Old 10-28-2011, 06:34 PM   #25411
10Cup
10Cup's Avatar
Oddometer: 2,609
More WRR Problems
Well my trusty WR let me down as mentioned earlier, I had thought the rectifier/regulator was bad but when I go the new part that did not fix it. Here is what I found.
Fried stator, I noticed the voltage dropping some the last few rides so was watching it and went out to ride last weekend and it was not charging,
thus the testing and rectifier/regulator change out. Problem now is the stators are on back order from Yamaha until Nov. 8th!
Fortunately I have a friend (JoeNuclear) that was not riding his WR and so let me barrow his until my parts come in. Thanks a million Joe!
For those inquiring minds, I had 35,000 miles on my WR.
Here is the rest of the business behind the stator and cover.
10Cup - WR250R - BMW R1200GS
Trails of the West 2011 Moab/Western TAT 2010 Continental Divide Ride 09 Route 66 Ride SPOT Tracker
The cost of living's going up, and the chance of livin's going down.
10Cup is offline   Reply With Quote
Old 10-28-2011, 07:02 PM   #25412
sturgeon
sturgeon's Avatar
Oddometer: 928
Originally Posted by WW Ronin View Post
Dont know about as a tank bag (I hate tank bags), but I'm using the Kreiga 5 up on my front plate above the headlight. ( Pics on page 1696, post #25426.) It also bolts down to the front fender well, I just like it better up above the light.
Dan
Thanks, know what you mean. I like a tank bag on my bigger bikes but I'm starting to think it's not such a good idea on this little tank. Might have to rethink the whole thing.
Do you find the US-5 blocks any light from the headlight? Can't tell from the photo. That looks like a decent setup.
sturgeon is offline   Reply With Quote
Old 10-28-2011, 10:05 PM   #25413
Ronin ADV
Gear addict
Ronin ADV's Avatar
Oddometer: 594
No problems at all. At least not that I notice.
But then again I dont do a lot of night riding. I'm sure I could have mounted it even higher as the weight of the bag will pull it down some if you keep heavy things in it. I keep my tire repair stuff (irons, CO2, patches) and my paperwork in that bag. You can definitely reach it easy from the seat so you could use it for typical tank bag stuff. I originally had it on the fender but it bounces around more in that spot I think.
Dan
Dan
2010 BMW F800GS, 2011 Yamaha WR250R, 2011 Honda Ruckus, 2013 KTM 500 EXC
Up the WABDR, F800GS Stealth Bike Build, WR250R Scotts Damper Install
Red dirt, rocks and sand; Riding the southern UTBDR, WR250R vs EXC 500 - a comparison
Ronin ADV is offline   Reply With Quote
Old 10-29-2011, 03:30 AM   #25414
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
I would not call that a let down. Maybe you are being facetious.
My TAT trip in 2014: http://advrider.com/forums/showthread.php?t=998193
SR1 is offline   Reply With Quote
Old 10-29-2011, 07:50 AM   #25415
sturgeon
sturgeon's Avatar
Oddometer: 928
Dan
Thanks! Might have to give it a try.
Old 10-29-2011, 08:17 AM   #25416
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,209
Mike, facetious?
35K on a very well maintained bike and it quits in peak Fall riding season. Yeah, I'd call that a let down.
The word "good" has many meanings. For example, if a man were to shoot his grandmother at a range of five hundred yards, I should call him a good shot, but not necessarily a good man. ~G.K. Chesterton
joenuclear is online now   Reply With Quote
Old 10-29-2011, 08:41 AM   #25417
rydnseek
rydnseek's Avatar
Oddometer: 5,888
Seems like a rash of bike issues.. when it rains, it pours. Sarah's bearing, 10cup's stator.. even my much lower mile bike had a problem.
First, an alum. sprocket i put on less than 2k miles back is already getting pointy & hooked. I had a nice 7075 renthal on my drz & it lasted longer than the front steel one. But all sprockets are not equal, so it's back to a nice inexpensive steel one. My riding style usually gets 10k + miles from chain & sprockets.
