Old 04-11-2011, 08:23 AM   #21061
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 891
First commute to work on the SM wheels.
onetravdown is offline   Reply With Quote
Old 04-11-2011, 09:12 AM   #21062
straightrod
Oddometer: 1,313
And it was like?
straightrod is offline   Reply With Quote
Old 04-11-2011, 09:34 AM   #21063
onetravdown
I can't ride where?
Oddometer: 891
Originally Posted by straightrod View Post
And it was like?
Riding a great handling slow bike fast through the curves and it was lots of fun!
Old 04-11-2011, 02:52 PM   #21064
Artlocks
Artlocks's Avatar
Oddometer: 154
jumpering out the headlight relay
Is it ok to remove the headlight relay?
Some background. The WR is new to me so I am not too familiar with it. I installed a headlight cut-off switch and it didn't work. I traced backward from the light looking for voltage until I got to the headlight relay.
I pulled the relay and checked it. I applied 12V to the coil and the contacts closed, so the relay appeared to be ok. The relay coil measured 94 ohms if that means anything. With the relay still removed, I put in a jumper on the relay connector to mimic the relay contacts. Now the headlight and cut-off switch worked as expected. This is a mystery, the relay checks ok yet does not work in the circuit.
What is the relay for? One side of the coil goes to the ECU so I assume the ECU is supervising the headlight in some way. At first I thought maybe the ECU kept the light from coming on until after the motor is started. Or maybe the ECU sees that my fuel pump is disconnected and the tank removed and determines I donít need a headlight. But both of these seem wrong because I hear the relay click when I turn the ignition switch to on. However, I didnít actually try to start the bike since my tank was off, so maybe the ECU opens the relay contacts only when cranking the motor.
Can I just leave the relay out and put in a jumper? If the ECU is only disconnecting the light during startup, I really donít need it since I now have a cutoff switch. Also with it out, it is one less thing that can fail. But what goes on inside the ECU is a mystery to me. I wonder if the ECU needs that wire from the headlight relay coil for other purposes. I would be nice to have a document explaining what the ECU does with all itís inputs and outputs.
If replacing the relay with a jumper is not a good idea, I guess I can buy another relay and cross my fingers.
Thanks for your help.
Artlocks is offline   Reply With Quote
Old 04-11-2011, 05:46 PM   #21065
Steez
USMC Infantry
Oddometer: 203
Thank you DewTwo, that means a lot.
Skierd- I like that setup. Just curious- how do you attach the tailbag? Will I need a rear rack?
Steez is offline   Reply With Quote
Old 04-11-2011, 06:53 PM   #21066
AKASY
Noob
Oddometer: 2,168
Relay
In operation the headlight is off until the motor is running--most likely to make sure the pump has sufficient voltage when the motor is cranking.
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 04-11-2011, 07:33 PM   #21067
Bonnie Abbzug
Property of Hayduke
Bonnie Abbzug's Avatar
Oddometer: 10,341
Loaded up the Stalker Van and headed to the desert!
It was cold and rainy, but we had a great time anyway!!
Bonnie Abbzug is offline   Reply With Quote
Old 04-11-2011, 07:41 PM   #21068
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,725
Noyyyyce!!!
MoBill is offline   Reply With Quote
Old 04-11-2011, 10:14 PM   #21069
SkidMarx
SkidMarx's Avatar
Oddometer: 2,127
FYI,
Found a WRR part out in MI. Don't know the seller.
http://flint.craigslist.org/mcy/2317091894.html
'90 XT350
'08 WR250R
GLDS
SkidMarx is online now   Reply With Quote
Old 04-11-2011, 11:05 PM   #21070
Bgunn
Mucha distancia
Bgunn's Avatar
Oddometer: 1,418
Originally Posted by Crawdaddy View Post
Fun day/ride with Daughter # 2, Caitlynn, yesterday.......one nice thing about living in the foothills of San Diego is we have some fun trails right out our door......
Mid Trail:
We had a rain/snow/hail mix yesterday. Hurry summer..........
Family fun at its finest..Do all your kids ride? Have a pretty good guess.
Bgunn is offline   Reply With Quote
Old 04-12-2011, 07:14 AM   #21071
AZ TOM
Oddometer: 4,000
It was cold and rainy, but we had a great time anyway!! [/QUOTE]
Keep heading south next time & Scotty & I will take you two on some great & warmer rides??
AZ TOM is offline   Reply With Quote
Old 04-12-2011, 08:58 AM   #21072
onetravdown
I can't ride where?
Oddometer: 891
Wasn't there a thread or post showing how that windscreen was made?
Old 04-12-2011, 09:06 AM   #21073
skierd
Wannabe Far-Rider
Oddometer: 2,938
Anybody out there with the happy trails panniers mind throwing up a picture of the setup? Particularly a direct side view and a direct rear shot. Let me know if you have the teton or the imnaha too...
I'd also like to.see anyones setup with a hard top box too, givi, pelican, etc. Let me know what size also...
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 04-12-2011, 09:36 AM   #21074
Krabill
Krabill's Avatar
Oddometer: 4,883
I just replaced my old cheap top box with a Pelican 1400. I like it. I'll try to remember to take some pictures of my mounting tonight.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 04-12-2011, 09:36 AM   #21075
GsVs
Goin' Somewhere
GsVs's Avatar
Oddometer: 1,402
H-T racks 'n cases
Hey skierd ...
Check the thread below for some pictures of the Happy Trail rack with and without bags ...
http://wr250rforum.forumotion.com/t8...trail-su-racks
Honda
GsVs is offline   Reply With Quote
Times are GMT -7.   It's 09:38 AM.
