Old 10-14-2011, 10:14 AM   #25021
eyty
Oddometer: 4
No Start
Engine light during cranking is normal
EyTy
eyty is offline   Reply With Quote
Old 10-14-2011, 10:23 AM   #25022
greer
Oddometer: 3,505
Thank you!
After a few minutes on the charger it swapped from "charging" to "charged" after two qiuck attempts to start it went back to "charging."
Still no start but it turns over like the dickens. I know these FI bikes don't like a low battery so it's got me wondering. Thanks again.
Sarah
'08 DR650
greer is online now   Reply With Quote
Old 10-14-2011, 10:36 AM   #25023
debaisley
debaisley's Avatar
Oddometer: 1,388
mine didnt start like that once , everything seemed normal but it just keep cranking and didnt fire. I then held the throttle wide open and started cranking it and after a few revolutions it started up , has never had that problem since , i dont know what would have caused it.
debaisley is offline   Reply With Quote
Old 10-14-2011, 10:43 AM   #25024
Sock Monkey OP
Corporate slave
Sock Monkey's Avatar
Oddometer: 1,555
Originally Posted by greer View Post
Thank you!
Sarah
Has anything changed? New fuel cap, removed the tank, adjusted the TPS, etc? No fuel or too much fuel are the first places I'd look. Next would be spark. If you've got fuel and spark, you should get kaboom.
-SM
aka NoVector
Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad
Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on.......
Sock Monkey is offline   Reply With Quote
Old 10-14-2011, 10:44 AM   #25025
simmons1
simmons1's Avatar
Oddometer: 643
+1
I have to do this a couple times also. My 2008 still has the original battery.
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, H2 750
simmons1 is offline   Reply With Quote
Old 10-14-2011, 11:28 AM   #25026
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,011
Thank you!
Sarah
Still have the OEM fuel pump? Do you hear the pump priming? Try recycling the key?
'13 KTM 500 EXC, '08 Yamaha WR250R, '08 Kawasaki KLR650 (Sold), '04 CRF250X (Sold)
Member AMA, NETRA, MVTR, CCCOFVT
Stealth is good! Noise annoys!
Nice_Rumble is online now   Reply With Quote
Old 10-14-2011, 11:39 AM   #25027
HighFive
Bike-aholic
HighFive's Avatar
Oddometer: 2,064
This happened to me for the first time just yesterday. But, I got it going by adding a little fuel (about 1/4 turn of throttle). I didn't try wide-open....didn't need to.
Restarted just fine later with no throttle input.....just letting it idle, as normal.
Didn't worry about it, didn't give it anymore thought until reading this post. What a coincidence!
If it pursists, I will simply make an adjustment to my Power Commander V fuel programmer to add a little more fuel at TPS = 0 - 5 % range. Easy to do on a PC unit....can't do on an FMF unit. But there is probably another adjustment that would fix it (in the CO mode of the OBC, or by turning up the idle screw on the throttle body).
HF
FYI....gasoline fuel formulations will begin to change from summer blend to winter blend during the fall. This sometimes can affect engine performance (a little). Its plausible that could be a factor. Your ECU will make adjustments over time to adapt to the fuel somewhat (if its smart enough.....I donno). Just thought. I was a refinery engineer once upon a time....FWIW.
HighFive is offline   Reply With Quote
Old 10-14-2011, 12:10 PM   #25028
ironbrewer
Hopefully Riding
ironbrewer's Avatar
Oddometer: 3,801
Originally Posted by jon_l View Post
Gotta love penny-tech.
Note that brass and aluminum don't get along (galvanic reaction). Alum or painted steel spacers would be better.
Thanks for the info. I knew about galvanic reactions, but I just didn't associate it with mostly dry conditions. I guess I'll have to get some aluminum standoffs.
"All the problems we face in the United States today can be traced to an unenlightened immigration policy on the part of the American Indian."
Pat Paulsen
ironbrewer is offline   Reply With Quote
Old 10-14-2011, 12:39 PM   #25029
greer
Oddometer: 3,505
This exactly! I have absolutely no idea what the trouble could have been. I've shut it off and restarted it several times over the last few minutes and it fires right up. Beats the heck out of me. I did take out the iridium plug and swap back to a factory plug I took out at last change, but it still wouldn't fire til I held the throttle open. Thanks so much for chiming in everybody, whew what a relief.
Sarah
'08 DR650
Old 10-14-2011, 01:21 PM   #25030
sturgeon
sturgeon's Avatar
Oddometer: 744
Am I imagining this, or did you recently mess around with your TPS? If so, I wonder if that has any bearing?
sturgeon is offline   Reply With Quote
Old 10-14-2011, 01:33 PM   #25031
Lee Dodge
Oddometer: 227
You may want to check your idle rpm setting. I had this happen on my Vstrom. It would crank without starting until I opened the throttle. Turned out my idle setting had dropped over time. Turned up the idle to factory specs, no problems since.
05 DL650
Lee Dodge is offline   Reply With Quote
Old 10-14-2011, 01:41 PM   #25032
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 266
TPS is at 15, which is the low end of the spec from what I gather. Should I mess with it, or is there a chance I can cure the off idle snatchyness with playing the CO mode and Powerprogrammer....???
'08 WR250X with X and R setups
'08 KTM 300xc-w
'01 KTM 520EXC - Dirt/Street/Tard <-- RIP....you will be missed
jgino157 is online now   Reply With Quote
Old 10-14-2011, 02:01 PM   #25033
greer
Oddometer: 3,505
Now I could be wrong, but after the replies here, and over on the WR forum, I think it's just one of those things that happens sometimes.
I've put nearly 2,000 miles on the bike since the TPS adjustment with nary a hiccup. I've been super-pleased with the results of that little trick and just wish I'd done it earlier, like day one. It made the bike feel better than any of the high dollar mods I've done. I'm thinking the variation in TPS settings from bike to bike is why some of us complained so much about the on/off throttle snatch while other folks said they'd never noticed it.
jgino--- it's a piece of cake to adjust the TPS, no jumper wire, just push a few buttons. You can peck it back the other way if you don't like it. But I'm betting you will.
Sarah
'08 DR650
Old 10-14-2011, 02:30 PM   #25034
GotMojo?
GotMojo?'s Avatar
Oddometer: 4,042
Noob GPS wiring question
Noob GPS wiring question.... I have a Garmin 60CSx that I'd like to run off the bikes battery. I bought this Garmin 4 pin round Direct To Battery Harness but then got to thinking. If I use this piece to hook up the GPS, won't it be running off the battery all the time even when the key is not on, and if I accidentally leave the GPS on when I'm away from the bike, it could drain the bikes battery?
Wouldn't it be better to wire the GPS so that it only comes on when I turn the key on?
GotMojo? is offline   Reply With Quote
Old 10-14-2011, 03:08 PM   #25035
debaisley
debaisley's Avatar
Oddometer: 1,388
I wired my 12v plug to the front running lights ,they are only on when the bike is running.
Times are GMT -7.   It's 04:41 AM.
