06-20-2011, 08:21 AM
#22591 | |
Oddometer: 2,289
10Cup - WR250R - BMW R1200GS Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker SpearMotorSports, Inc. The cost of living's going up, and the chance of livin's going down. |
06-20-2011, 08:23 AM
#22592 |
Oddometer: 369
one respected member says run it loose, another run it tight. I need a consensus here folks
06-20-2011, 08:25 AM
#22593 |
Lacks Freetime
Oddometer: 4,978
Yamaha changed their spec from 25 mm to 8 mm of slack in chain..IIRC. I suspect that was their response to this issue...chains eating the slider and then the swingarm.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
06-20-2011, 08:31 AM
#22594 |
Oddometer: 2,289
Well I have 31,000 miles on mine and I don't eat up chain guards. Do with it as you will.
06-20-2011, 08:34 AM
#22595 |
Oddometer: 369
06-20-2011, 08:37 AM
#22596 | |
Oddometer: 359
I'd go with 10Cup if I were a slab rider.
the true tragedy of our times - human overpopulation is destroying the 2-stroke |
06-20-2011, 08:38 AM
#22597 | |
I can't ride where?
Oddometer: 774
06-20-2011, 08:43 AM
#22598 | |
Oddometer: 359
Push down on the suspension as hard as you can - get some help from someone else...is the chain getting tight? Then it needs to be loosened some - when my chains are too loose I hear them - they are noisy way before they skip. This may sound silly, but are you lubing the chains enough? I would imagine for long hauls a bit of chain lube on the surface of the chain would help keep the heat and wear down on the swingarm buffer. It is only plastic, after all, and subject to heat deformation at lower temperatures easily attained by friction. One thing about off-road riding - the chain is probably lubed fairly often compared to road trips and it probably stays a bit cooler with the stop and go. On the hiway, you can go many, many more wheel revolutions in the same amount of time and more so on longer trips.
the true tragedy of our times - human overpopulation is destroying the 2-stroke kawagumby screwed with this post 06-20-2011 at 09:05 AM |
06-20-2011, 10:21 AM
#22599 |
Oddometer: 1,290
I just sent a new chain slider I'd ordered a while back Brian's way
overnight UPS. It should be there by the end of the business day tomorrow. |
06-20-2011, 10:24 AM
#22600 |
the explora
Oddometer: 1,703
Well, I did the hillclimb yesterday. I gave it my best shot.
There are three runs back to back shown in this video, I am the second one. This was my first attempt. You can get an idea of the steepness of the hill when after the first guy goes down, you see the helpers on the side of the hill having to walk over practically on all fours, like gorillas There were about 125 riders in total and I was the only chick except one other girl who was in the Pro Class with an actual hillclimbing bike. I did end up making it higher than several other riders though! My husband took this video and sadly you don't get to see my actual wipeout as it happens...I think he was a little more concerned about me than filming the action.
Who is Zora? "That's hard to explain... Have you ever stood on the edge of an active volcano, with a tornado in it, during an earthquake? A lot like that... But with whiskey... And bunnies." -Benron |
06-20-2011, 10:29 AM
#22601 | |
Oddometer: 4,058
"If you are checking you guide for wear and the bottom of the guide doesn't come all the way to the front of the swingarm----it is worn out and you may be digging into your swingarm---probably are. I've been running my chain looser than the manual says and so far the chain is not wearing on my guide at all."
My rides... 2009 Yamaha WR250X | 2008 Yamaha WR250R | 2013 Honda CRF250L | 2009 Kawasaki Ninja 250R |
#22602 |
WRR'er
Oddometer: 158
Nice job! Any damage or does the hay make for a pretty soft landing?
06-20-2011, 10:46 AM
#22603 |
the explora
Oddometer: 1,703
My knee is pretty messed up today. It got caught under my bike on the first run, but all in all I am in one piece - just sore as hell cuz of my second run. I'll post that in a bit.
06-20-2011, 10:57 AM
#22604 |
the explora
Oddometer: 1,703
There were about 250 runs total and I won "Best In Show" for my dismount.
![]() My second run. A little breakdown: ![]() ![]() ![]() ![]() ![]() ![]() What you can't see cuz of the grass..... ![]() ![]() I ended up doing a front flip, but OFF OF MY HEAD instead of my hands. I was bent backwards in half like some sort of circus contortionist. Ouch. Luckily I didn't snap my back or neck in two.
06-20-2011, 11:00 AM
#22605 |
fNg
Oddometer: 797
awesome, good job! those 2 stroke guys need to get on the pipe and how come nobody was standing up on this climb?
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
