Old 08-12-2011, 08:38 AM   #23821
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by Crawdaddy View Post
Here's a video one of the riders shot....it's from the bottom of the gorge up to the rock that juts out in the trail.......I was leading the group......you can hear me on the radio once I reached the rock saying, "the risk/reward isn't there for me......I'm walking it around this rock" ........the trail goes another ~half mile from there and eventually turns up right above the gorge......
http://vimeo.com/27514516
Another perspective on the drop-off next to the rock juting out in the trail......call me a sissy, I don't care, I'm walking around it
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 08-12-2011, 08:40 AM   #23822
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Originally Posted by dirthauler View Post
yes they do, although, for the f, you will need to have the spokes made, i used http://www.buchananspokes.net/
Sounds like you went through a lot of hassle.......I'll look into Woodies/Wheeling.......may even just buy a stock rim for ~$150 and relace.........thanks for the feedback!
Crawdaddy screwed with this post 08-12-2011 at 08:45 AM
Old 08-12-2011, 08:42 AM   #23823
bhd1223
bhd1223's Avatar
Oddometer: 294
With the damage to my WR I need to replace the stock bars. I'm looking for a bend that is a little bit taller with a little bit less sweep. With my rough measurements on the stockers it appears the Pro Taper Henry/Reed bend provides this. Can those of you with this bend confirm?
I'm also debating on sticking with 7/8 or going to a big bar. Are there any pros/cons of the choice other than the obvious bigger is stronger and new bar/hand guard mounts needed?
Regarding the ends of big bars, I know they taper off the 7/8 for the controls. Do standard hand guard inserts still fit or are mods needed?
Thanks.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 08-12-2011, 08:50 AM   #23824
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Consider saving a few $$.......I have the cheapo Rocky Mtn "Chub Bars" on my bike and they''re fine......CR high Bend or ATV bend if you really wanna go high.....
http://www.rockymountainatvmc.com/pr...FamilyId=19027
Stock inserts will work on bar ends but you'll need fat bar clamps
Old 08-12-2011, 08:59 AM   #23825
bhd1223
bhd1223's Avatar
Oddometer: 294
Thanks for the advice. How does the sweep/pull back on those feel compared to stock? The height looks to be about what I want with the CR High as long as my rough measurements were good enough.
Old 08-12-2011, 09:00 AM   #23826
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,966
Thanks.
I went through that exact stuff not too long ago. I now have, after bending a couple of sets of other bars, the ProTaper henry/reed bars. Henry/Reed is the one closest to stock...thanks for my fellow ADV'ers steering me that way when I was looking.
I stuck with 7/8" myself since I already had the snazzy HDB top clamp and did not want to render it useless. Not to mention everything else on the bars is set for 7/8". The Protapers are hella thick, and strong.
I am using some Pitposse.com generic risers to get a little more height on them since I stand 90% of the time while riding.
The bar end/hand guard connector has to be for a smaller ID..inside diameter bar. Most come with both set ups. The stock bars bend like swiss cheese since they are pretty thin walled...comparatively.
Hope that helps.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 08-12-2011, 09:16 AM   #23827
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
Couldn't tell ya, I never rode with the stock bars.......took those off as soon as I got home with the bike.......want'em? I actually have a lot of stock stuff laying around in my garage that I'll likely never use.......tank, exhaust, rear tail light, etc.....
Also, I have a GPR stabilzer so my bars are lifted a bit......I went with the YZ bend....
Old 08-12-2011, 09:20 AM   #23828
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,966
I could use a set of stock blinkers, on the cheap, if you have and want to get rid of those.
Old 08-12-2011, 09:20 AM   #23829
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,204
X2 on the Chub Bars. I have those and they seem to be pretty strong and are priced right for my silly budget....
SteveO is offline   Reply With Quote
Old 08-12-2011, 09:44 AM   #23830
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
I actually still have the stockers up front.......can't seem to break'em......yet
Old 08-12-2011, 09:55 AM   #23831
bhd1223
bhd1223's Avatar
Oddometer: 294
Well I just went and took some new rough measurements of the non bent side of the stockers. Somehow my height measurement is much different.
Old Height: 4.5"
New Height: 2.75" if not a little less
My old width measurement was about 31" and I can't do a new one.
My sweep or pull back is about the same.
Old: 2.5"
New: 2.25-2.5"
Can anyone tell me if which height is more accurate? Based of these I think the YZ bend on the Chub Bar is a better option over the CR High.
Also, I was wondering if anyone has replaced the plastics around the headlight. There is the top piece then the bottom part that screws into the black frame of the headlight assembly. Well, normally it may be one piece but the top piece popped off and won't pop back on because the lower piece is a little bent and cracked on the left side. Any ideas on exactly what I'd need to replace this? I've been looking on bike bandit for the 08 R and I can't figure out if part 12 is all I need on the headlight schematic. 13 looks like it may be needed but I imagine that broke off when the top piece broke off in the crash as I don't see it anywhere. I don't care about the graphics.
bhd1223 screwed with this post 08-12-2011 at 10:49 AM
Old 08-12-2011, 09:58 AM   #23832
SteveO
Huh???
SteveO's Avatar
Oddometer: 1,204
CrawDad,
Considering that you do quite a bit of riding on your bike, what do you think about using the RimLocks?
I'm in the process of ditching the stock tires on my WR250R and mounting up a D606 in the rear with a Heavy Duty Fly tube, and a K760 Trackmaster front tire with a Heavy Duty Fly tube.
I was considering putting these Rim locks in both tires......
Are they needed? Do they help with lower pressures?
I'm not sure If i need them or not......
Old 08-12-2011, 11:58 AM   #23833
greer
Oddometer: 3,727
bhd,
Per RichardU way back on page 474:
Stock bars are 30.7" W, 3.8" H, 2.6" Pull Back.
Handy chart:
http://www.rockymountainatvmc.com/handlebarinfo.do
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 08-12-2011, 12:07 PM   #23834
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,966
I was advised when I started riding offroad, if going any lower than 15 PSI, rim locks are a good idea. That is the rule of thumb I go with. And I usually set my tires down to 14 PSI for the sand I ride in.
I know once, I got a flat, and the rim lock at least held the tire in place for me, so I could still ride it home without the tire coming off the rim.
Old 08-12-2011, 12:15 PM   #23835
Crawdaddy
Crawdaddy's Avatar
Oddometer: 2,241
RimLocks?......Are they needed? Do they help with lower pressures?
Certainly couldn't hurt......and less weight needed opposite the valve stem to balance the wheel......that said, I've never bothererd with'em on the WR (I'm lazy ).......only flats to date on WR have been on the rear tire........I can't believe I just typed that ........now I'm screwed
Times are GMT -7.   It's 02:46 PM.
