Old 06-23-2011, 09:52 PM   #22726
jimrobinette
Oddometer: 379
Rear running light electrical gremlin
So, two days ago my stock tail lights were working great. Tonight, I've found that the rear running lights aren't working. Everything else works great, including the rear turn signals. Bike has been in the garage and not even started during this time.
Here is the trouble shooting I've done so far.
1. Front running lights work great
2. Front turn signals work great
3. Rear tail/brake light works great
4. Rear plate light works great
5. Rear turn signals work great
There are four connections to the rear light assembly. One each for the tail, L signal, R signal, plate. When you disconnect each, both the tail and plate lights go out, reconnect, both work. When you disconnect either of the signal light plugs, the respective rear turn signal stops working and the respective front signal flashes faster, indicating a problem on the rear light. When reconnected, the front and rear goes back to flashing at a normal pace, but the rear running light still doesn't function.
I'm kind of out of troubleshooting ideas going forward. Anybody have an idea?
jimrobinette is offline   Reply With Quote
Old 06-23-2011, 10:06 PM   #22727
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,734
You got the Service Manual and checking wiring.. fuses, grounds?
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 06-23-2011, 10:15 PM   #22728
ronvan
ronvan's Avatar
Oddometer: 49
I believe what you're describing is normal behavior. The rear signals do not function as running lights.
ronvan is offline   Reply With Quote
Old 06-24-2011, 03:17 AM   #22729
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,037
Exactly correct.
Sent from my DROIDX using Tapatalk
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is online now   Reply With Quote
Old 06-24-2011, 05:03 AM   #22730
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,731
Originally Posted by Chadx View Post
I thought you chewed through a front sidewinder "lifetime" sprocket and had to get it replaced under warranty? Might have been someone else's sidewinder. Or are you saying the same chain but different sprockets?
That is correct. I had to replace the TI counter-sprocket. I'm still running the original Smart Chain and TI rear sprocket. They are fine, except the rear teeth are getting a little thin.
The 2nd TI counter-sprocket is already showing significant wear, as the teeth are becoming quickly hooked. So, those aren't working out to good up front. I've had no issues with the rear sprocket and chain. No abnormal wear on my swingarm (seal) protector. Yes, it has some wear. Yes it should be replaced before too long. But, nothing like I've seen in these posts (eating thru into the swingarm).
HF
p.s. Think I'll be trying the Supersprox combo next time around....just because I want to.
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 06-24-2011, 06:44 AM   #22731
skian g
Oddometer: 74
Tires
Just put on some new Bridgestone rubber last night. ED03 up front and ED04 in the rear. Initial reaction... They are a huge improvement in traction offroad. I can not under normal starting and then mashing the throttle break the rear tire loose in the grass (obviously dumping the clutch might produce different results but i didnt try this). The front also hooks up as well under braking, used to be able to slide the front It just grabs now, to the point that you might be able to get the rear wheel off the ground. With the stock tires riding in the grass you would have to be careful not to break it loose. These you dont have to worry about washing out on you. The short jaunt around on the road are they feel as smooth as the trailwings which I was pleasantly surprised about. We will see how they hold up and how they act under spirited driving on the road, since its a slightly taller rear tire.
I was really thinking about the D606 that most people love but at $83 the price of the Bridgestones are what ultimately sold me at $59 front and $64 rear from motorcycle superstore, but I'm pretty Impressed from what i could gather from the few "hot laps" around the yard. Sunday I will be riding some power lines with a buddy so that will be the true test of highway, back roads and trails to really get a feel for them.
2008 WR250R
Go Light! Go Fast! Loud Sucks!
skian g is offline   Reply With Quote
Old 06-24-2011, 06:53 AM   #22732
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
Originally Posted by BallsoutSHO View Post
I was really thinking about the D606 that most people love but at $83 the price of the Bridgestones are what ultimately sold me at $59 front and $64 rear.
