Old 10-15-2011, 06:21 AM   #25051
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 760
Originally Posted by jgino157 View Post
Trying to tap it counterclockwise with whatever I can wedge in there. Doesn't want to budge and I've marked up the plastic housing. It is the black thing with wires coming out towards the rear of the bike, and held on with security tor bits, right??? Right side right next to the frame.
In my original post I loosened the throttle body clamps and were able to work it loose and move it to the side a little bit. This enabled me to get a security torx bit in there to loosen the screws and adjust it. I really would not suggest mangling the housing of the TPS as it is a little expensive to replace..
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 10-15-2011, 07:04 AM   #25052
Krabill
Krabill's Avatar
Oddometer: 4,888
Originally Posted by debaisley View Post
i wired my 12v plug to the front running lights ,they are only on when the bike is running.
+1
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 10-15-2011, 07:48 AM   #25053
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,172
Electrics...
Originally Posted by GotMojo? View Post
Noob GPS wiring question.... I have a Garmin 60CSx that I'd like to run off the bikes battery. I bought this Garmin 4 pin round Direct To Battery Harness but then got to thinking. If I use this piece to hook up the GPS, won't it be running off the battery all the time even when the key is not on, and if I accidentally leave the GPS on when I'm away from the bike, it could drain the bikes battery?
Wouldn't it be better to wire the GPS so that it only comes on when I turn the key on?
I didn't want to tap into the headlamp so used two Gerbings harnesses I had laying around. One powers my heated clothing off the battery, and then I tapped into that with another one to power my 60csx up front. Each has it's own fuse.
All my connections are the pigtail style plugs you find on heated gear. I have a 4 pin Garmin cable with a pigtail that plugs into the harness outlet ziptied to my bars. I pull the plug at night or when I'm off the bike a long time. The GPS battery keeps it powerd up if you don't want to turn the GPS off.
I ended up using heated glove liners from Powerlet, rather than heated grips. As a result, I have no 'switched' circuits to power anything. Am happy so far.
I've been wearing the heated glove liners under some medium weight Black Diamond mountaineering gloves. Pretty slick solution. I haven't tried them under my scooter gloves, which is what I normally wear.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-15-2011, 07:53 AM   #25054
jgino157
Yer' mom!!!
jgino157's Avatar
Oddometer: 455
Ok, one tap in right place and I'm 16/99.......I know I don't want a 100 on the top end, but why did I only jump only one on the low end? Any trick to bumping just the lower number up???
'06 Wee-Strom
'08 WR250X with X and R setups
'08 KTM 300xc-w - Plated
Colorado 2012
UPAT 2011 2014
jgino157 is offline   Reply With Quote
Old 10-15-2011, 09:14 AM   #25055
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
Originally Posted by bhd1223 View Post
I also need to find a tach so I can set the idle properly. It seems a bit low but without a tach I just don't know.
"6. Now start the bike. At the top left you'll have a digital tachometer. Also, while in this mode no mileage is recorded on the odometer."
From GSBS: http://www.advrider.com/forums/showp...ostcount=19822
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is offline   Reply With Quote
Old 10-15-2011, 12:31 PM   #25056
Cycle Sector
Aka Disco
Cycle Sector's Avatar
Oddometer: 75
Ive got a X with a SM Pro dirt setup. This thread is huge! Can you guys give me a breakdown of some of the best mods you guys have come up with? Id love to see what else I can do to my bike
Cycle Sector is offline   Reply With Quote
Old 10-15-2011, 01:48 PM   #25057
bhd1223
bhd1223's Avatar
Oddometer: 294
How do you guys find this stuff? Is there a way to place sticky notes on pages? Haha. There are so many pages it's tough to find those little bits of info you read that seem handy now.
WR250R - perhaps the ideal motorcycle for myself
Throw in a passenger and I'm unsure of what I'd consider ideal. Maybe a Multi?
I am now for sure sold on the Dual Sport style bike.
Keeping the Vulcan for now. The ladies seem to love it.
bhd1223 is offline   Reply With Quote
Old 10-15-2011, 02:08 PM   #25058
onetravdown
I can't ride where?
onetravdown's Avatar
Oddometer: 897
Looks like you already have a good start! Best mod you can do.....suspension!!!!!
onetravdown is offline   Reply With Quote
Old 10-15-2011, 02:19 PM   #25059
scottmac
scottmac's Avatar
Oddometer: 1,760
Looks nice - getting rid of the passenger pegs and seat strap would help the MX look.
Have you removed the XUP motor completely and done the relay? Added a fuel programmer?
Two things that would help you shave some weight and gain performance.
scottmac is offline   Reply With Quote
Old 10-15-2011, 02:59 PM   #25060
ArmyJoe
ArmyJoe's Avatar
Oddometer: 1,223
Originally Posted by ArmyJoe View Post
A few days ago, I took my WR250R out for my first adventure trip. I was with a few big bikes and they were impressed with my ability to keep up on the highway (75 MPH according to them). At high speeds, I have an occasional slight wobble, but I'm not sure if that's really the bike itself or a by-product of riding without a windshield. On gravel, I found the bike very manageable, almost like a large mountain bike. I almost dropped it once because it's too high, but it's light weight enabled me to hold it off the ground while I recovered my footing.
Pictures here:
http://www.advrider.com/forums/showp...ostcount=40590
http://www.advrider.com/forums/showp...ostcount=40612
I wear jeans with a 30-inch inseam and at the factory height, I'm on tip-toes wearing heavy combat boots. I bought a lowering link and plan to install that and do the factory lowering option this weekend. The combination of the two mods should net me about 2 inches. If you want, I can post pics of the before and after foot placement.
I installed my Yamalink today and did the factory lowering option. Here's the before:
Here's the Yamalink:
And here's the after:
2009 Can-Am Spyder RS, 2008 Yamaha WR250R
My latest adventures detailed at ArmyJoe's Perpetual Picture Thread:
http://advrider.com/forums/showthread.php?t=888783
ArmyJoe is offline   Reply With Quote
Old 10-15-2011, 05:13 PM   #25061
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,172
Maybe I should go back to stock height!
Old 10-15-2011, 05:42 PM   #25062
EverydayRiding
Year round riding
EverydayRiding's Avatar
Oddometer: 95
looking for some WR250X wheels
I have a '08 WR250R and would like to get a set of X wheels. Send me a PM if you have some or know of a good deal somewhere. thanks!
SV650, WR250R, Ural, R1150GS, Super9
Motorcycle Blog: http://everydayriding.org
http://www.youtube.com/EverydayRiding
@EverydayRiding
EverydayRiding is offline   Reply With Quote
Old 10-15-2011, 06:18 PM   #25063
brentde3
Should be outside
brentde3's Avatar
Oddometer: 574
Geez, this thread is huge.
I'm gonna go have a look at an '08 WRR this weekend. The owner says the bike has 3700 miles and is bone stock. Can you all give me some advice as to what to look for? Standard stuff like chain and sprockets, I know, but are there any WRR specific things to pay attention to?
2012 Honda NC700X ; '90 PW50
IBA# 49512
brentde3 is offline   Reply With Quote
Old 10-15-2011, 06:23 PM   #25064
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,737
Suggest: WRRdualsport.com
Nice decal job, BTW.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 10-15-2011, 07:40 PM   #25065
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,797
See if the fuel pump has been replaced. If not, it will probably need it.
Hate gets you nowhere.
Times are GMT -7.   It's 01:27 AM.
