Old 08-17-2011, 04:37 PM   #23956
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,766
Originally Posted by Rufjeep View Post
Hardworking Dog...I didn't mean anything remotely antaganistic in my response to you about the programmer. I appreciate your feedback...
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is online now   Reply With Quote
Old 08-18-2011, 05:01 AM   #23957
big-t
Oddometer: 490
How do I get out of the diagnostic mode ??
I was adjusting the EXUP cables and did the "hold 2 buttons down,switch on,toggle to Diag and hold the 2 buttons down to confirm diag mode.Then went to test 53 and worked the EXUP. After I finished, my understanding is when the switch is turned off the pcm exits the diag mode.Not happening..
Now when I do the "two buttons down,turn switch on " it goes to the Diag mode and I can't get it back to the Co mode.
Probably got the sequence wrong or something like that...any one else have this problem??
Anybody know what I'm doing wrong ??
big-t is offline   Reply With Quote
Old 08-18-2011, 05:22 AM   #23958
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,977
My experience...
Originally Posted by mordicai View Post
I would not open the airbox and put a flow through muffler on my WRR without using a programmer, unless I wanted to try and put holes in my piston.
Added FMF PC4 pipe - no programmer - at 8K miles. Simultaneously removed EXUP and AIS stuff, opened up airbox, added K&N air filter. Went into CO mode and rode the bike, set CO, rode some more, tried another setting, etc. etc. Ended up running best at +4 (factory setting was at -3 or -4). Checked spark plug 100 miles later and it looked just right (not too light or too dark).
The bike absolutely rips. I can't think of a place in the powerband I'd change. So I see no need for a programmer.
FWIW, the bike is now at nearly 15K and it's been run hard (often up against the rev limiter). Not a hiccup. YRMV, but that's my experience for almost 7K miles without a programmer.
GSBS is offline   Reply With Quote
Old 08-18-2011, 06:05 AM   #23959
Rufjeep
Oddometer: 395
How much di dyou open your airbox? Flapper mod or even more than that?
Rufjeep is offline   Reply With Quote
Old 08-18-2011, 06:15 AM   #23960
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,977
It now has no top. Removed flapper completely.
BTW, the bike actually runs cooler since doing the mods. The radiator fan seldom comes on unless it's really hot and I'm barely moving. Before removing the EXUP, AIS and opening airbox, adding pipe, it would come on much sooner.
Old 08-18-2011, 06:37 AM   #23961
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,798
I missed the memo. How do you go into CO mode on the dash. Is there a "how to" in the shop manual?
Hate gets you nowhere.
Old 08-18-2011, 06:46 AM   #23962
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,255
Further, how do you set CO mode on a US model with no O2 sensor??
Did you have one added on?
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 08-18-2011, 06:56 AM   #23963
GSBS
FunHog
GSBS's Avatar
Oddometer: 3,977
I posted a detailed how-to...
...here several months ago in this thread. Mine is a 2010 model. A buddy who showed me how to access the CO mode has a 2008 model and the procedure was the same. I have no idea if there's anything in the shop manual about this. I have one, but never looked. Just followed my buddy's instructions. He'd had his set up like this for about a year or longer when we did mine in February.
We did have to jump a wire to ground from the lean angle sensor to allow us to access the onboard diagnostics mode.
GSBS screwed with this post 08-18-2011 at 07:09 AM
Old 08-18-2011, 07:14 AM   #23964
bhd1223
bhd1223's Avatar
Oddometer: 294
In the service manual Diagnostic Mode states:
Turn main switch to off and engine stop switch to on. Disconnect fuel pump connector. Press and hold Select 1 and Reset, while holding them turn main switch to on and continue holding them for 8 seconds or more. Clock and trip should be only thing displayed. dlAG appears on the clock. Use Select 1 to select the CO or dlAG modes. After selecting press the Select and Reset buttons for 2 seconds or more to execute. The rest goes on to explain the diagnostic stuff and not CO settings but I think I read about those just using Select 1 and Select 2 to adjust the setting. I'm not sure how to save them or exit after selecting but it might be the same as the link provided above.
I suspect this is another way to get to CO mode without jumping anything.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 08-18-2011, 08:06 AM   #23965
Reposado1800
Juicy J fan!
Oddometer: 5,798
Thanks guys! That is what I was looking for. Sure is cool to be able to adjust the mixture from the dash. Bike value just went up.
Old 08-18-2011, 08:21 AM   #23966
bigdon
Oddometer: 2,653
Running my stock WR yesterday afternoon. Ran about 4 miles at 1/2 throttle then hit highway back home. Running full throttle in 6th gear for about 1 mile then shifted to 5th. Ran at full throttle for about oth 3/4 to 1 mile and hot light comes on. I let of throttle to about 1/2 or less and hot light went out in about 30 seconds. I was running slightly uphill and the ambient temperature was 106f.
Do I have a problem?
I am going to check water level and fan this afternoon.
Radiator fins are clean.
What else?
Thanks guys, going to Western TAT at end of month and would rather not worry about bike getting hot. I have run it hard many times with never a problem. Why now?
ADV Relay Rider 08 (The Texas Connection)
Ride Pooie Ride
Don't stop riding until you get to the crash , you might save it!
bigdon is offline   Reply With Quote
Old 08-18-2011, 08:29 AM   #23967
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,107
Question for those running a No-Toil Filter. I got one the other day for my WR250X, but noticed it's a bit different than other No-Toil Filters I've seen which have a hole in the filter and then part of the cage goes through that hole with a piece that holds the filter to the cage (see pic below). The one I got for my WR250X doesn't seem to have that though. There is a hole in the filter itself, but the cage doesn't have any provisions to "attach" to the filter. Is that the way yours is?
GotMojo? is online now   Reply With Quote
Old 08-18-2011, 08:30 AM   #23968
Krabill
Krabill's Avatar
Oddometer: 4,893
What else?
A lot of people remove the plastic shroud from behind the radiator. I have removed mine and my bike sees plenty of high rpm, slow speed, single track use in the Oklahoma heat and I have never had my temp light come on. You might want to try removing that while you're checking fluid levels and fan fuses.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 08-18-2011, 08:35 AM   #23969
debaisley
debaisley's Avatar
Oddometer: 1,424
I dont think the fan coming on at highway speeds would do anything for the cooling of the bike anyways, i was also going to suggest removing the shroud behind the radiator.
debaisley is offline   Reply With Quote
Old 08-18-2011, 09:10 AM   #23970
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,255
I have a NoToil air filter and do not recall anything going through the filter( could be I am forgetting it). I use the stock cage in the inside and stock locking down mechanism on the outside. Shape of cage and hole in airbox holds everything snuggly in place.
Times are GMT -7.   It's 08:31 PM.
