Old 06-26-2012, 09:39 AM   #29356
jon_l
jon_l's Avatar
Oddometer: 3,458
Originally Posted by Sewerat View Post
I got 6-7000 kms from a $60 tire. I can get 8-9 k from a $110 tire. Price/km the kenda won in my books. My Mitas rear that I expect to get 10-15 kms from cost me $150. Again the math doesn't add up to not run the trackmasters
I'd be thrilled with 6 or 7k kilometers.
P.S.
I was thinking of you Sewerat when I snapped this cell-phone pic the other day:
CBF1000 & PCX150, PCX Fuelly
jon_l is offline   Reply With Quote
Old 06-26-2012, 09:58 AM   #29357
markk53
jack of all trades...
markk53's Avatar
Oddometer: 9,208
Originally Posted by yaw View Post
I've run 606's for about 14,000 miles. I've had the usual scalloping problems on the front. Usually reverse it eventually. This last front tire wore strangely. It didn't scallop. Instead the middle single knob has about 1/4" left on it. The two knobs between every single knob wore down to nothing. When I roll along under 10mph the bike feels like a pogo stick. I run the front about 18psi on the hwy and 15psi on the dirt. I have balanced the tire. Anyone else had this wear problem? Should I go back to the merchant or is that a lost cause? Thanks.
FWIW, I am fairly certain the technical term for the scalloping is cupping. The tread develops a curved wear on the surface, a cupping effect.
It is a characteristic where the knobs wear on the trailing edge as the knob rolls under. It shows up on the front so badly because the front only has forces acting in one direction, braking and rolling forces are in the same direction. It happens on ALL motorcycle front tires that have tread, even street tires. It just isn't as noticable on the street type unless they're like the old small block tires aka K70 or F11 Dunlop type. Rub your hand over a street tire with some miles on it. You will feel the same tread wear characteristic where the trailing edges wear more than the leading edges on the front tire.
Believe it or not the same phenomenon occurs on the back, but is radial in nature rather than circumfrencial. The circumfrencial wear is mostly the same due to acceleration and deceleration counteracting the cupping that direction, but when leaning into turns the knobs roll under and the edge of the knob wears the edge toward the center more than othe outside edge. You rub your hand from outside to center you feel the cup. On the front you feel it when you rub your hand back over the top.
Ever get lost? You know, that good kind of lost - come to a dirt road intersection and you have no idea where you are or which way to turn? I like when that happens!
Mark - klx678
95 KLX650C w/Vulcan piston bigbore, Now an 09 KLX250S, selling my 90 Zephyr 550
markk53 is offline   Reply With Quote
Old 06-26-2012, 10:40 AM   #29358
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 761
I had to put some new tires on the WR. I think that I wore this one out. It was after a total of about 5000 miles and trying to get home from a 2000 mile trip without buying a new tire. I did the lower TETs loop solo camping. I may make a ride report but I do not feel that I have enough pictures to do so.
Here is the front. I have at least 3000 miles on it. I definitely shows signs of cupping. I like the Scorpion Pro but it kind of squirms on the highway when new. I think that I like the MT-16 front tire better. It handles better on the street and almost as good on the dirt. I think that it might last longer too but requires flipping halfway through due to cupping.
Here is the new Rear. It is a Shinko SR241. I could not find much info about people's experience with them. The only one I found was a guy with a XT225 that get about 4000 miles out of it running 16-20 psi. It was pretty cheap at $53.99. It looks a little smaller than the MT-43 but is taller than the 120 sized T63 that I had. I will have to check out the difference next time I see someone who has one. The rubber is also pretty soft as you would expect with a DOT trials tire. I plan on running 12 psi with a rim lock like most people do with the MT-43 and see what happens.
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 06-26-2012, 11:45 AM   #29359
yaw
lost
yaw's Avatar
Oddometer: 78
dunlop 606 wear pattern
Markk53 and Pantah, Thanks for the replies. I'm mounting up a new one today.
10 ktm 530 exc
08 yamaha wr250x
07 ktm 990s sold
67 bmw r69s sold
yaw is offline   Reply With Quote
Old 06-26-2012, 11:56 AM   #29360
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,903
Still at it...
Mr. Fisherman is offline   Reply With Quote
Old 06-26-2012, 02:18 PM   #29361
Discojon75
Oddometer: 242
I've got a WR250X with an extra set of dirt wheels. Progressive actually bills this bike as a street sport versus a dual sport, to the tune of $400 more/year for me. I think it's time to switch to another insurance provider. This one bike costs more than my BMW K1200LT, R100GS w/ sidecar, KLR650 and CT90 combined.
Disco <<Alamogordo NM>>
2002 BMW K1200LT// 2008 KLR 650 // 1975 Honda CT90 // 2008 WR250X // 2013 BMW C600S//1998 Harley-Davidson Sportster 1200// 2009 Kawasaki Versys // 2006 Yamaha Majesty
" The BEST bike......is a garage full of them."--dlearl476
Discojon75 is offline   Reply With Quote
Old 06-26-2012, 03:26 PM   #29362
2Stamp
2Stamp's Avatar
Oddometer: 406
What?! wow that seems high. There must be one heck of a difference between a R and X .
