08-15-2010, 07:15 PM
#16426 | |
Oddometer: 369
08-15-2010, 07:47 PM
#16427 |
oneandahalfassed
Oddometer: 9,811
Machtig, Do you have any details on your ignition switch mounting?
How did you deal with the tamper proof bolts on the stock bracket? Looking good by the way. Did you go with the provided EFI controller or are you running an aftermarket? You probably listed it already but reading is hard ![]() Sure looking good. I was supposed to be riding right now but I am at wurk. I will be out soon though and I did ride to work but that just ain't the same.
Round Way Round, 2 months and several thousand miles on a WR250X |
08-15-2010, 07:49 PM
#16428 |
Navigate 2 Adventure
Oddometer: 2,106
Heat Shield for FMF Powerbomb
Has anyone adapted a generic heat shield for their FMF Powerbomb header?......I wear shorts a lot which exposes my inner right leg to heat since my knee guards dont cover everything.....
Chris Crawford (Crawford + 4 kids = Crawdaddy http://www.CrawdadOffRoadEvents.com http://www.DualSportMoto.com http://www.WhereAmIRiding.com |
08-15-2010, 08:54 PM
#16429 | |
Sand seeker
Oddometer: 1,105
Looking forward to a ride report. When you left our boat shop on Coeur d'Alene lake, Rick's bike wasn't charging. Did he get it resolved?
Everybody's on the run |
08-15-2010, 09:27 PM
#16430 | |
Oddometer: 369
The ignition switch is in the stock location. I only moved the instrument cluster. I did have to cut the stock mount off but I don't ever plan on going back to stock, so no biggie in my book. If I do, I'll just buy a new mount I just didn't want to have to deal with those tamper proof bolts right now. |
08-15-2010, 09:41 PM
#16431 | |
Oddometer: 317
All my fault...It felt like I was just spinning the rear tire. Several rocks bound up between engine case and sprocket......It took about an hour with a tire iron to free the chain!!!.....(that is removing the mud and rocks) Sandman casesaver and guard is great! Scott
self discipline.......personal responsibility |
08-15-2010, 09:49 PM
#16432 | |
Oddometer: 317
No...He just kept both of the batteries charged up. He could get about 1 and a half days of riding out of 1 battery. You guys were tripsavers!!! Thanks again for all the help!!!! Scott
08-15-2010, 10:35 PM
#16433 |
Oddometer: 249
Ok, I've been wanting one of these forever. I have kept up with this thread since it started. Am I crazy for wanting to trade my VFR in for a WR?
One of the biggest things I was worried about was not being able to take longer trips on the smaller 250. It is obvious this bike is capable of any long trip you guys can throw at it. I am no longer worried about that. I would definitely miss the VFR, but I can get another one later down the road... |
08-16-2010, 01:14 AM
#16434 | |
Oddometer: 962
Same here, not worried, 6000+ miles, no problems. Will NOT be buying a back up pump... $$$ If mine breaks, oh well. I have run mine allmost empty many times this summer and it's been really hot here. If it is heat related. Maybe having Safari tank increases the chances of having a pump go bad. The right side/wing of Safari tank is right behind the radiator. A lot of heat comes true there. Does Safari have that aluminium foil/foam heat shield under it either? Safari tank is allso completely exposed to sun. The stock tank is allmost completely covered by the side shrouds. |
08-16-2010, 01:51 AM
#16435 | |
wr250r, XT660Z & DL650
Oddometer: 224
did you run into any problems? are the wires long enough or did you have to reroute/lenghten them? is cutting the mount needed or only if you fit that bigass light? ![]() btw: my pump made a different sound priming the other day (it was louder), should I be worried? 08 wrr and don't know the build date (since that isn't on the VIN plate here in Europe...) |
08-16-2010, 10:39 AM
#16436 | |
Oddometer: 369
FWIW, I'm running my pump till it blows chunks. Then I'll replace it. I've got an '08 build and about 5k miles, no issues yet. One thing that is rarely mentioned here, but these bikes need a good ground to operate correctly. I had a very slightly loose negative terminal connection and it caused all sorts of weird things to happen with the bike. Make sure your battery terminals are tight.
08-16-2010, 10:51 AM
#16437 | |
All idiot, no savant
Oddometer: 8,223
Cable to battery or cable to frame connection? . |
08-16-2010, 02:58 PM
#16438 |
Oddometer: 317
IMHO the "fuel pump problem" is too much ethanol in the fuel!!
We had some problems in north Idaho and a bike mechanic turned us on to Star Brite Star-Tron Enzyme Fuel Treatment. It did help!! The only problem was that I did not have any more of it the closer I got to home!! I picked up some today,treated my fuel, and have been riding around Tucson with no problems at all!!!!! To the best of my knowledge,there is no ethanol in Tucson gas, in the summer months because this is what happens when you have too much ethanol and temps are high!! I would suggest getting some Star-Tron and see if that works!! Just my opinion.......I am not looking for an argument! Scott
08-16-2010, 05:40 PM
#16439 |
Oddometer: 644
The UPS man just delivered my new fuel pump
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, H2 750 |
08-16-2010, 05:56 PM
#16440 |
Oddometer: 34
Regarding ethanol and the Japanese fuel pump recall, does Japan have ethanol in their gas?
