08-08-2012, 02:33 PM
#30001 | |
Wannabe Far-Rider
I think its even lighter now that he's running mousse instead of tubes but im not sure.
"We wish your trail a long one" - Darlene "Sid" Dowd ~ Never run out of traction, ideas, and real estate at the same time. 2008 Yamaha WR250X - 1998 Honda Nighthawk CB750 Eastern TAT 8/2009 ~MD-Key West-Oklahoma 4/2011~Maryland to Alaska 3/2012 |
08-08-2012, 02:34 PM
#30002 | |
Oddometer: 2,282
08-08-2012, 02:56 PM
#30003 |
My mate with his WRR did Rox Risers and high bars, he had to get all new cables and extend all his wiring.
08-08-2012, 03:06 PM
#30004 | |
Oddometer: 1,389
Ok I've rode and raced forever and know lighter is better. But the little weight (IMHO) saved by spokes and rims, is that really noticeable? I mean I don’t think I’m good enough to see a significant difference. I’ve stripped all the usual stuff off my 250R but hey it was a free mod. What I see all the time is guys showing up to trail ride and tell me that my stock 250F just didn’t have enough power for them. So they YZ cammed theirs and piped it and…threw piles of money at it, but I wait for them in the trails cause they can’t keep up, and I’m fatter and older than them. So is the cost worth it? Does it make the ride that much better?
I'm not saying there should be capital punishment for stupidity, but let's take the safety labels off of everything and let the problem solve itself. Current bikes: '12 WR250R, '10 F800GS, '08 Versys, '07 WR250F, '85 RZ350, Wife's bikes: '10 F650GS, '09 XT250,'03 WR250F |
08-08-2012, 03:19 PM
#30005 | |
Oddometer: 2,364
08-08-2012, 04:42 PM
#30006 |
Oddometer: 710
All stock length cables and wires, I didn't do anything special with the routing. It could be because I have my forks slid in the clamps about 19mm (3/4"), or maybe the ROX risers are taller? I am at about the limit any higher and I would have binding issues.
2010 Gas Gas EC250 - 1997 Honda XR650L - 1992 Gas Gas GT25 "Twenty years from now, you will be more disappointed by the things that you didn't do than by the ones you did do" - Mark Twain |
08-08-2012, 06:03 PM
#30007 |
Oddometer: 1,155
aftermarket headlight opinions
Alright, riding my wr again while I wait on clutch cable for the versys. At night my hid in stock headlight lense is not cutting it any more, as it eroded the silver lining. Looking for opinion on 3 options I am thinking about.
1. Baja designs replacement lense with a new hid kit 2. baja designs or trailtech 8 inch racing hid light 3. baja designs squadron. I don't care about the legality issue, just want light on the road properly aimed. Cutoff will be good enough. What do you guys think is the best aftermarket option of those, or suggest another option. Love the single round headlight look, but the work involved in the install looks daunting. Squadron would be plug and play for most part, but needs dimmer for true high low operation.
2008 WR250R(Anywhere) 2009 Versys |
08-09-2012, 02:47 AM
#30008 |
Southern Ontario
Oddometer: 1,986
I know it is here somewhere, but...
I have searched hard, and not found it. The wiring diagram Google Doc link in the WR250R bike specific index thread is broken.
I want to put a switched 12v accessory outlet up front, for GPS and air compressor. The DR650 had a handy spare lurking behind the front headlight cowl. I am an electric-idiot, so need clear direction on locating the source (preferably photos). I will fuse and solder and heat-shrink tube the connection, once I figure out where to tap in without causing any harm. Thank you in advance for a firm shove in the right direction. Jon |
08-09-2012, 06:03 AM
#30009 |
Oddometer: 710
I always use a relay and distribution block so I have switched power for whatever I want to add like heated grips, power outlet, etc. But if you don't enjoy wiring you might not like this option. It's easy but looks intimidating the first time.
You are correct, in the harness by the headlight there is often an empty connection that is switched. I can't remember if there is one on the WRR, but will look later because now I am curious. I do know under the seat is a yellow plug. It has two wires, this is for the plate light. But it is switched 12V and you can tie into the blue wire. Looks back at post #29986 (about two pages) and easy_dualsport posted a picture of mine pointing this connector out.
08-09-2012, 08:24 AM
#30010 | |
Oddometer: 1,072
Here's an install I found: http://www.basherdesigns.com/2010/01/29/3cs-part-1/
2011 WR250R 2009 KLR650 2004 KTM 450 EXC 2000 R1150GS "The older I get, the faster I was" |
08-09-2012, 08:34 AM
#30011 | |
The Spoad Warrior
Oddometer: 2,173
none of us are as dumb as all of us |
08-09-2012, 10:22 AM
#30012 | |
Southern Ontario
Oddometer: 1,986
Post 29986 looks great. Wish you were my neighbor, I'd offer you a case of beer to help me. I am hoping for something as simple (and free) as the DR650: ![]() unused connection under headlight cowl |
08-09-2012, 10:34 AM
#30013 | |
Curmudgeonly
Oddometer: 8,802
The WR does not have the empty connection.
Go forth, wander aimlessly, explore, have adventures and shit... |
08-09-2012, 11:13 AM
#30014 |
Oddometer: 710
Bummer. I didn't get a chance to look so thanks for clarifying. My wife's DR200 has an empty connection and a few other bikes I've owned. Like I said I use a relay and distribution block wired in so I have a switched power circuit for adding accessories so I never looked for an empty connection on the WRR.
jon if I was close I would have gladly helped you.
08-09-2012, 12:57 PM
#30015 |
Oddometer: 194
