Old 10-11-2010, 05:35 PM   #17851
Reposado1800
Bronze Age Fall Guy
Reposado1800's Avatar
Oddometer: 5,131
Anybody change their fuel pump and notice a difference in the sound it makes compared to the original 2008?
Hate gets you nowhere.
Old 10-11-2010, 06:38 PM   #17852
Chadx
Off the road again..
Chadx's Avatar
Oddometer: 2,132
Originally Posted by BigFeet
Hell, I should probably add one of those, too! Be the local "super tanker" to bail out riders on empty!
Nah, 6 lbs per gallon adds up fast...
That's preposterous!
OK, OK. I never actually road it like that, but the potential for 7.5 gallons is there. See my previous post...http://www.advrider.com/forums/showp...ostcount=15542
Chadx is offline   Reply With Quote
Old 10-11-2010, 07:21 PM   #17853
BigFeet
Oddometer: 501
I like it a lot! Now that's a SUPERTANKER!
BigFeets
BigFeet is offline   Reply With Quote
Old 10-11-2010, 07:23 PM   #17854
BigFeet
Oddometer: 501
FMF Q4 Muffler w/Stock Heat Shield
I'd seen some requests for pics of the stock heat shield on an FMF Q4.
This link goes to a thread I started for just this. It has a few tips on how I pulled it off; not super-sano by any means, but it looks good and works well.
And yeah, as usual I took a couple of shortcuts.
BigFeets
http://wr250rforum.forumotion.com/oh...3142.htm#30816
Old 10-11-2010, 07:39 PM   #17855
BigFeet
Oddometer: 501
Revloc Automatic Clutch
I've read all the linked info I could find on this and it looks like a Revloc on just about any dualsport is the cat's ass.
I've heard back from BigBird saying it's maintenance free and bulletproof.
Hoping to hear from some other WRR/X Revloc users... how do you like it everywhere? Any problems? Would ya' do it again? Do you know of a left hand rear brake unit that fits better than Revloc's version?
Stuff like that. Link to the main thread I've found on this for our bikes:
http://wr250rforum.forumotion.com/oh...4-20.htm#30817
Mainly, I'm just looking for some more recent or updated input. How goes the Revloc?!?
Machtig?? Others?
I'm about 2 or 3 days from ordering a Revloc anyhow.
TIA!
-feets
Old 10-11-2010, 10:06 PM   #17856
kawagumby
Oddometer: 359
Very much so. The new pump is a whole octave lower in pitch - very noticeable, it sure seems that would be from spinning more slowly? I was worried at first, but it has been working fine. (I changed mine out as a precaution, the old unit worked fine too, but it was an early model -08).
the true tragedy of our times -
human overpopulation is destroying the 2-stroke
kawagumby is offline   Reply With Quote
Old 10-12-2010, 03:18 AM   #17857
MiXu
Going small
MiXu's Avatar
Oddometer: 68
Question Chain Tension with 13/48?
Could someone running on 13/48 sprockets share their chain tension checking method? Where do you measure and what is the clearance? Don't say you measure with your fingers unless you have measured your fingers
I tried basing my tension on the Chain Tension Technical Bulletin and taking my bigger rear sprocket into account by using the upper limit of the TB spec (i.e. setting the clearance between the swing arm and the chain to about 12~14mm whereas the bulleting says 8...13mm) but I'm not quite sure this is the right way to go. The radius of the 48 sprocket is only 12% bigger than the radius of the original sprocket, right? So do I even have to take the bigger rear sprocket into account?
I don't have a tension gauge so I just push the chain towards the swing arm firmly but not with excessive force (the clearance difference between "firmly" and "with excessive force" is very small anyway, maybe 1 or 2 mm).
I do know that I could check the tension by deattaching the rear shock and aligning the sprockets and the back swing pivot but I'm still gathering courage to to do it I'm hoping someone has already done that for me
Big bore = Big bore
MiXu is offline   Reply With Quote
Old 10-12-2010, 05:57 AM   #17858
Krabill
Krabill's Avatar
Oddometer: 3,526
I'm running 13/47 and I don't get all scientific about it, but I keep just about 1/2" clearance between the top of the chain and the bottom of the swingarm. Seems to work for me.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 10-12-2010, 08:21 AM   #17859
simmons1
simmons1's Avatar
Oddometer: 644
This is what I do as well and works good for me.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, H2 750
simmons1 is offline   Reply With Quote
Old 10-12-2010, 08:24 AM   #17860
malibu_dan
Adventuring Mystic
malibu_dan's Avatar
Oddometer: 1,070
So, if one IS digging into the plastic swing arm protector more than one would like--do you think it's because of running the chain too tight, or too loose?
Follow me over here >>> WRRDualSport.com <<<
malibu_dan is online now   Reply With Quote
Old 10-12-2010, 08:45 AM   #17861
Krabill
Krabill's Avatar
Oddometer: 3,526
I have no idea. I'm guessing the 12T wasn't helping matters. I was worn into the swingarm at 5k miles when I was running the 12T. I've put 8k miles on it since then with the 13T/47T combo and while there are grooves in the guard, it isn't anywhere close to being eaten through yet.
I have always adjusted my chain the same way. ~1/2" clearance.
Loud Sucks!
Old 10-12-2010, 08:45 AM   #17862
scottmac
scottmac's Avatar
Oddometer: 1,283
Machtig?? Others?
TIA!
-feets
Brian (Machtig) is the one you want to get a hold of regarding this.
He's pretty much paved the way to get a Revloc that's compatable for
the WRR/X.
scottmac is online now   Reply With Quote
Old 10-12-2010, 09:16 AM   #17863
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Just a quick update (or lack thereof) on the fuel pump on my 2009 WR250X. I took the bike up to the dealer this past Saturday... haven't heard anything yet. The appointment isn't technically until this Friday, but I dropped it off earlier in case they could get to it sooner. When I dropped it off, the service guy seemed to think he could get it replaced...he'd call Yamaha if he had to. I told him I don't want the bike back without a new fuel pump LOL. I will post here once all is said and done.... hopefully it won't be too long.
GotMojo? is offline   Reply With Quote
Old 10-12-2010, 10:23 AM   #17864
greer
Oddometer: 3,494
Me too, under that big white sticker on the swingarm. I let my chain get too lose over a span of 200 or so miles and it wore the crap out of my chain slider. I've always run a 13T.
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 10-12-2010, 10:29 AM   #17865
bash3r
bash3r's Avatar
Oddometer: 1,597
Send a message via ICQ to bash3r Send a message via AIM to bash3r
Missouri 1900s Swinging Bridges
Here's a RR I just posted of my 2 day swinging bridges ride here in Missouri... camped off the bike and video from my GoPro helmet cam. The WR was just perfect, man I just can't wait to saddle back up on this bike time and time again..
Ride Report Video Here
I had a ball....
08' Yamaha WR250R
08' Kawasaki Versys
My ADV Website
| ADV Legends
bash3r is offline   Reply With Quote
Times are GMT -7.   It's 03:22 PM.
