Old 03-07-2012, 12:12 PM   #27361
Crawdaddy
Navigate 2 Adventure
Crawdaddy's Avatar
Oddometer: 2,250
Went for a ride near my place in AZ. this past weekend. Ride Report/Photos: http://www.dualsportmoto.com/boards/viewtopic.php?p=3186
Chris Crawford (Crawford + 4 kids = Crawdaddy )
http://www.CrawdadOffRoadEvents.com
http://www.DualSportMoto.com
http://www.WhereAmIRiding.com
Crawdaddy is offline   Reply With Quote
Old 03-07-2012, 05:21 PM   #27362
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,390
[QUOTE=wtiger;18155751 i have been checking my chain tension by compressing the rear shock and tying it off with a ratchet strap, and making sure that the chain does not become taught. i don't want a busted chain or worse out in the middle of nowhere.
.[/QUOTE]
^ This.
All the talk of how far and where, this is what needs to be done. More so, disconnect the shock and cycle the suspension, find the point where the chain gets tightest, it may be at 3/4 stroke ....All depends on where the output shaft is compared the swingarm pivot..... Then take note where it's at when back together....Sprocket size would probly change the spec also.
Think I know what I'm doing this weekend.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 03-07-2012, 07:25 PM   #27363
scottmac
scottmac's Avatar
Oddometer: 1,811
Machtig's WRR ate up a couple of swingarm guards in short order on his western TAT ride
last summer. He thought the culprit was a tight link and cured it by replacing his chain if I
remember right.
scottmac is offline   Reply With Quote
Old 03-08-2012, 12:17 PM   #27364
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,031
WR Rider needs help in YUMA, AZ!~
Fellow inmate Dysco is in Yuma; was headed into Baja, and his WR250r just quit. He's with Codys and they got the bike to a Yamaha dealer in Yuma, but the dealer is basically not giving them the time of day; they are in the parking lot trying to trouble shoot, but not having much luck.
Do any locals know of an independent shop/mechanic that could help them out?
His symptoms as I understand it:
Riding down the highway to the border; bike started losing power, and the engine light came on. (I think).
Pulled to the side and let it sit for a few minute. It would then start and run, but not idle. then it wouldn't start at all.
He pulled the airbox cover; there's oil in the airbox. He says he "may" have overfilled it. He wrung out the air filter, but still no go.
I suggested pulling the plug, that it might be fouled; in the parking lot of the shop, he did so, and replaced the plug. He said it runs but won't idle still.
Any ideas? Any locals there?
"What these people need is some mental psychology."-Bonnie Abbzug
Hayduke is offline   Reply With Quote
Old 03-08-2012, 12:24 PM   #27365
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,258
Over filled/lubricated air filter will not stop bike..been there, done that.
Is his bike an 08?
Does he hear the fuel pump buzzing when he turns the key on??
Sounds fuel pump related to me.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 03-08-2012, 12:33 PM   #27366
Hayduke
///SAFETY THIRD///
Hayduke's Avatar
Oddometer: 44,031
Is his bike an 08?
He said he was able to bump start it after changing the plug, but it won't idle. Do you think the fuel pump would present that way?
Old 03-08-2012, 12:49 PM   #27367
Ed@Ford
Oddometer: 1,662
Correct...the first thing is to see if with key on you hear the fuel pump come on for about 1 sec then shut off. The sound is obvious.
BUT....if that Yamaha is like most cars, if the throttle potentiometer goes bad, they won't idle at all, or idle poorly. BUT BUT...I'm guessing the ECU should give you a fault code for a bad throttle pot
Finally, if you look at the '08 serial numbers for USWR250R & X, ALL of them can experience the fuel pump failure!
Ed@Ford is offline   Reply With Quote
Old 03-08-2012, 01:00 PM   #27368
indypup
indypup's Avatar
Oddometer: 3,764
My ride into work this morning.
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 03-08-2012, 01:02 PM   #27369
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,258
If the fuel pump can't maintain pressure to the injector, it would present exactly like that.
Old 03-08-2012, 01:04 PM   #27370
Dysco
Whackaducker
Dysco's Avatar
Oddometer: 16,408
The fuel pump is charging on startup, but it won't idle at all. My WRr is one of the sketchy numbers from '08. (<2,000)
Sorta bumming a Comfort Inn computer right now...
Anyone had this problem (fuel pump) and heard it charging when turning the ignition on? May order the pump from Ron Ayers or, alternately, take the pickup down to Baja while my buddy rides.
Dysco is offline   Reply With Quote
Old 03-08-2012, 01:05 PM   #27371
Dysco
Whackaducker
Dysco's Avatar
Oddometer: 16,408
That's kinda where I arrived. Yammie shop said 1 week on pump.
Old 03-08-2012, 01:06 PM   #27372
Dahveed
Sumo Biker!
Dahveed's Avatar
Oddometer: 5,565
I have an 08, how can I tell if I have one of the problem fuel pumps or if it had been replaced by the PO?
Originally Posted by summerinmaine
When you get too old to serve as a bad example, you can always give bad advice.
'13 R1200GS
'08 WR250R
Dahveed is offline   Reply With Quote
Old 03-08-2012, 01:06 PM   #27373
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,258
One other thing...water in gas from a cheapo station presents the same way too.
key diagnosis, as I mentioned, is to listen for the fuel pump whine.
The initial whine we hear is the fuel pump running to build pressure. Once pressure is met, pressure regulator turns pump off. Once it gets below point x, it kicks on again, etc.
The heat issue also comes into play and is also a sign of the fuel pump issue.
Old 03-08-2012, 01:07 PM   #27374
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,258
Did ya get potentially bad gas recently at all, that you know of?? A sketchy station?
Old 03-08-2012, 01:10 PM   #27375
Dysco
Whackaducker
Dysco's Avatar
Oddometer: 16,408
Nope- local gas from Salida- best they make.
Ran like a top last night, actually. Did some freeway and some in town putting- maybe 25 miles and ran dreamy. Got 10 miles today before the drama... 9 miles before the border.
Times are GMT -7.   It's 10:46 PM.
