Old 08-13-2011, 07:45 PM   #23866
bash3r
I ain't no DingWeed
bash3r's Avatar
Oddometer: 1,740
Originally Posted by DougZ73 View Post
Was $60 for four, or two?? For four, it is a good price. My bad if I read it wrong.
Really, I only need one...so if you wanted to do two for $30 shipped, I could do that. left and right rear.
I think I got stockers too.. front and rear laying around here.. PM me if you're interested
08' Yamaha WR250R
09' Yamaha WR250F
14' BMW F800GSA
Adventure Tshirts | 3 Step Hideaway |Campground POIs
bash3r is offline   Reply With Quote
Old 08-13-2011, 10:05 PM   #23867
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 897
Supermoto track day. I was 1 of 2 WR's in a sea of orange. Once again, the bike was able to handle the task at hand. Even the many crashes I had in the morning sessions. In the afternoon we both stayed upright.
onetravdown is offline   Reply With Quote
Old 08-14-2011, 04:38 AM   #23868
AKASY
Noob
Oddometer: 2,170
Temp Light
Still running the modified TAT as Dual Sprting America here is the RR link if you are interested.
http://www.advrider.com/forums/showt...=710618&page=5
Yesterday I was running WFO in Nevada 77mph, almost arrow stright, sixth, 13\48 and temps were guessing around 80--just had a light rain, no traffic.
Temp light comes on after maybe 25 or so miles of this- back off about 10 mph and light goes off after a couple of minutes.
This has been reported before and this is the second time I've seen it on this triip.
Fuel low level light remains on all the time it does not initiate the fuel reserve trip meter either--will find the fix after the trip.
Some 5000+ miles into this trip with another 1000+ to go
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 08-14-2011, 09:05 AM   #23869
BadBrian
Oddometer: 31
New OwneR
I guess this means I'm in the club....
Got $3,400 tRade in on my '06 450F payed $3075 and Rode out with this...2011 250R
Not the woRlds best deal but I feel pRetty good, Really I'm just glad to finally get my R.
BadBrian is offline   Reply With Quote
Old 08-14-2011, 09:30 AM   #23870
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,744
WRelcome
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 08-14-2011, 09:40 AM   #23871
10Cup
10Cup's Avatar
Oddometer: 2,648
Bad Brian, Sweet! You won't regret it!
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 08-14-2011, 09:43 AM   #23872
bhd1223
bhd1223's Avatar
Oddometer: 294
You'll love the bike. I know I do. I recommend replacing the bars right away though. They really do bend extremely easy. When I take mine off to replace them I'll have to post up a picture.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 08-14-2011, 10:30 AM   #23873
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,252
If you ever want to run heated grips you'll want to retain the OEM steel bars. Aluminum bars act as a heat sink more than steel.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is online now   Reply With Quote
Old 08-14-2011, 10:37 AM   #23874
RichardU
Let's Ride
Oddometer: 903
You can run heated grips on aluminum bars, just won't be quite as hot. Helps to have insulation under the heater on the clutch side. Friction tape works.
RichardU is offline   Reply With Quote
Old 08-14-2011, 11:02 AM   #23875
tonymorr
Malta,NY(Saratoga Spring)
tonymorr's Avatar
Oddometer: 2,513
I bought my heated grips from Dual Star. They reccommended (and I bought) a length of heat shrink tube for the clutch side. They keep my hands warm when riding on the ice so I guess they work good enough!
2013 Multistrada 1200ST - 2013 Honda CB500X - 2014 Honda CTX700
2011 Husaberg FE 390 - 2014 Honda Grom "Napoleon" - 2014 Honda Grom "Lucy"
'07 Mutant Ninja II (sold)click for build report - 2008 Yamaha WR290R (sold-not sure why)
2013 Piaggio BV350 (sold)
tonymorr is offline   Reply With Quote
Old 08-14-2011, 12:23 PM   #23876
Bee
Ride On Brother
Bee's Avatar
Oddometer: 113
Question New handelbars
Posted by BluePill Last November "NOTE ON ANY BAR CHANGE: The stock bars have two indexing holes on the right side to align the throttle and switch unit. You will have to either drill the new bars to match, or (what I did) grind off the tabs on the housings."
I am at this point right now and am wondering what others have done. Easiest is to grind off the tabs - but once you grind there's no going back! BluePill have you ever had any problems with the throttle cable housing or switches slipping?
2008 WR250R; 2008 Wee-Strom; 1967 Honda 305 Scrambler CL77; 1969 DT1 MX conversion; 1969 DT1 project; 1975 DT 175 Project
Bee is offline   Reply With Quote
Old 08-14-2011, 12:23 PM   #23877
bhd1223
bhd1223's Avatar
Oddometer: 294
Fair enough but make sure the bars never touch the ground. I suppose triple clamp mounted handguards may help but the OEM steel bars bend easily.
Old 08-14-2011, 12:34 PM   #23878
bhd1223
bhd1223's Avatar
Oddometer: 294
Just grind/file them off. I'll be doing that once I decide on the bars I'm getting to replace my bent stockers. I've done it on other bikes with no problems. When you adjust all the controls to yourself you'll find everything "pinned" needs to move as well to retain the same easy activation movements. I was so lazy when I did this on the stock bars I just loosened them up until I could pull the pin out then just tightened them back down elsewhere, I didn't file off the pins. I had the turn signal box pivot on me once. Some people like to put electrical tape under these "de-pinned" items so they have something to dig into and grip as opposed to the smooth plastic on smooth metal. Others like to put teflon tape under everything on the bars so it spins easier even when tightened down. I don't do either. Usually for the electrical switch boxes I just grind/file the pins and then attach them and tighten them to the point they don't move without some effort forcing them. It's easy enough and works.
If you never plan on moving your controls then I guess pinning them may work but if you want to try different bar positions you'll be rotating everything around drilling a lot of holes thereby weakening your bar. Just leave the bars as they come. What's the worst that happens? Your turn signal box spins on the bar when cancelling the signal and you have to grab it to correct it's position before activating the signal again?
bhd1223 screwed with this post 08-14-2011 at 12:39 PM
Old 08-14-2011, 12:46 PM   #23879
RichardU
Let's Ride
Oddometer: 903
I have ground off the pins on about a dozen bikes. No problems. Use friction tape under if you need more grip. If you drill a hole, it will probably not be in the right place, or you may decide to adjust your bars later, and you're stuck.
Old 08-14-2011, 12:49 PM   #23880
craftycoder
Motobrain PDU
craftycoder's Avatar
Oddometer: 2,334
Agreed
craftycoder is offline   Reply With Quote
Times are GMT -7.   It's 05:57 PM.
