Old 05-15-2011, 03:58 PM   #21811
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,247
Originally Posted by vasculopath View Post
All fuses are OK, battery is fine, just no action from the fuel pump.
I think then you've isolated it to the pump itself and the the wiring. I'd double and triple check the wiring. Doubt your new pump is bad.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 05-15-2011, 04:52 PM   #21812
Krabill
Krabill's Avatar
Oddometer: 4,867
If it ran before you took it apart and doesn't now, you obviously bumped something or didn't plug something back in correctly.
Kill switch turned on?
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 05-15-2011, 05:30 PM   #21813
VTbeemer
Traveler
VTbeemer's Avatar
Oddometer: 349
So Last fall, the fuel Pump in my 08 started to go. I ordered a new pump and waited for the IMS Large tank to come out. Got the tank last week, install went without a hitch, but the bike won't start. When I turn on the Key, I am not hearing any noise from the fuel pump...So electrical right? Disconnected the electrical plug from the tank, and when they key is turned, it gives a low fuel light on the panel...So there must be some connection going on, because the fuel sensor must be picking up. Plugged the old fuel pump in for kicks and no noise from it when the key is turned on either. I'm a bit stumped.
Any Suggestions?
I also did the airbox flapper mod at the same time, but that shouldn't have caused any thing like this..
Any Help appreciated. I had a window to take a ride with the kids out of the house with Mom this afternoon...bummer.
Sidestand Switch??
http://vtbeemer.blogspot.com/
14' R1200GSW- 93' R100GS/PD- F650GS- 94' R11RS
08' WR250R- 95 R100R- K75s- 57' R69
77' R75/7- 06' Ducati S4R Monster- 74' XL 250
VTbeemer is offline   Reply With Quote
Old 05-15-2011, 06:04 PM   #21814
vasculopath
You're not your bike
vasculopath's Avatar
Oddometer: 366
Originally Posted by Heoz View Post
Since you did the flapper mod, you might want to check that the tilt/lean angle sensor is connected and oriented correctly.
Where is that?
vasculopath is online now   Reply With Quote
Old 05-15-2011, 06:25 PM   #21815
vasculopath
Oddometer: 366
Where is that?
Duh, the little black box that says up? The one that I removed?
Ha Ha Ha!
Thanks Heoz! I owe you a beer if you're ever in Santa Fe!
vasculopath screwed with this post 05-15-2011 at 07:48 PM
Old 05-15-2011, 08:14 PM   #21816
rjnutt
Desert tortoise
rjnutt's Avatar
Oddometer: 244
Good call Heoz
rjnutt is offline   Reply With Quote
Old 05-16-2011, 12:48 PM   #21817
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,548
new ims fuel tank filter sock avail.
since profil australia has effectively stopped production i found this.
http://www.crfstuff.com/prfufi.html
http://www.split-stream.com/products...xf-ktm-sxf-efi
contacted crf stuff and found out that honda and ims use the exact same fuel neck/cap dimensions. crf stuff have tested the filter and several different ims tanks. they all fit and fit the same as ims use the same cap/neck on all their tanks.
also been using the acerbis locking cap on my ims .
works great.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-16-2011, 01:18 PM   #21818
RichardU
Let's Ride
Oddometer: 900
If anyone is looking for a rare silver-framed X, I've posted my WR250R with factory X wheels for sale here:
http://www.advrider.com/forums/showt...8#post15925648
RichardU is offline   Reply With Quote
Old 05-16-2011, 05:27 PM   #21819
Machtig
Oddometer: 369
Well, due to the 12" of #@$%& SNOW that fell in the middle of the night, the Fool's Gold Enduro was postponed til 05 June. We'll try again then.
Machtig is offline   Reply With Quote
Old 05-16-2011, 06:46 PM   #21820
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,718
Honestly, I can't remember another time that the weather affected D36's events more in the last 10 years...
Well, here's hoping I can run it in June with my son
That would be a nice reunion. The first event we ever ran together was the (grrr) last running of the CERA Training Wheels Enduro.
He's due back from London on the 3rd, and if he doesn't take a job down south I'm sure I can talk him into it
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 05-16-2011, 09:50 PM   #21821
Chadx
Off the road again..
Chadx's Avatar
Oddometer: 2,167
Nice looking bike. Looks like you swapped the entire front end with an X (since your forks are black). I'd bite if you were closer. I've been wanting to add an X (or R converted to an X as you have done) to the pair of WRR that we have already.
If anyone within a state or two of Montana is looked to sell your X (or converted R), PM me. Mainly looking for unmolested examples (no mods to exhaust, AIS, airbox, etc.). I'll be in Minnesota visiting family in mid to late summer and will probably look around that area, too. Seems to be a lot more X models in the midwest near big cities than there are out here near the rockies.
Chadx screwed with this post 05-16-2011 at 09:55 PM
Chadx is offline   Reply With Quote
Old 05-17-2011, 04:10 PM   #21822
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 891
...and the transformation to white (natural tank) complete! Now I just need to get it dirty so that nice clean white plastic will match the rest!
onetravdown is offline   Reply With Quote
Old 05-17-2011, 04:12 PM   #21823
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,019
Looks good Trav. Dirt wheels still on from weekend?
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 05-17-2011, 04:18 PM   #21824
onetravdown
I can't ride where?
Oddometer: 891
Yep. I have to do a little traveling for work that requires me to drive this week. At least I won't have to swap over to the dirt wheels this weekend.
Old 05-17-2011, 04:23 PM   #21825
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,019
Times are GMT -7.   It's 05:27 AM.