The difference in price would have more than been made up in longevity. Dunlop D606's wear like iron. Not so with the Bridgestones.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 06-24-2011, 07:03 AM   #22733
skian g
Oddometer: 74
I couldn't really find anything on this site about any one using them, so I decided I would be the guinea pig and try them. If this is truly the case well, Ill document it for the next guy and move on the the D606s.
2008 WR250R
Old 06-24-2011, 07:33 AM   #22734
jimrobinette
Oddometer: 379
Originally Posted by DougZ73 View Post
Exactly correct.
That would be awesome if true. I replaced the whale-tale with a tiny little LED butt-tuck kit the first month I bought the bike back in 2009, and then just reinstalled it a couple of days ago. Thought I had a short somewhere.
Now, I feel like a bit of a dumb-ass, but I just assumed (yes, I know, and it's true) if the fronts worked as running lights, so would the rears.
Basher,
Yeah, I had the manual out to the exact page you posted and was checking voltages/grounds/bulbs, etc. Thanks for the clip.
Old 06-24-2011, 07:33 AM   #22735
Machtig
Oddometer: 369
HF
My smartchain is in the garbage bin at Nelson's Racing in Battle Mountain. My Ti sidewinder front sprocket is in my saddlebags. It was badly hooked as well and I replaced it with a no name brand (unpackaged) they had at Nelsons. I'll post more details in my ride report thread.
Machtig is offline   Reply With Quote
Old 06-24-2011, 07:48 AM   #22736
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,943
I'm curious if anyone knows whether these are DOT approved for DS use. I went to the Motorcycle Superstore website and the product page for the rear ED04 stated that it was "DOT/FIM approved" but the page for the ED03 front tire made no mention of whether it had the DOT rating. Does anyone know?
I've been pretty happy with the 606s, but my source just went up from $60 each to $83 each for the rear and around $72 for the front, so I'm looking around. On my WR-R I'm getting around 2,500 miles of 50/50 riding from the rear 606 and another 500-1000 from the front 606 before they become useless off road and scary on the street.
GSBS is offline   Reply With Quote
Old 06-24-2011, 08:07 AM   #22737
Chadx
Off the road again..
Chadx's Avatar
Oddometer: 2,167
Indeed it is true.
Most streetbikes, including our WRR, use the front turn signals as running lights but the rears only as turn signals. There are aftermarket kits, for various bikes, to make the rears act as running lights (though I have never considered buying one).
Chadx is offline   Reply With Quote
Old 06-24-2011, 09:56 AM   #22738
skierd
Wannabe Far-Rider
Oddometer: 2,938
I had this for sale previously, but changed my mind at the last second and reinstalled it. However I have learned in the last two weeks, thanks to two separate conversations with MD state troopers, that one of the ways that my state is attempting to make up for its budget shortfalls is enforcing taillight regulations on motorcycles. Mainly to ensure that the new speed cameras, red light cameras, and toll cameras are able to take a nice picture of your license plate and send you a nice donation form a few weeks later.
Plug and play, works and looks great on the back of the bike. Has the 12 o'clock labs integrated turn signals and flasher board. Mine was repaired and weatherproofed by 12 o'clock labs after drowning it several times last year. Comes with the red and smoked lens. The plate bracket does still mount to the frame, and a license plate will still attach with a little bending. New they're $160, asking $100 shipped.
PS the stock taillight is hideous now that the bike is a sumo. But I'd rather be ugly than hassled by the police.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 06-24-2011, 10:57 AM   #22739
jimrobinette
Oddometer: 379
Big ass tail on the WRR
I too just pulled my 12 o'clock labs light and I forgot just how big and nasty that stock whale-tail was until I re-installed it a couple of days ago.
Old 06-24-2011, 11:49 AM   #22740
Buzzbomber
Not Dr. Who...
Buzzbomber's Avatar
Oddometer: 1,271
It looks much better once you bob it...
No straight-on pictures handy.
Don't look back. Something might be gaining on you.
-Satchel Paige
Buzzbomber is offline   Reply With Quote
Times are GMT -7.   It's 05:36 PM.
