Old 04-28-2012, 06:17 PM   #28411
Oh2RideMore
Oddometer: 1,299
That looks great
Originally Posted by ecarnell View Post
I'm still waiting for the top pcs/gps/speedo mount - that I did not order at the same time as the light (my mistake).
I believe the mounting is the same a the TT light - but Darryl at cyclops motorsports swaps out the 8" HId and puts in a standard H4 7" which is a direct connection to our harness/H4. I don't have to worry about ballasts or wiring changes. Looks 10X better than stock - and brighter - still streeet legal (have same H4 type high/low bulb) - though I'm going to swap in a 80/100 bulb next week I think.
http://www.cyclopsadventuresports.com/
(I did get an ADV discount also - which helps).
Thinking of going that route or new baja designs led bulb. Like the retro big headlight look and deep basket for good throw.
2008 WR250R(Anywhere)
2009 Versys
Oh2RideMore is offline   Reply With Quote
Old 04-28-2012, 06:19 PM   #28412
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,038
Originally Posted by johnnyadventurepants View Post
Any of you short people want to trade your 18" black rear rim for my 17? I'm running 17/21 right now but want to get as tall as possible because I'm 6'8".
And you'll gain what? A half inch when you have your feet down?
If you really want to take care of your situation go get your seat reuphostered with another 2-3 or more inches of padding.
It works for Rik Smits, of NBA fame and now a Vintage MX racer. He's only about 7'3", although racing vintage bikes with 4" travel on the back he may be pounded down to 6'8" by now.
This one is obviously a bit newer:
I don't think you'd need to be quite as radical though. Notice the risers... Custom Chrome?
I'm curious who makes his MX boots!
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 04-28-2012, 10:26 PM   #28413
johnnyadventurepants's Avatar
Oddometer: 492
Yeh, I already have a seat that is about 3" higher than stock. The 17/18 rear difference is pretty minimal and isn't worth the $ for me to change sizes, but if someone wanted to do a trade, I definitely would.
2008 WR250X/R
johnnyadventurepants is offline   Reply With Quote
Old 04-29-2012, 11:20 AM   #28414
Nevada
Oddometer: 302
Originally Posted by Adv Grifter View Post
Has anyone done any long tours (like year long RTW rides) on the WR250R? I've only skimmed through, any links to Ride Reports from WR riders? (or posts in this thread describing rides more than a week or ten days long?)
The more I read, more it looks like this little beasty can be packed up full and ridden all day ... and then race a Hare Scrambles! How is comfortable riding 10 hour days, back to back? (I saw a picture of a Corbin seat ... looks good!)
How many riders are over 40,000 miles at this point?
Big Dog took his to Prudhoe Bay, Alaska. Does 7,000 miles count as a "long tour" in your book?
Nevada is offline   Reply With Quote
Old 04-29-2012, 12:06 PM   #28415
Oh2RideMore
Oddometer: 1,299
rear shock remvoed
Thanks for the info, was easy to remove. Sending rear shock off to go-race in the morning. A couple more weeks and the WR will have that magic carpet ride I have heard about.
2009 Versys
Old 04-29-2012, 12:24 PM   #28416
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
7000 is incredible!
If you go back into the thread you'll see helpful members already posted Ride Report links on some WR guys doing long tours. (including Big Dog) I've read them all ! Great stuff.
Old 04-29-2012, 01:54 PM   #28417
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
Originally Posted by jgiacobbe View Post
Mine has a pronounced wobble at highway speed too. Pretty scary as it doesn't seem far from being a tank slapper. The wheel is balanced. I've heard that when you get wobbles like that it is good to make sure the steering head bearring are not worn and that the steering head is tight.
Hey Jgiacobbe,
I had a similar problem with my KTM. Two problems I found after eliminating all the suspension problem possibilities.
1. The steering stem bolt was sensitive to the proper torque on the stem nut(not the bearing).
2. If if you use/or your bike was designed to use tube tires, but the tire store sells you tubeless tires that you can use tubes in some bikes are more sensitive to that incongruity and will give you head shake. Mine usually occurred when slowing down to around 45mph and that is where it began to head shake. I overcame it by holding steady. I corrected most of the problem when I used a lighter torque on the stem nut and a steering dampener took care of the tire problem. I don't know if you have either of these problems, maybe this might help.
Paul
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 04-29-2012, 01:56 PM   #28418
MotoMind
Oddometer: 1,272
Mounted up a Michelin T63 in 110/80-18. Let it soften up in the sun for 2 hours and it slid right on, even though the first step was to seat the whole rim inside the tire (I'm using Tubliss so you can't reach over the inner tube). Took surprisingly little air to get it up to pressure. Should spin up nicely, probably a better fit for the 250's powerplant than a 120 or 130 tire. 130/90-18 Michelin MT21 for comparison.
MotoMind is offline   Reply With Quote
Old 04-29-2012, 02:00 PM   #28419
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 587
My stock lense had cracked - so mind as well go big (ger)or go home!
Hi Ecarnell,
What are you using as a rock guard for your baja ralley light??
Paul
Old 04-29-2012, 03:49 PM   #28420
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 340
Got out today.
ridepjride is online now   Reply With Quote
Old 04-29-2012, 05:48 PM   #28421
xaman
Oddometer: 583
Beautiful pics
xaman is offline   Reply With Quote
Old 04-29-2012, 06:08 PM   #28422
Krabill
Krabill's Avatar
Oddometer: 4,893
Originally Posted by Daamud View Post
On the grease subject.
Anyone ever think about drilling parts (like swingarm pivot bolt) for a zerk fitting?
No, but if I were to ever consider it, I certainly wouldn't put them directly on the bottom of the linkage. They'd be torn off during the first rough single track ride around here
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 04-29-2012, 06:31 PM   #28423
freetors
Oddometer: 958
I have definitely thought about it, but the full width needle bearings would make it a pain to do properly. You would have to press them out first and then shove em back in after you drilled and tapped everything. Definitely a dead of winter project.
freetors is offline   Reply With Quote
Old 04-29-2012, 06:51 PM   #28424
Daamud
AAAAAYYY!
Daamud's Avatar
Oddometer: 2,390
Google picture.
WARNING: Most things posted above contain sarcasm.
Daamud is offline   Reply With Quote
Old 04-29-2012, 07:07 PM   #28425
xaman
Oddometer: 583
Here's a nice pic from a recent ride in Arkansas:
Times are GMT -7.   It's 12:02 PM.
