Old 05-13-2012, 03:57 PM   #28561
mpatch
Oddometer: 897
Originally Posted by DougZ73 View Post
The TPS made it stick?? Its just a sensor...should not affect the mechanical linkage or make it bind. Hmmmmm
Thanks for the info though..I'll check it out.
Pretty sure the the other end of the rod that the cam mounts to goes into the TPS so if it's not perfectly inline it will bind a bit.
mpatch is offline   Reply With Quote
Old 05-13-2012, 03:59 PM   #28562
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 6,969
Originally Posted by mpatch View Post
I fixed it. The TPS was a bit out of alignment. Thanks to mwgak for this link.
http://wr250rforum.forumotion.com/t5...on-off-at-idle
Took quite a bit of fine tuning with a hammer and a socket extension to get rid of the bind and get the TPS numbers within parameter.
That link dead? Just brings me to the idex.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 05-13-2012, 04:11 PM   #28563
mpatch
Oddometer: 897
Fixed link that should work
Old 05-14-2012, 09:26 AM   #28564
IdahoRenegade
Oddometer: 1,495
Seat Concepts-Materials and Pics?
I did a nice 280 mile day yesterday on my WRR, a mix of gravel and nice twisty pavement. That ride made me decide it's tiem to do something about the 2x4 Yamaha refers to as a seat. Based on all the great reviews here, I want to order a Seat Concepts cover and pad...but am am undecided on which material to go with. I'm leaning towards the "gripper" top and blue sides from an appearance standpoint...but how grippy is the gripper? I do like to be able to slide around a bit. Thoughts?
IdahoRenegade is offline   Reply With Quote
Old 05-14-2012, 09:48 AM   #28565
TwilightZone
Oddometer: 2,954
>"how grippy is the gripper? I do like to be able to slide around a bit. "
Happy with the conventional cover on mine... I have a grippy cover on another bike and don't like it.
"I don't really know, I've been too busy falling down."
TwilightZone is online now   Reply With Quote
Old 05-14-2012, 09:49 AM   #28566
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,385
I have the grippy gripper SC cover.
You can still slide around a bit but it is pretty grippy. It's almost like a rubberized/vinyl pebbly cover affair.
If you like to slide forward easier the CF pattern is pretty good. Had that on an other bike and liked it alot.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-14-2012, 11:30 AM   #28567
Scott_PDX
Leisure Engineer
Scott_PDX's Avatar
Oddometer: 3,126
Did 250 miles on my Seat Concepts (Blue sides, gripper top). The seat was soft enough that my rear didn't get sore until the last 50 miles or so. Before the seat, it only took about 70 miles. The bigger problem was the heat (High 80's), making things "Uncomfortable" down below. I think the gripper seat made things worse as sliding forward and backward caused friction on the inside of my pants vs. the outside sliding on the seat. But other than riding in the heat, it's been great.
FYI - I don't think the blue in the Seat Concepts matches the Yamaha Blue enough. If I were to do it over, I would get all black and skip the Gripper, especially in ID.
-= Scott
2014 KTM 690R, 2009 KLR650, 2004 KTM 450 EXC, 2000 R1150GS
My MotovLog (Youtube Videos): http://www.youtube.com/user/scottb572/videos
Where Am I via SPOT (Code SCT): http://www.advrider.com/forums/showthread.php?t=719703
Scott_PDX is online now   Reply With Quote
Old 05-14-2012, 12:25 PM   #28568
Loud Al
Loud Al's Avatar
Oddometer: 3,902
I did a 12 day 4,000 mile trip and I can highly recommend the Renazco tall seat
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 05-14-2012, 12:46 PM   #28569
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,793
That's a badass photo!
MeefZah is offline   Reply With Quote
Old 05-14-2012, 02:05 PM   #28570
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,385
Cool2 Clutchism
I'm considering getting a Barnett set of plates (kit) since I'm starting to get really pissed at the lack of clutch control. The lever engages way at the top (lever out) now. I've adjusted and lubed every which way, and the bike has just about 2K on it.
I've got about 1K on the oil so maybe I should swap it out and see...
I do have bar risers but the clutch seems to have enough slack though.
Makin; me cranky. !!!
Old 05-14-2012, 02:36 PM   #28571
Krabill
Krabill's Avatar
Oddometer: 4,830
There is an adjustment screw right on the clutch lever that will allow you to adjust it to engage wherever is the most comfortable for you.
Too far out? Loosen the cable by loosening the lock nut (the big one) and screw in the center piece a few turns. That will effectively loosen the clutch cable, bringing the engagement closer to the bar.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 05-14-2012, 08:55 PM   #28572
byron555
Lame Duck Adventurer
byron555's Avatar
Oddometer: 1,124
Ims 3.1
Just added an IMS tank that came in the mail today, and it looks pretty good. I notice that it is about 1" wider than the stock tank where my knees are. It feels strange since I am so used to the old tank setup. Anyone else notice this?
Another inmate stole my Avatar...
WR250R... 15 cubic inches of raw power.
WRr re-build
http://www.advrider.com/forums/showthread.php?t=997633
byron555 is offline   Reply With Quote
Old 05-14-2012, 08:59 PM   #28573
jgiacobbe
Skid plate tester
jgiacobbe's Avatar
Oddometer: 2,152
What color tank and who did you order from? I have one on order but it appears to be back ordered.
jgiacobbe is offline   Reply With Quote
Old 05-14-2012, 09:03 PM   #28574
byron555
byron555's Avatar
Oddometer: 1,124
2 fingers? Clutching
My xr and wr are the same in that regard. I used to use my whole hand on the lever. 2 finger clutching made a world of control difference... It took a while to get used to doing it. Maybe you already use 2 finger clutching?? I think they are designed for 2 finger clutching, because when the clutch completely disengages there is room for 2 fingers gripping the bars
Oil won't change it... tried that in the xr.
It's a short throw clutch, and it always will be, its a leverage thing... I must have forgot to attach the quote
WRr re-build
Old 05-14-2012, 09:04 PM   #28575
byron555
byron555's Avatar
Oddometer: 1,124
its black
mine was back ordered from Just Gas Tanks... and now its here
WRr re-build
Times are GMT -7.   It's 09:45 PM.
