Old 08-15-2010, 06:32 AM   #16411
emerson.biguns
All idiot, no savant
emerson.biguns's Avatar
Oddometer: 10,420
Is the US the only locale that is heavy into ethanol? Any history of international failures that may correlate ethanol causes?
Any reports yet of a new pump failure?
Sounds like any major adventures would warrant pump replacement AND a spare.
emerson.biguns is offline   Reply With Quote
Old 08-15-2010, 11:45 AM   #16412
ducnek
Satisfied customer
ducnek's Avatar
Oddometer: 1,010
Gun shy fuel pump
Ok so I posted on here about my WR with a build date of 2/08. The bike died a couple of times after I loaded it up for a weekend ride, while running around the block. It was 100+deg.
I left for the trip anyway, and I figured that if it is heat related that it will break while on this trip and get it over with. It was 100+ for most of the trip this weekend. I did a little over 600 miles on the WR with no fuel issue what so ever. The major issue my poor backside.
From what I have read the bike will not die all at once, but will rather only start after cooling (sometimes).
I read about 200 pages of this thread before I noticed the bike die. Then I *thought* I heard the priming sound change. I think that reading all of the posts made me overly suspicious of the fueling issue.
Few people post about how reliable the pumps are, and I wonder how many pumps have failed compared to the number sold that were built in early 08?
I guess less than 10%.
I do ride alone mostly, and ride in relatively remote areas, but I do take enough food/water in case I have to hoof it out. I plan on running mine till she blows and hope for the best. Time will tell.
ducnek is offline   Reply With Quote
Old 08-15-2010, 02:43 PM   #16413
skierd
Wannabe Far-Rider
Oddometer: 2,938
My current WRR is right in the meat of the bad pump range (02/08, 1500's VIN) and closing fast on 8000 miles with no issues, even with all the heat this summer. This is why I bought the extended warranty on mine, if it ends up being a problem I'll be happier with replacing the pump instead of having to worry about a doohickey breaking loose or a cam chain tensioner detonating or etc etc etc...
Of course I probably just jinxed myself with the 4 days off I have coming up.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 08-15-2010, 03:58 PM   #16414
DingWeed
DingWeed's Avatar
Oddometer: 505
Originally Posted by Machtig
I have a feeling that the above account, and the one in this thread, are due to operator error.
In my experience, you would have to really, really abuse the clutch to wipe it out so quickly. During my testing with the Revloc dyna ring, I slipped my clutch pack numerous times, and its still going strong. If you continually slip the clutch in mud, rocks whatever, with the engine WOT, yeah, you will destroy it in short order. Slipping it occasionally, for short periods, and it will likely be fine
Yes-----It was all operator error!! I got a rock lodged in the counter sprocket and it was so slimy that I did not realize that I was not spinning the tire!!........Chalk it up to experience!!
BIG THANKS to EB for saving the day....and the trip!!
Thanks much for everyone that offered help!!
It was a FANTASTICK ride!!
Thanks again everyone
Scott
self discipline.......personal responsibility
www.3stephideaway.com
scott@3stephideaway.com
DingWeed is offline   Reply With Quote
Old 08-15-2010, 04:00 PM   #16415
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,422
Originally Posted by edteamslr
Mine is 1/08 0041. Only 2,000miles so far and slightly worried. It doesn't get very hot here but I'm taking it to Russia next year so it looks like I'll have to find space to add a fuel pump to my luggage!
Will do the same for peace of mind when off the beaten path. What is a rough estimate for time to swap out a pump in the field?
Bgunn is offline   Reply With Quote
Old 08-15-2010, 04:06 PM   #16416
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,876
20 minutes alone, 1 hours with advice from bystanders.
“If you think adventure is dangerous, try routine; it is lethal.” (Coelho)
Attico is offline   Reply With Quote
Old 08-15-2010, 04:11 PM   #16417
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,734
Very easy swap, hardest part is to keep the gas on the tank.. just fuel clip, electrical clip and i believe six allens, put the pump in the same orientation as you took it out..
Man, wish we had a master list of everyone who's had problems then appoint a spokes person for us WR owners and speak to Yamaha with our list !!!!
Given that the owner of the Yamaha dealer in Idaho swapped pumps with us from a new bike he had on the floor leads me to believe Yamaha gave him good news about sending him out another one for the new bike ?!
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 08-15-2010, 05:08 PM   #16418
Machtig
Oddometer: 369
Done.
Well, I think my WRR is officially "done" and I couldn't be happier with it. I'm still in the middle of the engine break in following the Thumper Racing big bore, but I can say this so far--the increase in bottom end torque is substantial. I really like the Jet Hot coated exhaust bits as well. I've run with this headlight for over a week and have passed a couple popo and none have pulled me over yet. I think I'd have issues at night, but I don't typically ride at night unless I'm chasing Scottmac's campsite. I'm still trying to get Paul at HDB to build me a custom instrument cluster protector, but for now my home fabbed mount is working fine.
I think all I'll do to the bike at this point is ride it and maintain it. Maybe throw some yellow plastics on it if Wheeling Cycle supply ever gets any.
Machtig is offline   Reply With Quote
Old 08-15-2010, 06:14 PM   #16419
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,736
Scott
Welcome back!
Can't wait to read the reports from you and BD
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 08-15-2010, 06:25 PM   #16420
Machtig
Oddometer: 369
Doh! That blows. Are you still running the stock case saver/cover or the VWsandman one? How big was the rock? 12T, 13T, 14T?
Old 08-15-2010, 07:02 PM   #16421
scottmac
scottmac's Avatar
Oddometer: 1,675
Your bike is lookin' good Brian!
scottmac is offline   Reply With Quote
Old 08-15-2010, 07:05 PM   #16422
ramz
Professional Trail Rider
Oddometer: 2,000
What is the blue plastic thing?
ramz is offline   Reply With Quote
Old 08-15-2010, 07:06 PM   #16423
simmons1
simmons1's Avatar
Oddometer: 1,525
Looks like a church key to me.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 08-15-2010, 07:10 PM   #16424
fastfreddie15005
Oddometer: 6
Its a beer bottle opener.
fastfreddie15005 is offline   Reply With Quote
Old 08-15-2010, 07:15 PM   #16425
Machtig
Oddometer: 369
Yamaha key ring/bottle opener. Don't be jealous.
Times are GMT -7.   It's 03:04 AM.
