08-19-2012, 07:29 AM
#30166 |
Lame Duck Adventurer
Oddometer: 796
the horn is pictured here
Another inmate stole my Avatar... WR250R... 15 cubic inches of raw power. xr50r.... More than I can Handle Oil changed @ 11900 miles + filter (so I don't forget) |
08-19-2012, 08:29 AM
#30167 |
Oddometer: 97
So you just swapped out the horn then? No additional work required to make this mod happen?
08-19-2012, 09:39 AM
#30168 |
Oddometer: 1,281
FYI: you can easily rotate the mount of your horn around so that it sits up out of sight behind
the plastic cover on the left side of your bike.
08-19-2012, 09:49 AM
#30169 |
Ducati Monster. EVO.
Oddometer: 882
Dunno, but the Walmart ATV Seat Cover gets pretty high marks and at $20 is a darn sight cheaper.
2011 Yamaha WR250R 2012 Ducati Monster 2007 R1200GS (Sold) IBA # 20880. STFU and Ride. |
08-19-2012, 11:18 AM
#30170 | |
Oddometer: 112
![]() http://www.amazon.com/gp/product/B00...ls_o00_s00_i01 |
08-19-2012, 06:01 PM
#30171 |
Oddometer: 648
tat
Just shredded black dragon wash in 45 min. Today
My favorite philosopher is Cha Ching ! |
08-19-2012, 07:13 PM
#30172 |
Oddometer: 796
Horn and added wiring
A few post backs I pictured my new horn, and I did not add a relay or any additional wiring and it works. That being said, this winter I will be adding a gps plug and probably try a relay setup for the horn to see if it gets louder still with more available amps from the battery
08-19-2012, 09:14 PM
#30173 | |
oneandahalfassed
Oddometer: 9,797
Did you verify the fan is working? Did you check to make sure it is spinning freely? Have you cleaned the air filter lately? Did you check coolant level (when it is cool.) Did the intake temp make sense compared to water temp when you did the diagnostics? When is the last time you changed the coolant and what did you use?
Round Way Round, 2 months and several thousand miles on a WR250X |
08-20-2012, 01:57 AM
#30174 | |
MacGyver
Oddometer: 1,972
Coincidentally, I did Cinnamon Pass, California Pass, Engineers Pass, Mosquito Pass and a few others over a 6-day ride which ended last week. We did a few miles of pavement between some of the trails and I was experiencing the exact same symptoms as you describe. The problem got worse by the 3rd or 4th day. Turned out to be my air filter, even though I began the trip with a clean, fresh oiled filter. Because I started the week with a clean filter, I was really reluctant to believe it. But riding near the back of the pack (6 bikes) my poor little WR inhaled a serious amount of dust, and the filter was totally clogged in just 3 days. Cleaned and re-oiled, symptoms disappeared for day-4.
Sent from my Galaxy Tab 10.1 with TapaTalk
_______________ "You can't put the shit back in the donkey." - Tony Soprano FYYFF
08-20-2012, 05:03 AM
#30175 |
I just had my steering head off. There was pretty minimal grease in there. I had no movement though. I tightened just a tad tighter than factory specs and it is great, no movement at all.
08-20-2012, 05:25 AM
#30176 |
Lacks Freetime
Oddometer: 4,913
OK, thanks for the reply Joe. Much appreciated.
Skyline Drive 11/2010 , Catskills 2010 trip, Catskills 2011 , Southern TNJT, 2011 WRR/X rear shock adjustment , DZ Moto Photo Bloggin' , Learning photography thread - Ryder Joseph Z. , Born 11/26/12-- the next Adventure begins. |
08-20-2012, 06:37 AM
#30177 | |
Curmudgeonly
Oddometer: 8,794
Oil em up in advance and toss them in a ziploc bag. Put one on the air filter before the ride and pull it off after each day and replace it with a new one. Takes however long it takes to open up the airbox - a few minutes, max.
Go forth, wander aimlessly, explore, have adventures and shit... |
08-20-2012, 07:27 AM
#30178 |
Oddometer: 97
Great tips regarding horn, filter, and filter skins! You fellas really know how to help a noob out :)
08-20-2012, 01:03 PM
#30179 | |
MacGyver
Oddometer: 1,972
That's definitely the plan for next time.
Sent from my GT-I9300 using Tapatalk 2
08-20-2012, 04:19 PM
#30180 |
Oddometer: 4
For me in Colorado, I use a 12/50 with excellent results. For 8000 ft and up to 13000 ft riding it is perfect for the steeps and especially rocky sections.
2012 WR250R 12 X 50 GEARS AIS removal Flapper box Modification Many Add-ons from Dirt Freak DRC hardware. |
