Old 10-03-2011, 07:42 AM   #24796
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
How much "hard riding (sand/climbing)" distance are you guys getting on the 3.1 tank?
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 10-03-2011, 07:59 AM   #24797
rydnseek
rydnseek's Avatar
Oddometer: 5,888
Originally Posted by Neonguy95 View Post
Has anyone experienced trouble with the fuel pump working and then not working? A couple of times now I have come out after work to a fuel pump that won't turn on. Smack the base of the tank and turn switch, tada works.
Today went on a ride with the wife, her on her XT. 30 miles from the house the WR dies. Fuel pump won't turn on. Disassemble unplug the pump and check nothing. Tap around nothing. Hit with force nothing. Wife leaves to get the truck. Load the bike still nothing. Get home unload the bike, fuel pump kicks on bike starts.
7300 on the clock still have warranty so it is going in, but has anyone experienced this?
Thanks.
Sent from my MB860 using Tapatalk
Are you sure it is the fuel pump? If you've re routed wiring on the handlebars, sometimes the connector coming from the starter switch gets too tight, & the plug pulls out.. i had an intermittent problem with this once.. drove me crazy to find it. It happened again last week, but i suspected it right off. The dash lights come on, but no fuel pump, & the starter won't turn over.
If your starter turns over, but just no fuel pump sound, then that is probably not it. But if you don't have starter or fuel pump, that wire might be suspect. I ended up re routing the wire so it went on the inside of the bars & it has plenty of slack. The plug is under the radiator.. have to move the tank back, take off the radiator bolts, then get at the plug underneath.
rydnseek is offline   Reply With Quote
Old 10-03-2011, 08:17 AM   #24798
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,103
Originally Posted by Krabill View Post
Finally edited the video from the race. Most of the footage is from the 1st lap since that was before the camera started fogging over.
1st lap - 38 minutes - 5th place
2nd lap - 35 minutes - 2nd place
3rd lap - 35 minutes - 3rd place
4th lap - 35 minutes - 2nd place finish
Awesome stuff Krabill! Brings back memories of when I used to race motocross and did a few hare scrambles one sumer. Man do I hate trees LOL!
What tires (and sizes) were you running that day?
GotMojo? is offline   Reply With Quote
Old 10-03-2011, 08:36 AM   #24799
Krabill
Krabill's Avatar
Oddometer: 4,830
I didn't change anything for the race, so the bike was set up the same way I always keep it.
13/47 sprockets
D606 tires
90/90-21 front
120/90-18 rear
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 10-03-2011, 09:00 AM   #24800
Neonguy95
Self Sponsored Rider
Oddometer: 300
Starter turns over, fuel pump does not kick in. The times it has happened at work I could hit the tank a few times and it would turn on. This last ride however it died while I was on it. Cycled the key and nothing.
Shop is closed this am, but I plan on taking it in tomorrow. Since it is now working guess I will take them the video I was shooting as proof.
2010 WR250R
2010 XT250 (Wifes)
2012 Super Tenere (Black)((The fast one))
Neonguy95 is offline   Reply With Quote
Old 10-03-2011, 09:14 AM   #24801
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 571
12v
I only expect to use it for light duty (GPS, phone) so I wired it into the headlight since I wanted it switched too. It sits inside the Wolfman Enduro tank bag & stays on/dry in the rain. A 2nd heavy duty fused/wired to the battery unswitched connection for Gerbings heated gear comes out on the left & tucks behind the seat. I don't know if you need to consider waterproof use. I hope to be at Recompence, see you there maybe?
Originally Posted by dirthauler View Post
anyone do a cigarette lighter 12v power outlet? thinking that inside the left side faring???
"Four wheels move the body,
Two wheels move the soul." http://ridingacross.com/
Three move you & the dog!
Cromoth is offline   Reply With Quote
Old 10-03-2011, 09:22 AM   #24802
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 890
The only decent picture from the Hare Scramble.
onetravdown is offline   Reply With Quote
Old 10-03-2011, 09:47 AM   #24803
Sock Monkey OP
Corporate slave
Sock Monkey's Avatar
Oddometer: 2,084
Nice vid, and way to represent on the WRR!
Two questions: Did you figure out where the leak was that was causing the camera fogging? I'm debating Contour vs. GoPro.... Also, what bikes were the other guys in your class riding? Looked like maybe a Husky and a couple KTMs?
Thanks again!
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R
Gone: Ducati Multistrada, Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-03-2011, 09:53 AM   #24804
onetravdown
I can't ride where?
Oddometer: 890
Great Vid Krabill! That course looks fantastic compared to the slop we rode in yesterday.
Old 10-03-2011, 09:55 AM   #24805
skierd
Wannabe Far-Rider
Oddometer: 2,909
My worst MPG's on the WR came from high speed slab riding, averaging 45-50mpg netting me a maximum range of 150 miles. As in I filled up with 3.098423 gallons at 150 miles on the nose. With a programmer you might be able to drain the tank faster since you'll be adding more fuel, but I think at the worst worst you could expect would be 120-130 miles.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 10-03-2011, 10:24 AM   #24806
Krabill
Krabill's Avatar
Oddometer: 4,830
Thanks again!
-SM
I'm 99% sure there was moisture in the housing before I closed it up in the morning. It sat in the open air all night and it got pretty cool that night. Most everything that was sitting out had moisture on it in the morning. Being sealed up in the housing when the sun started coming up and warming everything caused the condensation in the housing. I don't think it leaks at all, the moisture was in there before I closed it up. Just didn't think about it.
From what I've seen, the video from the Contour is better quality than the GoPro, but all my friends have GoPros so I just went with that for consistency.
As far as the other bikes go, there were a couple KTM's, one Honda, and a Kawasaki. The winner was on a Honda.
Finishing order:
1st - Honda
2nd - Yamaha (me)
3rd - KTM
4th - KTM
5th - Kawasaki
Loud Sucks!
Old 10-03-2011, 10:24 AM   #24807
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,969
And my one shot...pre the mudfest of the rest of the track.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 10-03-2011, 12:40 PM   #24808
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,103
Was just reading a ride report from a guy with a WRR who encountered the problem with the chain eating through the bottom of his swingarm and it got me to thinking....
I've lowered my WRR with the stock lowering option, and might install a Yamalink to lower it some more. I am on the stock chain/sprockets right now, but will probably go to a 14t front sprocket at some point. Does anybody think that lowering the WRR can add to this chain-eating-the-swingarm problem?
Old 10-03-2011, 01:27 PM   #24809
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,246
I think the general consensus is it's the 12 tooth counter shaft sprocket along with too tight a chain is the culprit.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 10-03-2011, 01:39 PM   #24810
AKASY
Noob
Oddometer: 2,167
Cig
Just a heads up---I used those same cig adapters. Sooner or later a little water will get in--it then corrodes and shorts the center electorode to the side wall and sits there draining the battery. Want to know how I know
Originally Posted by MoBill View Post
Did mine this way HDP top clamp:
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Times are GMT -7.   It's 05:22 AM.
