07-04-2012, 03:16 PM
#29506 | |
Oddometer: 248
I went with a non-sealed chain for max performance. Downside is if you don't keep it clean it is toast. My bike actually just returned from a mud facial at our single-track spa. So there, mister smarty-pants. Nya ni na na.
________________________________ Confidence is the feeling you have before you understand the situation. |
07-04-2012, 03:17 PM
#29507 |
Red Sox Nation
Oddometer: 8,902
Top speed for me is low 90's on my GPS. It seems happy to run GPS 70, but I generally am cruising 62-67. If I hit a grade dragging me to 60, I downshift and bring her back up. If happens again in 5th gear, I go to 4th and bring her back up. No problem. The bike revs well. You can run it wide open a lot, which we do when we are climbing grades or facing headwinds on the plains. Basically I try and run her 70mph indicated on the highway at all times. That will be an actual low 60's.
Straight ahead and faster -Bo Weaver 1970 "There I was..." -Griffin Niner Three Hotel |
07-04-2012, 03:56 PM
#29508 | |
Skid plate tester
Oddometer: 1,467
2009 Wee-Strom, 2008 WR250R |
07-04-2012, 03:58 PM
#29509 | |
Oddometer: 65
I think that if the gears were 13-45 or 47, then the engine RPM could go higher in 6th before you ran out of steam and possibly obtain a slightly higher top speed. Jon Sent from my Galaxy Nexus using Tapatalk 2
Jon WR 250 R |
07-04-2012, 07:37 PM
#29510 | |
Hair on fire!
Cougar tracks The initial pawprints The blind date Travels with my wiener Lead me not into temptation ............ just follow me, I know a short-cut. |
07-04-2012, 08:03 PM
#29511 | |
Bike-aholic
Oddometer: 2,067
Another option to consider: lay the bike over on its side with the clutch cover facing upward. Remove the cover and inspect the plates. You can take them out fairly easily....6 bolts if I remember correctly. Be sure to keep track of the order of things and reinstall exactly the same. Remove the plates and inspect each one....clean them with a rag (no solvent). Look to see if any of the fiber is becoming disbonded from the plates. That could cause some grabbing in the clutch action. You'll have to look very carefully, as this would be very small amount. If it were a large amount, the whole fiber would rip off the plate and wad up inside your clutch and run thru your gear box.....it'd get chewed up and spit out, most likely. I doubt you'll see any problems, but who knows. Its a possibility to consider if you notice your engagement situation getting worse. Laying the bike on its side, let's you do this inspection without losing your oil. But, its always a good idea to have a spare clutch cover gasket on hand, before attempting....in case you tear the original during removal. They are often stuck to the cover or case somewhere. I read BigDog's RR on your trip at his website. Looks like you had a grand time of it. Me....I'm not retired yet. Probably never will be. ![]() HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 BMW F800GS, '71 Honda CL70 Bergs Over the Rainbow Texas or Bust! BigDog/Highfive--Fall Colors in Missouri 2011 Athena Big Bore Project The Other Side of Nowhere Highfive Goes Dragon Hunting WRRDualsport.com |
07-04-2012, 08:32 PM
#29512 | |
Professional nOOb
Oddometer: 350
Glad it worked out. Within a week of getting my new bike in April I had lost my set on one key ring; luckly I had put the spare key on a separate key ring as backup. So I got 2 more blanks and made more copies and placed them in strategic locations just in case.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875 2011 WR250R,2008 KTM 990 ADV,2004 KAWA Concours May the Lord bless you and keep you in all the Dark places you must travel
07-04-2012, 09:04 PM
#29513 | |
I'll keep you posted .... for sure! ![]() Yea we had a great ride, BigDog's a class act...a good friend indeed! getting to know Sam was awesome too, and to hear how he's been re-routing sections of the TAT. He's retired and very passionate about re-routing a few different sections of the TAT, both east & west. Anyone who's gonna ride it, make sure you look for the new routes, I know TN and MS are done, I rode some of both of them while down there.. we are going to get another ride in after it cools down!! |
07-05-2012, 03:24 AM
#29514 | |
Oddometer: 716
2010 Gas Gas EC250 - 1997 Honda XR650L - 1992 Gas Gas GT25 "Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain |
07-05-2012, 05:34 AM
#29515 | |
Oddometer: 288
Sounds like a plan ?Jordan |
07-05-2012, 05:59 AM
#29516 |
Lacks Freetime
Oddometer: 4,924
I am potentially having some chain slider issues, and currently have a 12T front sprocket. I of course have always been on the side that its a chain maintainance issue/ slack issue, when the slider gets worn. I keep my chains very clean, and always have plenty of slack.
Now that I have the 300 EXC for a dedicated woods bike, I have started doing longer dual sport type rides. After last one, about 90 miles, I noticed what I thought was drops of chain lube. BUT, they also looked very much like little specs of worn plastic. I inspected the slider and saw it was a little more worn that usual. I am gonna pull off and get a better look. 13/43(stock) = 3.31 12/45 = 3.75 (now) 13/45 = 3.46 I had gone to a 12T in front for more grunt, and then as I started getting faster, I wanted 2nd gear to have more grunt and more " loft the front wheel" ability, so I went to the 45 rear. This was important, since I did not wanna buy a new chain as well. Now, I am thinking about going back to a 13T front, but keep the 45T rear. Question: Will it fit with stock length chain( probably slightly worn)???
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
07-05-2012, 08:06 AM
#29517 |
Cert. bike whore
Oddometer: 892
I'm running a 13/47 with a 110 chain. It's adjusted about 3 hash marks into the marks so close to the frame. I'd think you should be fine with 13/45. I can fit 12,13,14 all on no problem.
2009 WR250R "Da Mini Bike" "That's our colour: mud!"
07-05-2012, 10:11 AM
#29518 |
Oddometer: 1,776
13/43 is stock so 13/45 on a stock length chain, especially a used one, shouldnt be an issue at all.
07-05-2012, 10:38 AM
#29519 |
Lacks Freetime
Oddometer: 4,924
OK, thanks guys. Looks like the stock 13 might be going back on.
07-05-2012, 12:28 PM
#29520 |
I"m 10K+ miles and still on first chain slider... I run 13/47 + 110 chain and thus far haven't wore through or come close yet... I know some are on their 3rd and 4th!
