Old 07-10-2012, 04:55 AM   #29566
Longboardr
Longboardr's Avatar
Oddometer: 143
Pretend it's your track bike and safety wire the drain bolt to your frame
Longboardr is offline   Reply With Quote
Old 07-10-2012, 07:14 AM   #29567
tommu56
tommu56's Avatar
Oddometer: 1,375
tommu56 is offline   Reply With Quote
Old 07-10-2012, 07:26 AM   #29568
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,941
Originally Posted by Jungle Man View Post
I wonder how long the engine would last without oil pressure? To the point where if it hasn't been working for a while that checking it at the next oil change makes a difference in a possible save?
The schematic shown states about a minute.
"A man turns his back on the comforts of home, and when the dust all settles and the story is told, history is made by the side of the road..." - DBT
MeefZah is offline   Reply With Quote
Old 07-10-2012, 01:03 PM   #29569
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
+1
I use WCS http://www.wheelingcyclesupply.com/index.shtml magnetic replacement plug. Pre-drilled.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 07-10-2012, 01:23 PM   #29570
skierd
Wannabe Far-Rider
Oddometer: 2,951
Originally Posted by ADVCoop View Post
I have to ask, how did you realize the bolt fell out? Did a warning light come on when the oil pressure dropped? I am partially deaf and worry if this happened to me I would never know until it was too late unless a low oil light comes or something. I just changed the oil this weekend now I am nervous haha.
I noticed that i didn't have any rear brake as i slowed down to turn left on to the trail system i hoped to ride that afternoon. The whole wheel was covered in oil and hence the rotor too. If i hadn't slowed for the turn, i probably wouldn't have noticed and wouldnt have stopped... just don't reuse the crush washer 5-10x like i had done and you should be fine... or do the safety wire thing.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time.
2008 Yamaha WR250X
Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012
skierd screwed with this post 07-10-2012 at 05:22 PM
skierd is online now   Reply With Quote
Old 07-10-2012, 01:26 PM   #29571
DougZ73
Fading off.........
DougZ73's Avatar
Oddometer: 7,105
damn.....5-10 times. Damn things are really meant for one use...as they crush. I though I was pushing it changing it every two.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011
DougZ's MTB thread , DZ Moto Photo Bloggin' , (my) Learning photography thread, DougZ vids
- Ryder Joseph Z. , Born 11/26/12-- the next Adventure: Grayson Hunter Z., born 5/3/14
DougZ73 is offline   Reply With Quote
Old 07-10-2012, 01:56 PM   #29572
MeefZah
Curmudgeonly
MeefZah's Avatar
Oddometer: 10,941
I've never changed it.
Old 07-10-2012, 02:45 PM   #29573
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
+1. They take a long time to crush unless your over tightening.
One on the DRZ has at least 10 changes on it.
I inspect it and clean it every time but if it's not crushing in close to the threads it goes back on.
oPAULo is offline   Reply With Quote
Old 07-10-2012, 03:18 PM   #29574
jon_l
jon_l's Avatar
Oddometer: 3,268
Originally Posted by pfy50 View Post
+1
Cool! Thanks!
Here is the link to the parts in the photo http://www.wheelingcyclesupply.com/shop/1/1/index.shtml
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Old 07-10-2012, 03:23 PM   #29575
jon_l
jon_l's Avatar
Oddometer: 3,268
Even the Yamaha manual indicates re-use is OK, just says to inspect it.
I always put newspaper under the bikes after each oil change, look for spotting.
CBF1000 & PCX150
Old 07-10-2012, 03:25 PM   #29576
jon_l
jon_l's Avatar
Oddometer: 3,268
Good idea, and I like the Wheeling bolts with magnets already drilled.
Do you (or anybody) have a photo of a safety-wired drain plug?
CBF1000 & PCX150
Old 07-10-2012, 03:32 PM   #29577
jon_l
jon_l's Avatar
Oddometer: 3,268
Originally Posted by Sewerat View Post
I always put a little bit of loctite thread sealant on every time I take any drain plugs out. Basically just a paste form of Teflon tape and I have never had a problem with leaks or fallouts.
Originally Posted by MiamiMotorcyclist View Post
I use yamabond. Though I think I have the honda equivalent right now.
http://www.amazon.com/Yamalube-Yamab...words=yamabond
I'm surprised to hear of you guys using Locktite on a drain plug. We don't know how these drain plugs came to fall out, but I assume they were never tightened in the first place, since this is (AFAIK) a really rare occurrence.
The plugs are hard steel in a alum casting, and require very little tightening. I worry more about too tight than too loose. I use a 1/4" drive ratchet with a 6" extension just because it is so wimpy it resists over-tightening.
Wifey is getting an inch-pounds torque wrench for her birthday in 3 weeks. Lucky lady, eh?
CBF1000 & PCX150
Old 07-10-2012, 03:48 PM   #29578
ADVCoop
ADVCoop's Avatar
Oddometer: 791
Not my picture nor is it a pic of a WR250R but you can get the idea. I have safety wired drain plugs before and plan to order one of the Wheeling bolts this Friday. Thanks for that link!
2006 Husqvarna TE610 - 1982 Suzuki PE175 - 2009 Yamaha XT250 (wife's)
ADVCoop is online now   Reply With Quote
Old 07-10-2012, 03:57 PM   #29579
Mikef5000
Oddometer: 2,030
They're not using locktite locktite... It's thread sealant, but locktite brand. Doesn't 'lock' the threads, it's a sealant like liquid teflon tape, to keep oil from seeping.
Oh, and I've never replaced a drain plug washer in my life.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 07-10-2012, 04:11 PM   #29580
jon_l
jon_l's Avatar
Oddometer: 3,268
Thanks for the photo.
With a skid-plate, the safety wire would be different, I assume? I was thinking I'd need drill the bolt (or order from WCS) & skid-plate in a North-South orientation so it doesn't catch weeds and sticks.
CBF1000 & PCX150
Times are GMT -7.   It's 07:00 AM.
