy 76 degrees, then 6 hours later it was 25 degrees! Anyway, I digress....
For you Technomaniacs, I followed the sound testing procedure covered in this link: http://www.thumperfaq.com/sound.htm
Well, as best I could anyway. Kind of hard to do it perfectly without a tachometer. Here's a photo of my sound meter in action, which anyone can buy from Radio Shack. Its an affordable, accurate unit. I've had lots of practice with it as the Sound Engineer at my Church. It works!
I don't know if I was below, at, or above the rpm for 1/2 peak power. Don't really care. Who knows how the manufacturers actually rate their products. Since I didn't have a Tach on Rē, I had to devise a plan for consistency to easily apply to each bike. So, while the actual measured numbers may be different than manufacture ratings....or even some official certified field test....I think they are decent comparisons between each bike.
I measured sound at the following points:
1) Idle
2) 1/4 throttle
3) 1/2 throttle
No, I didn't get all scientific and physically measure/mark these exact points on the throttle for each bike and hold it there perfectly. I just turned it to where I felt was right. If you want it better, do it yourself!
Drum Roll........here are my results:
Pipe- Idle- 1/4- 1/2
Stock w/ SA- 90- 103- 105
Stock w/ Graves- 93- 105- 110
Powerbomb/Q4- 91- 104- 107
KLX250 w/ Q2- 94- 99- 107
Interesting results on paper. Everyone knows the sound of the stock pipe. It is definitely more quiet to the ear than the Q4, but actually produces similar measurements. At least not as far off as you'd think. The differences in my numbers could easily be related to throttle position...due to my unscientific method.
I can tell you the sound of the Q4 is definitely different. The Graves Insert and the Q4 both produce a deeper tone of sound. Maybe that is what we usually interpret as being "louder". I know that I felt I could sneak around in stealth mode with the stock pipe & can. But I do not think that I could go undetected with the Q4. Maybe its all in my mind while I'm sitting on the saddle and not such a big issue from a distance. I donno.
I do know Zadok's Powercore seems louder than my Q4. But, it was too windy to test his the other day. We'll post that result later....
HF
Old 12-16-2008, 10:31 AM   #1587
scottmac
scottmac's Avatar
Oddometer: 1,621
Thanks for the comparison HF.
Had a feeling a DB test would show that the Q4 is
really not that loud - just more of a different
pitch/frequency than the stocker.
FMF rates it as 92db in their description.
scottmac is online now   Reply With Quote
Old 12-16-2008, 11:35 AM   #1588
FIDOLLAZ
Dirty D
FIDOLLAZ's Avatar
Oddometer: 744
I don't know how accurate that could be. In a season of AMA Db testing I have yet to test a MXer (with any of the thundering exhausts from FMF, Pro Cir, WB, etc.), at higher than 102 Db at 50% max RPM.
For comparisons sake, AMA MX sound at 50% max RPM is now 96 Db. =/-1. No way a stock or Q4 piped bike is near/over 100 Db!!! The Q4s we tested were all at or below 92 Db, 20" from tip of muffler.
FIDOLLAZ screwed with this post 12-16-2008 at 11:46 AM
FIDOLLAZ is offline   Reply With Quote
Old 12-16-2008, 12:39 PM   #1589
FOCKER
FOCKER's Avatar
Oddometer: 154
Actually that's part of the cutting process. When you're ready to cut/plot the image it's vectorized first. Also the image is very large...When scaled down for actual printing there no concern regarding jagged edges (at least it hasn't been for this particular graphic).
Old 12-16-2008, 03:58 PM   #1590
gordo5
Roadkill
gordo5's Avatar
Oddometer: 538
Guess which wannabe lurker (well, mostly lurker) has finally joined the club.....
Just before winter can be a good time to find some deals. This one was a Yamaha demo bike that was on loan to a local trail riders organization. Way cheaper than list, a few nice add-ons and a 3/4 warranty to boot!
Sure is gonna make for a long winter though..
HF, I don't care how scientific or accurate your tests are, it's the deltas that are interesting. Looks like the Q4/powerbomb combo does pretty well compared to stock - looking forward to hearing your general impression of sound levels once you've had a chance to live with it a bit. btw, thanks for your comments on the stabalizer... food for thought.
gordo5 is offline   Reply With Quote
Times are GMT -7.   It's 01:35 AM.