Then, the darn tires are getting worn.. after only 10k miles! ..cheap junk. So i replaced them with the exact same tire.. shinko 244's.
But the most serious issue was leaking front fork seals. They have been leaking for months, but due to my extremely busy schedule & chronic laziness, i didn't get around to replacing them. They started squeaking in Utah, so i poured in a bit of oil to keep the rest of the forks alive until i could change them. A couple of days ago, my riding buddy Tom wanted me to come over & do a bike workathon. We also added some neoprene socks to the forks. I figured all the dirt, mud, etc might have contributed to the fork seal leak. But with Tom's expertise & my blazing work speed, we got all the work done in a few hours.
A couple of tips for replacing fork seals: These are both from AZTom, a fellow wrr rider from prescott.
1. after removing the clip that holds the seal in place, use the weight & momentum of the forks to knock the old ones out. Just slide the fork in then pull it out quickly until the seal pops out.
2. Tom used a piece of abs plumbing pipe.. 2", sawn in half, about 3" long. This was to set the new seal in place. You have to tap on the plastic pipe until the seal is seated. Of course, you can buy a special tool to do this, but the pipe worked perfectly, & the edge fits the seal & doesn't cut or damage it. Once the seal clears the ring clip slot, it is in place. It won't go further, anyway.
So i got new shoes, new socks, & new teeth for my wrx. After it's grueling utah ride, it needed some tlc. Now i just need to find some time to ride it!
scotty
PS. Please note the attempt at dry humor.. i don't really want to have to put a disclaimer in every post i make.. e.g., i don't really think motorcycle luggage is an absolute, one size fits all discussion.
rydnseek is offline   Reply With Quote
Old 10-29-2011, 08:52 AM   #25418
strongbad
Oddometer: 482
Fried stator...
Is your electrical system stock? I wouldn't ask to borrow anybody else's stator until I found out what caused the first one to fry. There's a good chance you'll toast your buddy's stator too.
If you're a little ambitious you can rewind the stator with a few dollars of magnet wire. A local shop that rewinds electric motors will have the wire. Number the poles, take pictures as you unwind, count the turns on each pole, and use the pictures and your notes as a guide to re-wind.
strongbad is offline   Reply With Quote
Old 10-29-2011, 06:41 PM   #25419
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,776
The hot oil attacks the wire insulation. It is just about inevitable.
Hate gets you nowhere.
Old 10-30-2011, 01:51 AM   #25420
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,671
To prepare for said inevitable...
If anyone with a failed Stator would like to sell it to me for the price of a core and shipping I would like to have one re-wired to shelve as a spare. I will make this spare available if needed for the re-wiring cost and shipping if you ship me your old core so I can have it re-built. That way we should be able to to forego the long lead time to get one. Of course if you want to donate your old core all the better as my current financial situation sux.
I know a place locally that can handle the rebuild.
Mr. Fisherman is offline   Reply With Quote
Old 10-30-2011, 03:53 AM   #25421
SR1
Back in S. Korea
SR1's Avatar
Oddometer: 4,385
That is a really great thing to do. Thank you.
Old 10-30-2011, 06:41 AM   #25422
jimmy2020
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 983
I took off my dirt wheels (18/21)
and put the street wheels (17/17) back on for the winter season.
I forgot how much fun this bike is with the X setup.
I purchased my bike used in June and have put 5k on it.
Bike has performed beyond my expectations....
Next..I'm going to try some knobbies on the X wheels.
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is offline   Reply With Quote
Old 10-30-2011, 08:17 AM   #25423
reddog830
reddog830's Avatar
Oddometer: 62
rolie bags
Thanks for the reply you just made my decision easier. I will be going with the rolie system. I had another type of saddle bags but got rid of them.
