Old 07-10-2012, 04:11 PM   #29581
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 2,001
Originally Posted by ADVCoop View Post
Not my picture nor is it a pic of a WR250R but you can get the idea. I have safety wired drain plugs before and plan to order one of the Wheeling bolts this Friday. Thanks for that link!
Thanks for the photo.
With a skid-plate, the safety wire would be different, I assume? I was thinking I'd need drill the bolt (or order from WCS) & skid-plate in a North-South orientation so it doesn't catch weeds and sticks.
'09 Honda CBF1000; '09 Yamaha WR250R
jon_l is offline   Reply With Quote
Old 07-10-2012, 04:47 PM   #29582
DougZ73
Lacks Freetime
DougZ73's Avatar
Oddometer: 4,924
I have seen enough pictures of cracked cases from my DRZ owning days, for the fifty cents, I am happy to use a new one every other change.
DougZ73 is offline   Reply With Quote
Old 07-10-2012, 04:57 PM   #29583
scottmac
scottmac's Avatar
Oddometer: 1,284
My problem is usually rounding out the drain plug just trying to break it loose. Good to run the engine for
10 minutes or so beforehand to get everything nice and heated up and then put a wrench on it.
scottmac is offline   Reply With Quote
Old 07-10-2012, 04:59 PM   #29584
HighFive
Bike-aholic
HighFive's Avatar
Oddometer: 2,067
Oil Drain Plug Crush Washers
Suit yourself, use it as many times as you please.
Me......I change it every time. Most crush washers are made (intended) for single use.
SkierD's advice is quite accurate. You would be wise to follow it. Last time I bought a bag-full, they cost me all of 50 cents a piece.
Yamabond #4 is a thread sealant made to perform in contact with oil. Perfectly designed for an oil drain plug. It is neither Loctite (thread locking), nor Permatex (gasket making) type of material. It is good.....(correction).....incredibly good stuff for this specific application. It has no equal, that I'm aware. I use it on any bolt that needs securing that could contact a hydrocarbon liquid. Buy it at the Yamaha shop. One tube lasts half a lifetime, if you secure the cap and don't poke a hole in the tube.
HF
p.s. I replace my drain plug with a fresh one ever so often.......whenever the head starts getting rounded in the least. Those things tend to be soft. And a sharp head is important to proper torque. Yes.....I torque the drain bolt to exact spec. It always seems too low of a torque setting to me....but I've never lost one or had a leak (using a fresh crush washer).
HighFive screwed with this post 07-10-2012 at 05:05 PM
HighFive is offline   Reply With Quote
Old 07-10-2012, 05:27 PM   #29585
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,005
You are correct but these aren't really actual "crush" washers like you would find on a spark plug. They're just aluminum or copper or brass flat washers. They're soft so they will conform to any machining anomalies in the case or the bolt head and prevent leaks. If the washer deforms so much it gets into the threads of the bolt it can cause problems. It takes a long time to deform one that much using the proper torque.
How are you guys cleaning sealant out of the threads in the case every time? Or do you just pack more in on top of the old?
oPAULo is online now   Reply With Quote
Old 07-10-2012, 05:39 PM   #29586
TwilightZone
Oddometer: 1,951
Re-anneal the 'crush' washer... to red hot and let it cool.
Restores softness in the copper... lets it reseal.
Whales were everywhere. On the beach, on the hillsides. One crossed the road in front of us… it was a big beluga!
TwilightZone is online now   Reply With Quote
Old 07-10-2012, 05:43 PM   #29587
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 3,005
Isn't anneal low heat and harden is high heat?
Old 07-10-2012, 06:10 PM   #29588
Longboardr
Longboardr's Avatar
Oddometer: 113
Here's a link to safety wiring a street bike for (presumably) a track day
http://www.rc51.org/wire1.htm
Here's the safety wire pliers I own a set of, you can use regualr pliers if you wish. I bought them because I'm a tool junkie and they came with good stainless steel safety wire
http://www.rockymountainatvmc.com/p/...TY+WIRE+PLIERS
Longboardr is offline   Reply With Quote
Old 07-10-2012, 06:25 PM   #29589
Attico
Wrong way 'round
Attico's Avatar
Oddometer: 1,462
Send a message via MSN to Attico
Hi all
Powerbomb or megabomb... It is going in front of a powercore...
"Build a man a fire and he will be warm for the night, set a man on fire and he will be warm for the rest of his life."
Attico is online now   Reply With Quote
Old 07-10-2012, 06:47 PM   #29590
Ryel
Ryel's Avatar
Oddometer: 214
Originally Posted by Mr. Fisherman View Post
311 miles yesterday, all but 96 on dirt.
DUDE! where are you riding so much dirt?
keep on truckin Fish
"Good judgment comes from experience and experience comes from bad judgment."
Ryel is online now   Reply With Quote
Old 07-11-2012, 03:25 AM   #29591
jon_l
Southern Ontario
jon_l's Avatar
Oddometer: 2,001
Thanks for clearing up my misconception. I saw "Locktite" and "Yamabond" and made a wrong assumption.
Drain plug, Yamabond #4, and drain plug washers are on the shopping list.
Old 07-12-2012, 12:22 AM   #29592
etingelefunts
etingelefunts's Avatar
Oddometer: 291
Temper (draw) is low heat.
Brass (and similarly copper) soften (anneal) if rapidly quenched (cooled) after heating.
Slowww cooling or forming/compression of brass and copper washers usually makes them brittle.
Steels react opposite; rapidly quenching steels makes them harder, brittle, and often cracking.
Annealing varies widely by type of steel, but usually involves heating to temperatures up close to those used for hardening, and verry slowwwww controlled cool down. Tempering a hardened part involves moderate to low heat after heat treating/quench, to reduce brittleness.
Reasons for each (typical);
Harden= resists deforming
Temper =Toughness and less likely to chip
Anneal = Makes soft and machinable and less likely to fracture or crack
Piloting a bike with its disperate focus awakens clarity, perhaps the wind shews the clutter.
Drawn to this place, I am inspired to share my ride, especially watching others' journeys.
In a little way gregarious again, marveling at the profound experiences of nearly everyone whom I meet. Its like a whole new clan.
Teach me more.
etingelefunts is offline   Reply With Quote
Old 07-12-2012, 09:13 AM   #29593
dadthemechanic
dadthemechanic's Avatar
Oddometer: 28
Somebody paid attention in school.
Baker
Before you insult a man, walk a mile in his shoes. That way, when you insult him, you'll be a mile away, and have his shoes.
dadthemechanic is offline   Reply With Quote
Old 07-12-2012, 09:33 AM   #29594
DougZ73
Lacks Freetime
DougZ73's Avatar
Oddometer: 4,924
Or did a quick google search.
Old 07-12-2012, 01:32 PM   #29595
IdahoRenegade
Oddometer: 1,113
Exhaust options w/o repacking?
Are there any exhaust options that don't require regular repacking (other than stock)? I know the DR650 guys swap in "takeoff" GXSR cans pretty often and wonder if there is something similar for our bikes. Part of the beauty of the WR is the low maintenance; I don't want a can I have to repack several times a season.
IdahoRenegade is offline   Reply With Quote
Times are GMT -7.   It's 07:38 AM.
