Old 08-23-2010, 11:47 PM   #16606
TierHawg
Herder of the J-Cats
TierHawg's Avatar
Oddometer: 126
Popeye approves
XTZ12B
WR250R
TierHawg is offline   Reply With Quote
Old 08-24-2010, 03:09 AM   #16607
arkridergc
arkridergc's Avatar
Oddometer: 295
Twitchy throttle
I rode some really rocky terrain this weekend and the bike handled it all just fine except for the abrupt off/on throttle response at rock crawl speed. It made it very hard to smoothly get through the knarly stuff. I kept winding up in 2nd gear and just trying to keep a little more speed rather than deal with the water faucet style throttle response. Anybody else having this problem or have a cure?
Apostle2
Ride report
http://www.advrider.com/forums/showp...&postcount=933
Gary
Well they say time loves a hero, but only time will tell......Little Feat
3 rides in 1 weekend, Mt. Nebo State Park Arkansas
Two Brothers on Two50's
Two Brothers on Two50's ride Colorado
'09 Yamaha WR250r, '08 Harley Davidson Road Glide
arkridergc is offline   Reply With Quote
Old 08-24-2010, 03:34 AM   #16608
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,009
Originally Posted by arkridergc
abrupt off/on throttle response at rock crawl speed. Anybody else having this problem or have a cure?
Try taking any slack out of your throttle cable.
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold)
Member AMA, NETRA, MVTR, CCCOFVT
Stealth is good! Noise annoys!
Nice_Rumble is offline   Reply With Quote
Old 08-24-2010, 04:11 AM   #16609
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Gary
My X has been like this since day 1.... very tough to ride at slow speeds because of the abrupt on/off of the throttle. My Ninja 250R, by comparison, is very smooth and easy to ride at slow speeds. I just thought this was the way the WR was and probably because of the FI or something.
GotMojo? is offline   Reply With Quote
Old 08-24-2010, 04:24 AM   #16610
vwsandman
vwsandman's Avatar
Oddometer: 241
Cool2 throttle abruptness?
I found three things that when combined pretty much eliminated any throttle snatch:
1) Fuel programmer, in my case a Power comander 3
2) G2 ergonomics throttle sleeve with the 400 cam (throttle tamer)
3) 47T rear sprocket.
I can pretty much stand on the pegs in rough terrain in first gear and tractor around at will now...
Ivan Sandoval
https://sites.google.com/site/sandmanparts/ ADV Vendor thread and more info here:http://advrider.com/forums/showthread.php?t=537271
Home of The Original WR250R/X Case Saver/Freedom Sprocket Guard Kit
vwsandman is offline   Reply With Quote
Old 08-24-2010, 04:50 AM   #16611
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Good info, thanks. I was hoping some mods would solve this "problem". The jerkiness of the throttle really is annoying at slow speeds. I'm hoping to do an exhaust, fuel programmer, and filter here shortly. Some seem to report that that will make the bike ride smoother.
Old 08-24-2010, 05:12 AM   #16612
greer
Oddometer: 3,494
+ a gazillion. Also check for excessive drive chain slop.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 08-24-2010, 06:59 AM   #16613
Krabill
Krabill's Avatar
Oddometer: 3,526
All of the above, and practice slipping the clutch on top of all the adjustments. If you can learn how to properly use the clutch, you can completely eliminate the snatchiness.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 08-24-2010, 07:51 AM   #16614
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Sarah
Speaking of which, could somebody post a pic of what the correct drive train slop looks like? My owners manual says one thing, but then I saw a PDF file posted on another site that suggested pushing the bottom part of the chain towards the bottom of the swingarm and making sure that there is 8-13mm gap.
So, I keep wondering what is the correct method?
Old 08-24-2010, 09:20 AM   #16615
Reposado1800
Bronze Age Fall Guy
Reposado1800's Avatar
Oddometer: 5,129
You want to run with the PDF bulletin on a stock 08 with the rubber ring sprocket.
Hate gets you nowhere.
Old 08-24-2010, 09:58 AM   #16616
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
What about stock 2009 and 2010 bikes?
Old 08-24-2010, 10:05 AM   #16617
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,462
Send a message via MSN to Attico
I sdon't have a pic, but i tend to run a little looser than too tight. Just check the wear on the swingarm guide for wear. If you keep you chain lubed and kink free, and run it a little looser for safety, you should have any issues. Just remember a little loose, not tons of slack. My way of checking is to bounce while sitting on the bike and make sure there is slack when the swingarm is parallel to the ground, which is the "longest" part of the swing. Not sure if that makes sense to you...
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life."
Attico is offline   Reply With Quote
Old 08-24-2010, 12:10 PM   #16618
AZ TOM
Oddometer: 2,355
Gearing??
AZ TOM is offline   Reply With Quote
Old 08-24-2010, 01:56 PM   #16619
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Originally Posted by AZ TOM
Gearing??
My '09 X has stock gearing. And I'm wondering if the chain on an X can be a bit tighter because on the street you're not really encountering a lot of rough terrain where the rear suspension is compressing. Would that be the case?
Old 08-24-2010, 02:28 PM   #16620
malloy
Oddometer: 668
Thumb Amazing!!!!
Whew - Just finished the entire thread. Took about too much time and very informative. You guys are amazing, helpful, courteous and mostly respectful of others here unlike a few other places on ADV. A lot of good information here. Thanks for sharing .
Anyway, a comment. So often the fuel pump issue seems to come up in high ambient temperature conditions. It's just too damn hot in the tank. Well that little motor sitting under the tank ain't exactly cool. So has anyone thought of using some heat barrier to line the underside of the tank? Such as http://www.pegasusautoracing.com/pro...p?Product=1828 ?
Maybe it would help keep the tank cooler. I've seen similar OEM on other bikes but didn't notice it here, OEM or Safari.
F650GS (Build Date 11/11)
malloy is offline   Reply With Quote
Times are GMT -7.   It's 02:24 AM.
