Old 06-16-2011, 06:54 PM   #22516
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,748
Originally Posted by Fast1 View Post
I haven't popped open a little WR but on other Yamahas I've owned we would zip tie the cam chain to the cam sprockets during the tensioner release phase which may help you also.
Oooo....I like that idea.
Just don't drop the zipties into the abyss, when you cut them off...eh?
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 06-16-2011, 07:09 PM   #22517
PYG RYDR
Adventure-Dual Sport
PYG RYDR's Avatar
Oddometer: 392
Question Tires
Anyone try to run the new Kenda Big Block 140-80-18 on the rear wheel?
http://www.kendausa.com/en/home/moto...big-block.aspx
I am speculating it is too wide and will rub the chain....
TIA
PYG RYDR
T800XC-VFR800-XR650L-WR250R
MSTA-NVR
There are two things to aim at in life: first, to get what you want; and, after that, to enjoy it.
Only the wisest of humans achieve the second.
Logan Pearsall Smith
PYG RYDR is offline   Reply With Quote
Old 06-16-2011, 07:52 PM   #22518
tshrey
Oddometer: 200
Even if it fits, you really want to run a 15 pound tire on the back of little RR? The Dunlop D606 feels stupid heavy at 12.3 pounds.
Having said that, I'm curious if it will fit as well
tshrey is offline   Reply With Quote
Old 06-16-2011, 08:20 PM   #22519
skierd
Wannabe Far-Rider
Oddometer: 2,972
Pardon,
But does anyone else running a Unifilter want to part with their stock filter cage for Steez? I offered mine up, but can't find the damn thing (or my TwinAir filter) to save my life. I'll pay for it for getting his hopes up...
Dave
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 06-16-2011, 10:43 PM   #22520
tshrey
Oddometer: 200
He can have mine, no need for anyone to pay anything.
Steez, PM me your address and I'll see if I can get it out tomorrow.
trav
Old 06-17-2011, 02:59 AM   #22521
RoadDad
n13ub
Oddometer: 444
Originally Posted by HighFive View Post
Is the camchain jumping a tooth when you fire (release) cam chain tensioner? That was what I experienced. If so, there are a couple approaches to resolve this. First of all, make sure the marks are aligned, and pull all the slack in the camchain to the back side.....i.e. pull the chain tight on the front of the engine when you set it on the exhaust cam sprocket, and drape the extra slack over the back side where the camchain tensioner is.
Next, get your tensioner loaded, installed, & ready to fire. But, before you release the tensioner, put a good rag on top of the camchain sprockets (to protect your hand) and hold the chain down firmly against the top of the two sprockets.....while you release the tensioner (by turning the crank against it). Might take a couple attempts for you to get the hang of it, but the "Ah-Ha" moment will come. Then, it will be celebration timeout.
The other option, is to try and release the camchain tensioner from "inside" the cylinder tunnel using a long screwdriver, or the like. This keeps you from having to turn the crank to fire the tensioner. Often, just a little pressure pushed into the backside of the tensioner will make it release.....if you can reach it that way. I'd still keep my hand pressure on the top of the chain & sprocket to help keep it from jumping a tooth. This WRR tensioner is a nasty evil little gadget, and can fire with quite a bit of force.
Hope that helps you out.
HF
Guess i didn't explain the situation very well. I can't get the sprockets lined up period. Not even before i fire the tensioner. They are always about half a chain link off. No, they are not worn. Sprockets and chain look brand new and they were lined up before I pulled the cams.
RoadDad is offline   Reply With Quote
Old 06-17-2011, 03:39 AM   #22522
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,306
HF
Did ya like it when I said it at top of this page too?
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 06-17-2011, 03:42 AM   #22523
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,306
Is there a chance you mixed up the cams and have the exhaust cam on the intake side and the intake cam on the exhaust side??
The manual should have the specs for the lift for each,. and you can measure the lobes with a lift to see which is which. They might also have an IN or EX cast somewhere into them.
Old 06-17-2011, 04:49 AM   #22524
Steez
USMC Infantry
Oddometer: 203
trav
Wow thanks a lot guys! Really means a lot that people I don't even know are looking out for me!
Steez is offline   Reply With Quote
Old 06-17-2011, 05:52 AM   #22525
RichardU
Let's Ride
Oddometer: 903
Did you take a picture before you took it apart? They don't always line up perfectly. You might not have noticed at the time.
Also, if the chain skips when you release the tensioner, I believe someone told me a solution is to rotate the engine in the other direction.
RichardU is offline   Reply With Quote
Old 06-17-2011, 11:04 AM   #22526
Tygris
Oddometer: 6
Why my Bike wouldn't start on Wednesday
On Wednesday I told everyone of the tale of me trying to get to work on the WRR after two weeks and it not starting. Well today I found out why. Intially I found my EFI fuse had blown, so I replaced it with the spare and the bike started right up. Something told me to pull my seat as well just to check things out and I found 5 stowaways. Minnie mouse scurried away almost immediately . After much cursing I evicted the 4 kids and the nest from the air box (pics below). Minnie did a good job of eating through my FMF programmer's wires.
From Stowaways
3 Babies on top of the air box
From Stowaways
Nest in the air box with 1 more baby.
Moral of the story: Keep riding regularly and maybe keep the flapper on the air box.
Luckily I work for an electronics company so I can fix the wires in a jiffy.
Keith Brown
Tygris is offline   Reply With Quote
Old 06-17-2011, 11:24 AM   #22527
SkidMarx
SkidMarx's Avatar
Oddometer: 2,266
That'll do it.
I duct tape the holes for the winter, but I doubt I would have bothered for just a few weeks.
Better to keep riding.
'90 XT350
'08 WR250R
GLDS
SkidMarx is offline   Reply With Quote
Old 06-17-2011, 12:38 PM   #22528
Chadx
my toot toot
Chadx's Avatar
Oddometer: 2,169
The dang little critters set up house under my wife's car hood last winter. Only 4 or 5 days and they chewed out about 16" x 16" section of the hood insulation to build a nice nest on the exhaust manifold. Luckily no wires were chewed (that we found). I don't do anything specific for the motorcycles. Always think about it, though.
Off the road again...just can't wait to get off the road again.
The life I love is making roost with my friends.
Chadx is offline   Reply With Quote
Old 06-17-2011, 01:34 PM   #22529
MiamiMotorcyclist
used to be -MiamiUly
MiamiMotorcyclist's Avatar
Oddometer: 1,952
These stories make me want to surround my bikes with snap traps or glue traps. Fortunately I don't see signs of mice or rats in the garage but it makes me nervous when I read these types of things.
Okay it's a sportbike... but riding is not a sport, it's a necessity. Same goes for the Dual Sport.
MiamiMotorcyclist is offline   Reply With Quote
Old 06-17-2011, 01:50 PM   #22530
vintagespeed
fNg
vintagespeed's Avatar
Oddometer: 1,799
Originally Posted by zora View Post
... If my run isn't incredibly humiliating I will post the video here when I get done.
soooo.....??? was it incredibly humiliating??
i must admit, i'm not even a WR guy but i ran across this thread and now i'm on dying to know if you made it!
530EXCR and a bunch of 2 strokes that you dont want to read about. :)
TAT-2013: http://www.advrider.com/forums/showthread.php?t=913898
SoCal_NoDak-2012: http://www.advrider.com/forums/showthread.php?t=829203
vintagespeed is offline   Reply With Quote
Times are GMT -7.   It's 06:18 PM.
