08-30-2010, 07:03 PM
#16741 | |
Oddometer: 501
Ordered Marc Parnes Balancer
Attico, I couldn't find my dial indicator. It's still in a moving box somewhere. Eyeballing the front wheel/tire runout with a stead rest, I'd say the wheel isn't the roundest I've ever seen. It may have 1/16" out of round with much of that being what appears to be almost a flat spot. Yet the wheel itself doesn't look abused. I suppose it's possible someone got a spoke wrench for their birthday and didn't know what they were doing. The tire itself has what I would call almost a "bulge" in the tread face. Not a typical eccentric gradual out of round, but more like a 10" area on the circumference that sticks out about 3/32". I expect BikeBandit would be more than happy to tell me that this was caused by excessive seating pressure by the installing shop. And that's possible since the guy showed himself to be a "brain donor" ![]() One thing about the cheap tire; if I need to return it and can't get 'em to play ball, I'm not out that much. I looked up the Marc Parnes balancer you were talking about. It seems like a good design to me and the price isn't bad ($105 shipped) with sticks of lead stick on weights costing $2 each. Can't get those at my backwater auto parts or tire stores. So I ordered a universal balancer and some sticks of lead. If balancing doesn't improve the problem sufficiently to allow me to use up the new tires, I'll get the front tire replaced either as a defective part or on my ticket; whichever turns out to be realistic. Try it again. But this time, I want assurances from the seller that the tire is Shinko, not Golden Boy. Not sure if that's an issue at all; just suspect it. Anyway, so thanks for the suggestion on the balancer! I'm a retired car mechanic, but not much motorcycle background. So I sure appreciate everyone's input! With that background, I have to admit to being very darned picky about wheel/tire smoothness. I go to unusual lengths to make my car and truck ride smooth. And that's not easy with all the crap out of round car tires being sold these days! I think maybe some people would have just used the tires up as is and maybe it wouldn't have hurt much. So that's the plan. Artoo |
08-30-2010, 07:32 PM
#16742 | |
Wrong way 'round
Sounds like you're on the right track. The flatspot on the rim can happen if the spoke tension isn't right. The bulge could beba seating issue. You can put your axle on wood blocks and use some stiff wire like a strand of romex as a guide to get rough runout, check roundness or for dents. A good shop can true out most problems. You can trust a shop like buchannans or woody (see vendors forums) if the local shop aren't any good.
Let us know how you make out...i'm curious. Quote:
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life." |
08-30-2010, 07:47 PM
#16743 | |
Oddometer: 501
Thanks again!
Excellent tips, there. I was considering taking the wheels to Woody's as I think they are in Denver. It's a bit of a hike, but doable. I'll try the balancing first since the wheels aren't "horrible"... Would like to get through riding season and maybe one set of tires, then maybe farm the wheels out to Woody's during the off season. Artoo |
08-30-2010, 08:02 PM
#16744 | |
It'll grow back.
Oddometer: 366
(((((Sorry ... there's a fine Mist settling over the valley .... )))))
___G.O.D.S.____ (Geezer On a Dual Sport) |
08-30-2010, 08:09 PM
#16745 | |
Oddometer: 501
BigFeet screwed with this post 11-14-2010 at 05:29 AM |
08-30-2010, 08:35 PM
#16746 | |
caddis muncher
Oddometer: 14,802
08-30-2010, 08:53 PM
#16747 | |
caddis muncher
Oddometer: 14,802
(I haven't balanced the last 2 sets of tires I've put on) |
08-30-2010, 08:57 PM
#16748 |
It'll grow back.
Oddometer: 366
Hammer it on there with an 18 pound sledge. Hit it with 98 pounds of air pressure. Run it up to 138 mph.
If ya survive ..... .... it's good. heh
08-30-2010, 09:56 PM
#16749 | |
Butler Maps
Oddometer: 14,440
i've balanced every wheel (dirt, ds & street) i've mounted a tire on with this.
http://www.marcparnes.com/Universal_...l_Balancer.htm i use motion pro stick on weights. theory is easy. -setup and let wheel rotate to low point (heaviest spot) -apply weight at top/light point/180 degree from low point. -rotate 90 degree and let wheel move. -if it goes back to low point add another weight to light point -repeat until the wheel doesn't move...heavy point = light point = it's balanced Quote:
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
08-30-2010, 10:46 PM
#16750 | |
Mmm... mud!
Oddometer: 1,399
'07 Speed Triple 1050 | '08 WR250R "'Course, don't ever tell anybody that they're not free 'cause then they're gonna get real busy killin' and maimin' to prove to you that they are." -George Hanson |
08-31-2010, 05:27 AM
#16751 | |
Oddometer: 198
08-31-2010, 07:26 AM
#16752 | |
Oddometer: 1,284
08-31-2010, 08:03 AM
#16753 |
Off the road again..
Oddometer: 2,130
Longer clutch cable
I just spoke with Motion Pro about making a custom clutch cable 1.5" longer than stock. Since it is a custom item, it is going to run $40 plus shipping. Not out of line for what it is, but has me wondering if anyone else knows of a source for a longer clutch cable so I can compare, otherwise I might just go ahead and order tomorrow. Thanks.
For Sale: 2008 Suzuki VStrom DL650 in Bozeman, MT. |
08-31-2010, 08:40 AM
#16754 |
Oddometer: 718
Clutch Cable
Do you think that Motion Pro would be condusive to a group buy on a longer clutch cable? Seems like we should be able to get 20 orders from this site pretty easily. Alot of guys are running high bend bars and risers on their bikes.
08-31-2010, 08:41 AM
#16755 |
Oddometer: 1,388
I have 3/4" risers , CR high bend bars , absolutely no problems with any of the cables.