The Rolie system works great. I had the E-10 on before that and although they are good, the Rolie bags are better. The construction is like the Expedition bags and they are tough and waterproof. I use a pair of them and a Kreiga 5 bolted to the front plate. This is enough to carry everything I need on day rides. You could easily use Mediums if you wanted more room. I hate tank bags and I like to keep the rear plate free for my Rotopax or other stuff. I don't use my WR for multi-day, large quantity gear hauling, but I think the Rolie system is outstanding for day use.
The small Rolies and the Kriega bag on the front before I made my new rear plate.
Another shot with the Rotopax on.
If you want a photo of something specific, let me know.
Dan
reddog830 is offline   Reply With Quote
Old 10-30-2011, 09:43 AM   #25424
Mr. Fisherman
PROUD 2B Riff Raff!
Oddometer: 10,671
Don't thank me until I get one and make it available but I pretty much have a reputation for helping when I can. I hope to get one cheap. It could save someones trip.
Welcome to the club. I just found a decent set of used 244s that I am going to try to deal on. If not, I'll have to bite the $80 bullet and just get a set
I am interested to see how much difference in height there is between the dirt set and the 17s with knoblies.
Old 10-30-2011, 11:01 AM   #25425
skierd
Wannabe Far-Rider
Oddometer: 2,908
I'm also considering the Rollie's now as the inevitable replacement for my Enduro saddle bags. Waterproof is a big bonus, and the more normal shape will aid in packing bigger items...
We had our first snow/ice/sleet/wintershit storm this weekend here in MD. Time to start planning winter modifications, maintenance, and upgrades I guess, with a car now I think I'll be riding a lot less in the salty cold months I think. Maybe I'll actually wash the bike for starters.
Its probably time to start considering a bunch of long-term maintenance items too, given what others are starting to experience with high mileage '08's and '09's. I know I need to get the suspension rebuilt again, I've noticed it getting worse particularly the shock over the last few weeks. Radiator hoses are looking worn and starting to bulge where it connects to the water pump outlet, radiator, etc. The clutch is starting to get grabbier, particularly in the morning though it got better with an overdue oil change, so probably look at a new cable minimum. Throttle cable too, just for piece of mind. It looks like a stator might be on my short list, and I know I'm gonna want a new battery by next season (still on the stocker, its gonna be sitting for longer than it ever has now so its gonna have to go on a tender once the cold really hits and stays). I've already replaced the coil back when I was having a misfire issue that ended up being the FMF programmer which has since been removed.
So, after 2 years and probably 35k miles when I hit the 2 year mark this January, I'm looking at a stator, clutch and throttle cables for piece of mind, fresh rad hoses, a battery, and a second suspension rebuild for maintenance needs. Valves have been checked and adjusted once and should be good for the next year/20K+ miles, I've gone through the aforementioned coil, 3 non-OE spark plugs including an iridium plug that broke, two non-OE chains+sprockes, two chain sliders, 2 coolant flushes, 1 brake bleeding and 1 set of brake pads F+R, half a tub of bel-ray grease for suspension lubing, and probably 8 oil filters with 15qts of oil. Ready for its 9th rear tire (including one that only lasted 500 miles due to warranty failure) and 7th front tire, including changing to X wheels. Motor feels stronger than ever, still a great bike to rip around on.
I'm bored but I still can't think of any one motorcycle I'd buy to replace it. I can think of a couple to complement, like a better long distance bike especially with regards to carrying a passenger and maybe a true dirt bike for enduro's, but not replace her especially for commuting, solo back road bombing, lightweight adv touring, and general all-weather all-road fun. Still wanting a retro standard (thinking a Guzzi V7 classic, or even a Sportster or Dyna). Still wanting a woods bike (something orange or blue 2 stroke and around 200 pounds).
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd screwed with this post 10-30-2011 at 11:22 AM
skierd is offline   Reply With Quote
Times are GMT -7.   It's 07:57 AM.
