Old 08-14-2010, 12:55 PM   #16396
Chadx
my toot toot
Chadx's Avatar
Oddometer: 2,169
Originally Posted by SuperSize
I picked up a left over 07, build 3/07 and my pump failed with only a 100 miles.
A U.S. '07 WR250R? That would be quite the unique beast. Tell us more...
Off the road again...just can't wait to get off the road again.
The life I love is making roost with my friends.
Chadx is offline   Reply With Quote
Old 08-14-2010, 04:08 PM   #16397
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,829
Got me worried...
Mine was built 5/08. It is about as hot as it gets here and I am planning to go on a pretty remote ride tomorrow... Haven't had a problem yet...
Is there a list somewhere of the failed pump build dates. My ailing memory seems to think it was early 08 and mostly Feb and March build dates... have there been any May 08 build date failures reported?
Mr. Fisherman is offline   Reply With Quote
Old 08-14-2010, 04:47 PM   #16398
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
Mine is 1/08, 5,300ish miles on it, it's 95+ here and ran from 9am till 4pm today, no issues at all since I got it first of Sept. 09. I'm running Safari tank. I'm hoping mine doesn't fail ... in Idaho one of the guys had a 2/08 WR pump fail, we were running in thick woods 1st gear for miles and he turned the key, nothing....
Waited for a bit, then started up...it never died while running, just if he killed it and it was hot & wouldn't start or prime. Bad thing is he got it replaced from a local Yamaha dealer in Idaho, but the pump was off a 2/08 bike too
Do we know what other Yammy's use this same/similar pump? And the new pumps look the same visually?
Anyone get theirs replaced under warranty or extended warranty?
Yamaha needs to make this right...
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 08-14-2010, 05:23 PM   #16399
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,954
Anyone hear of an 1/08 fail? That's what i got serial number 00000054 but i'm in canada. I don't recall seeing an 01 build month failure. Seems to be in the 1500's and month 2 to 4-5?
If you think adventure is dangerous, try routine; it is lethal. (Coelho)
Attico is online now   Reply With Quote
Old 08-14-2010, 06:00 PM   #16400
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,427
Dingweed is dead in the water an hour from home with fuel pump problems. Mrs. Weed is on the way with the rescue trailer.
The old WR is starting to look like a troublemaker on the road. He and BigDog had gas/fuel issues on their trip.
emerson.biguns is offline   Reply With Quote
Old 08-14-2010, 06:17 PM   #16401
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,259
Plus a fried clutch due to the mud in Arizona.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 08-14-2010, 06:28 PM   #16402
tremor38
tremor38's Avatar
Oddometer: 1,469
They are having the darndest luck, arent't they? Maybe this will change Big Dog's opinion of the WRR from untouchably perfect to 'darn good dual sport bike.' Prolly the best 250cc dual sport when you look at the big picture. It just bothers me when people get unrealistic.
tremor38 is offline   Reply With Quote
Old 08-14-2010, 06:39 PM   #16403
jimrobinette
Oddometer: 379
Fuel pump failure timing?
Doesn't is seem like the fuel pumps have been failing at an alarming rate the last month? I guess it is all heat related, with July/Aug the time we have seen the recent rash. Was there such a rash last summer?
jimrobinette is offline   Reply With Quote
Old 08-14-2010, 06:56 PM   #16404
Mr.Metal
Adventure hungry
Mr.Metal's Avatar
Oddometer: 313
Bad luck for sure, but no bike is perfect. Let's not forget they are taking a very long and very grueling trip. Failure can occur to anyone at any point, but putting heavy stress on parts can speed up those problems. The problems they've been having seem well-known or at least not shocking. I think it could be way worse.
2015 KTM 1190 Adventure R a.k.a. The Austrian Beast
2009 Aprilia Tuono 1000R a.k.a. Silver Thunder
Mr.Metal is offline   Reply With Quote
Old 08-14-2010, 07:55 PM   #16405
emerson.biguns
Oddometer: 10,427
Just from a quick chat with Scott (Dingweed) after I saw his SPoT stop moving, he mentioned that he and Mark had identical problems within 10 miles of each other after a fill up and headed south near Hell's Canyon. Scott noticed some relief after after using an ethanol treatment. So, the initial thought was gas problems. Scott noticed increased problems/symptoms the farther south he got. I'll let them comment on all the details, but from the recent posts here and their experience, it sounds like maybe a combo of gas(ethanol) and heat cause premature failure?
Scott also mentioned a change in the "prime" sound of the fuel pump on key turn before starting.
Come to think of it, they both have Safari tanks. Anyone with the "telltale" failure that is still using a stock tank?
Old 08-14-2010, 08:31 PM   #16406
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,741
Many folks with stock tank have the same issue. First I heard of it was all on stock bikes..
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Old 08-14-2010, 11:32 PM   #16407
scottmac
scottmac's Avatar
Oddometer: 1,813
I've got a 2/08 vin with 12,000+ miles on the stock fuel pump.
And it's been sitting in a Safari tank for the past year, one of the first
Safaris delivered.
My guess is it's a combination of things. How often have you ran the pump
completely dry? Heat and the fuel blend you're running.
I just read a ride report where a KTM owner up in Canada went through
six fuel pumps in a couple of weeks of riding so if the WRR can get by with
one swap I'm stoked.
scottmac is online now   Reply With Quote
Old 08-15-2010, 01:47 AM   #16408
edteamslr
edteamslr's Avatar
Oddometer: 198
Canadian Import in the UK
Mine is 1/08 0041. Only 2,000miles so far and slightly worried. It doesn't get very hot here but I'm taking it to Russia next year so it looks like I'll have to find space to add a fuel pump to my luggage!
edteamslr is offline   Reply With Quote
Old 08-15-2010, 04:58 AM   #16409
Teep
Oddometer: 295
I have a 1/08 with 7000 miles and so far so good. It's been hot here for the last month. I fuel up as soon as the light comes on.
Garry
Teep is offline   Reply With Quote
Old 08-15-2010, 06:07 AM   #16410
SuperSize
Oddometer: 152
Typo sorry. Its a 08. Stock tank also.
XR650R
WR250F
Super Tenere
SuperSize is offline   Reply With Quote
Times are GMT -7.   It's 06:54 PM.
