Old 11-05-2011, 03:04 PM   #25501
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 1,975
+1
If you don't run tire pressures less than, say 20 psi, then you'll be fine without rim locks. If you wanna run with 12-14 psi, then you'll definitely want them.
Originally Posted by Pantah View Post
You only need rimlocks when you are running very low tire pressures. The wrr doesn't even come with rimlocks. I wouldn't do anything with the hole. Just put your well band in and you're good.
_______________
"You can't put the shit back in the donkey." - Tony Soprano
FYYFF
thumpididump is offline   Reply With Quote
Old 11-05-2011, 03:14 PM   #25502
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 4,965
Originally Posted by thumpididump View Post
+1
If you run rim locks, does it really throw off the balance at highway speeds?
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
Any typos, misspellings, or obnoxious posts are the result of Autocorrect or Siri.
Dahveed is offline   Reply With Quote
Old 11-05-2011, 03:29 PM   #25503
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 1,617
Send a message via Yahoo to Daamud
If you run knobbies does it really matter much
To answer your question....some.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 11-05-2011, 04:32 PM   #25504
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 681
+1
I have run 15psi with no rim lock and did not have a problem. I would not go any lower than that without one though.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
duanew1 is offline   Reply With Quote
Old 11-05-2011, 06:25 PM   #25505
rydnseek
gone & forgotten
rydnseek's Avatar
Oddometer: 4,094
Depends on the tire. I've run 2- 3 pounds in my shinco 244s without rim locks. That's on x rims & some of the nastiest terrain you can find.
rydnseek is offline   Reply With Quote
Old 11-05-2011, 06:44 PM   #25506
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,463
Send a message via MSN to Attico
I've run less than that, to the point that the air guage didn't register....no rim locks. The wrr really doesn't put down enough power down.
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life."
Attico is offline   Reply With Quote
Old 11-05-2011, 06:45 PM   #25507
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,463
Ok when do we ride. I need to see this new steed.
+1
Old 11-05-2011, 06:57 PM   #25508
thumpididump
MacGyver
Oddometer: 1,975
I'm hoping for a ride tomorrow. I can't go for the whole day, but I should be good from early morning until about 1pm.
Hunting season starts Monday so tomorrow would really be the last day for trail riding.
You name the time and place.
_______________
FYYFF
Old 11-06-2011, 04:39 PM   #25509
huntinguy
Oddometer: 16
Have any of you been in a situation where you wished you had a kick starter on this bike?
huntinguy is offline   Reply With Quote
Old 11-06-2011, 05:44 PM   #25510
Dysco
caddis muncher
Dysco's Avatar
Oddometer: 14,792
Never enough to think much about it. With a totally dead battery I rolled off a 3' berm and bump started it. Easy- peasy.
Dysco is offline   Reply With Quote
Old 11-06-2011, 08:16 PM   #25511
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,587
I found my battery dead in the parking lot at work (totally flat) and even with my 606 knobbies I just had to run with it and pop the clutch in 2nd and away I went... The engine warning light you get with a super low battery went out in about 5 miles.
EnderTheX is offline   Reply With Quote
Old 11-07-2011, 08:50 AM   #25512
coresports
coresports
coresports's Avatar
Oddometer: 86
my 86 XT225 didn't have one, my 08 WRR doesn't have one and i have never even found it necessary to bump start either one...you won't miss it.
coresports is offline   Reply With Quote
Old 11-07-2011, 09:47 AM   #25513
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 8,315
...I'm thinking about being in the market for a WR250R, hopefully in SoCal if anyone has any leads...
'08 R1200R / '10 WR290X/R
'81 R100RS Rattlecandy Red
'06 950 ADV Orangeboom
'05 R12GS Wedding Bike '91 R100GSPD Derelict
Rapid Dog is offline   Reply With Quote
Old 11-07-2011, 10:42 AM   #25514
herods_flu
herods_flu's Avatar
Oddometer: 296
Finally got my dirt wheels mounted up. Only went through through two front tubes getting the tires on the rims
It was a lot harder than the guy in the you tube video made it seem. The handling will definitely take some getting
used to.
1 234 by stedfastbloom, on Flickr
1 236 by stedfastbloom, on Flickr
herods_flu is offline   Reply With Quote
Old 11-07-2011, 10:58 AM   #25515
RimBenty
Bender of Rims
RimBenty's Avatar
Oddometer: 160
Yeah, this past weekend at the Hammer run we stopped to catch our breath for a while and my son left his key on. The motor would crank over but it was too slow to start it so I pulled my battery and jump started his. If there was a hill or something close by we would have used that but we were on flat sandy ground.
His bikes due for a new battery, for the amount of time we were there it should have been fine.
RimBenty is offline   Reply With Quote
Times are GMT -7.   It's 02:01 AM.
