06-17-2011, 01:50 PM
#22531 | |
fNg
Oddometer: 779
i must admit, i'm not even a WR guy but i ran across this thread and now i'm on dying to know if you made it!
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
06-17-2011, 04:11 PM
#22532 |
the explora
Oddometer: 1,666
The event is this Sunday.
If I don't end up with two broken arms, I should have it posted by Monday. I know it won't be pretty, but everyone will get a laugh and I guess that's a good way to start the work week.Maybe I can inspire some of the other WR riders to give it a try at their local event. ![]() I mean really.....if a chick is taking a stab at it.... Oh, and I can guarantee there will be no "making it". I just hope to get a few feet further up than at least one of my guys.
Who is Zora? "That's hard to explain... Have you ever stood on the edge of an active volcano, with a tornado in it, during an earthquake? A lot like that... But with whiskey... And bunnies." -Benron |
06-17-2011, 04:25 PM
#22533 | |
Oddometer: 430
06-17-2011, 04:28 PM
#22534 |
the explora
Oddometer: 1,666
I just got a knobblicious Pirelli Scorpion MX XT delivered today, for the rear. I sure hope that sucker fits on there okay. Anyone tried one of these before?
06-17-2011, 04:54 PM
#22535 |
Lacks Freetime
Oddometer: 4,924
I run the Pirelli Scorpion XC MH's on the WRR, and the rear in a 120/100. It fits, barely.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
06-17-2011, 05:40 PM
#22536 |
Noob
Oddometer: 1,746
TAT Planning
OK what are they and what would you pick different?
Don't make the mistake of believing everything you think. |
06-17-2011, 05:57 PM
#22537 |
Oddometer: 2,267
I would proly change the throtle cables rather than bring them along, (not shown) cuz you break one of those and your done, clutch not so much. Personally I don't think you would need the ECU or Regulator use a snake to tie down the break lever and forget about another one in the bag, I would also suggest the Zeta levers and leave the spares at home, The zetas will spring forward rather than bending or breaking. Hoses not needed but I did put some metal mesh over the small hose coming from the pump.
Foot pegs nope, coil nope and gaskets nope. One very important thing you are not showing is a fresh fuel pump. Depending on the year and miles you have on your bike. That is the weak link. Extra spark plug, though you won't need it unless you drown the bike. Be sure your battery is good and fresh. I change mine every two years need it or not......fuel injected bike... Tooth past to get the bugs off your teeth cuz you'll be smilling all the time Hope you have a killer of a time!
10Cup - WR250R - BMW R1200GS Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker SpearMotorSports, Inc. The cost of living's going up, and the chance of livin's going down. |
06-17-2011, 06:20 PM
#22538 |
Professional Trail Rider
Oddometer: 1,725
Shift lever, extra seat bolts, fuses, throttle pull cable (remove push), oil drain bolt, inner tubes (and related tools). Start with new or nearly new sprockets, chain, tires. Some nuts/bolts, tire gauge, tools.
And take nothing in the pile you have. I would motel-it, so would not carry any camping gear. UPS clothes and whatever to motels along the route, so minimal baggage. Mojavi on the back to carry everything I'd need. I like to ride without a load on the back - much more enjoyable (to me). If you saw me on the road, you'd think I was just riding to the next town. More than you asked for, but I got carried away
06-17-2011, 06:22 PM
#22539 |
Smiles when says dat
Oddometer: 12,712
Learned that the hard way....or relearned...shipping and hotelling it...that is.
What did you mean by "remove push"?
WR250R Data Thread Pix: Sets for 2007 DL650 Build. , Custom Wolfman Tank Bag..Yamaha Super Tenere Build and now 2012 DL 650 Bulid |
06-17-2011, 06:38 PM
#22540 |
Oddometer: 1,283
A trick I've seen used before to good effect is to thread and run a
spare throttle cable right alongside the one in use and just tape/zip tie it in place. |
06-17-2011, 07:01 PM
#22541 | |
Noob
Oddometer: 1,746
Parts and Pieces
Shift lever--ordered but small vice grips work
![]() extra seat bolts--in fuses--in throttle pull cable (remove push)--doable oil drain bolt--no oil change on trip inner tubes--one 21" in (and related tools)--two short spoons and a bead buddy Start with new or nearly new sprockets, chain, tires--check done Some nuts/bolts--check in tire gauge--check in tools--check in Of what I've got here I will most likely take it all except the footpegs, Reg\Rec and the fresh air filter--traveling solo and do it a lot--some of these have been very useful on other bikes. I normally parallel in a spare clutch cable on all my bikes--which I will do with this one. No camping gear--no food. Just water tools and spare parts and oh yea an empty 1.5 gallon rotopax that I will fill and immediately empty into the main on a couple of the sections.Quote:
06-17-2011, 07:51 PM
#22542 |
Twisted Throttle
Oddometer: 1,673
I'd bring a spare headlight and tail light bulb and leave the majority of what you show in the photo.
Definitely have someway to clean and oil the air filter.
11 Husqvarna TE630 11 Husqvarna SM630 08 Husqvarna TE510- sold 10 Yamaha FJR 1300 |
06-17-2011, 08:05 PM
#22543 | |
Off the road again..
Oddometer: 2,132
06-17-2011, 08:13 PM
#22544 | |
Oddometer: 2,132
It just seams like the "what if" list could be endless because there is always one more item that could fail. I've not had anything fail in 12,000 miles and I'd take my bike on the TAT next week after a few maintenance items (tires, oil change, filter cleaning) and not carry anything you pictured; just maintenance items or plan on stopping at a dealership, independent shop or ADVrider inmate's house along the way for oil change and filter cleaning. ...And this comes from someone that hates to not be prepared and have things at the ready. At the end of the day, though, you need to do what lets you sleep at night during your trip. |
06-17-2011, 08:16 PM
#22545 |
Oddometer: 3,526
I wouldn't bring anything you've got shown there.
I would take 2 tubes, a patch kit, a bicycle tire pump, some quick steel, a master link, and my tools. That's all I take everywhere I go and wouldn't bring anything extra for a TAT trip if I were to do one.
Loud Sucks! www.wrrdualsport.com www.designatedvaping.com <- for all your electronic cigarette needs |