_______________________________
2011 F800GS
2014 350XCF-W
2006 450EXC
2014 Honda Grom (hers)
2Stamp is offline   Reply With Quote
Old 06-26-2012, 05:16 PM   #29363
ADVCoop
ADVCoop's Avatar
Oddometer: 792
Originally Posted by duanew1 View Post
I
I had a Cheng Shin DOT trials tire on my KDX and it looked exactly like your tire does. It worked great but was wearing pretty fast. I sold that bike before I could wear it out for mileage check. I have an MT-43 on my WRR now and love it.
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is offline   Reply With Quote
Old 06-26-2012, 05:17 PM   #29364
jon_l
jon_l's Avatar
Oddometer: 3,458
Originally Posted by jon_l View Post
I am debating what to replace the OEM Trailwings with (3,500 km). List I am considering so far:
MT-21 F / MT-43 rear
MT-21 F / T-63 rear
MT-21 F / D606 rear
Alternative front for all of the above is the Pirelli Scorpion Pro, looks good and lots of folks like them, but I have never used one, and I have run the MT-21 of a DR650 and liked it.
I run lots of street, but care much more about off-road performance; we have a lot of loose sand on the local trails.
If I can get 5,000 km /3,000 miles I'd be satisfied.
I'm running 12-43 now, plan to go to 13-48 when I can afford to. I like the 12 but it makes me nervous with the chain slider / swingarm wear issue.
I like most of what I've read about the MT-43. I know Skierd had less than stellar results with them, Crawdaddy seems to like them. I want to try one on the rear, but I do care about getting decent amount of road mileage since the WRR is so OK there, and since it take some time to get past the city around here.
Gearing is currently -1 on the front, but I plan to go back to the 13T (swingarm / chain-slider paranoia), and up to 47 or 48 on the rear (as much as the stock chain will allow).
Feedback welcome, as always here.
I also think this front is kinda sexy, but I don't read much about them, and the IRC TR8 Battle Rally Front Tire isn't cheap. http://www.motorcycle-superstore.com...ront-Tire.aspx
Old 06-26-2012, 07:00 PM   #29365
skierd
Wannabe Far-Rider
Oddometer: 2,990
As you noted, I didn't have great luck with the MT43 in terms of longevity. I thought it did ok on the sandy dirt roads on the eastern shore of MD, and had fantastic traction in rocks and in most snot slick conditions so long as you were aired down enough.
I like the D606 a bunch as its the only tire I ever had on the rear that flat out worked everywhere in any kind of conditions right down till the knobs became nubs. A D606 with a MT21 or MT16 front were what I was going to run on my bike next before I swapped to supermoto wheels. The Scorp Pro was also on my radar.
Also keep in mind that if you go with 13/48 gearing that your effective final drive ratio will change depending on the tire you decide to run. The MT43 is taller than the D606, the 120/90-18 D606 is taller than stock, and typically most people end up with the 120/80-18 T63 which is stock. 13/48 on the T63 is closer to 13/50 on the MT43. Also, keep in mind to run your chain 2 links longer if you go with an MT43 for swingarm clearance i.e. if you were running 13/47 with a D606 or stock sized tire you'd run a 110L chain, but with the taller MT43 you'd need a 112L.
MT-21 F / T-63 rear
MT-21 F / D606 rear
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd is offline   Reply With Quote
Old 06-26-2012, 07:06 PM   #29366
Loud Al
Loud Al's Avatar
Oddometer: 3,921
That is a great tire, I will be putting that on again and I will be trying the same for the back.
A Quick Trip to Big Sur
Allan
Loud Al is offline   Reply With Quote
Old 06-26-2012, 07:15 PM   #29367
BENRON
Crosscut Certified
BENRON's Avatar
Oddometer: 3,677
Half Done:
If I take my hands off the bars, the bike will pull to the right... But I don't notice it at all if my hands are on the bars. Its about the same effect as sticking one hand out straight at 50mph.
Bike is more flickable, Brakes are improved. Stoppies are possible if you grab a handful.
BENRON is offline   Reply With Quote
Old 06-26-2012, 08:34 PM   #29368
Luke308
Luke308's Avatar
Oddometer: 425
Nice surprise...
I know this is probably old news to most, but just today I realized that since replacing my D606's with Shinko 244's (i.e. slightly smaller overall size) my 6th gear actually has some pull to it, and I find myself comfortably cruising in 6th when I used to leave it in 5th...pleasant surprise
However, my next set of tires I might get something a little knobbier for the front since it felt pretty floaty on a hardpack dirt/sandy road I was riding this past weekend. Rarely had that problem with the D606 front...but on the other hand I feel more comfortable leaning the bike over on pavement with the Shinko 244 front.
Luke308 screwed with this post 06-26-2012 at 08:43 PM
Luke308 is offline   Reply With Quote
Old 06-26-2012, 08:43 PM   #29369
thumpididump
MacGyver
thumpididump's Avatar
Oddometer: 2,766
Indeed.
Originally Posted by DougZ73 View Post
Did you tell them who sent ya??
Keyboard Diarrhea
2014 KTM 690 Enduro R
2013 KTM 1190 Adventure R
Poor decisions always lead to great adventures.
thumpididump is online now   Reply With Quote
Old 06-26-2012, 08:57 PM   #29370
Longboardr
Longboardr's Avatar
Oddometer: 143
That sucks! I have an R and Progressive charges about $75 a year for full coverage. It's the cheapest bike on my policy and interestingly enough has the highest blue book value. Makes you wonder how they come up with their numbers
Longboardr is offline   Reply With Quote
Times are GMT -7.   It's 10:39 AM.
