Old 08-26-2012, 09:48 AM   #30301
HardWorkingDog
Harvey Mushman
HardWorkingDog's Avatar
Oddometer: 1,743
Originally Posted by Nice_Rumble View Post
Got a weepy left fork seal. I believe there is a bit of dirt lodged in the seal and will do the "credit card" trick. Now that some fluid has leaked out what's the best way to get it back to specs? Measure fluid height from the top of the fork leg? Anyone know what OEM specs and weight should be?
Good luck. In my experience you're going to need something thinner and more flexible than a credit card. I've used a paper index card successfully, and some 35mm film (what's that???) but I also had the film break off inside the fork...
Motion Pro makes a handy little tool that works pretty well.
The problem is that if you're going to all the trouble to pull the forks out, remove the cap, remove the spring and pushrod just to add a few cc's of oil you may as well replace the seals and put all new fork oil in and be done with it.
Do you have any idea how much oil seeped out? If you can clean the seal and stop the leak, and you know the oil is fresh (say, less than a year old) then I'd be tempted to just pop the bleeder screw on the cap and drizzle in a few cc's of oil and not worry about it. If not, I'd go ahead and do the seals and bushings and new oil all around.
"Coffee first..."
Next Trip: Divide & Conquer...
"it's a dog's life.............and I love it"
HardWorkingDog is offline   Reply With Quote
Old 08-26-2012, 09:58 AM   #30302
Bob in Indy
Bob-O
Bob in Indy's Avatar
Oddometer: 24
Does the setting only take after turning the ign. off?
Originally Posted by GSBS View Post
...or one click here
So...after changing the setting and starting the bike, can you take it for a ride still in diag mode and make adjustments on the fly while seeing how they affect it? Or... do the settings only take effect after turning the ignition off? I wasn't 100% clear on this from the write up.
My stock setting was at 0... I took it out for a ride still in diag mode and tried a few other settings to see how each affected the bike. I went from -4 to +4... I "think" I could tell a little difference, but honestly I'm not sure if I really could or if it was my imagination.
Thanks for any insight...
Bob
Bob Smith
2011 Yamaha WR250R
Bob in Indy is offline   Reply With Quote
Old 08-26-2012, 10:19 AM   #30303
ramz
Professional Trail Rider
Oddometer: 2,006
From the referenced post:
The nice thing is that you can adjust it on the fly to as many different settings as you want and it saves the last number used when the key is turned off.
ramz is offline   Reply With Quote
Old 08-26-2012, 10:29 AM   #30304
what broke now
Petroleum Brother
Oddometer: 1,410
Fuel Pump
I am in the mood for a fuel pump spare, anyone on here have an old take-out they would part with?
what broke now is offline   Reply With Quote
Old 08-26-2012, 10:52 AM   #30305
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,249
It's the original fluid from '08 so you're right, best to just go ahead and flush the tubes and refill with fresh fluid and new seals. I'll take them to factory Connection.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is online now   Reply With Quote
Old 08-26-2012, 10:59 AM   #30306
indypup
indypup's Avatar
Oddometer: 3,764
The WRR was struggling to get up this with my fat ass on it. :( I think I was in first gear pretty much the whole time.
Going UP the Poughkeepsie Gulch Trail in Colorado.
This trail is very steep. It goes from 10,143 to 12,546 feet in about 4 miles.
This trail is probably the most technically challenging trail in the Ouray area. It connects Mineral Creek on one end to California Gulch and Hurricane Pass on the other end.
It also has a huge Rock Obstacle in the middle called the wall. Unfortunately my batteries died before getting to that part. :(
Enjoy!
don't do that...but if you do FILM IT!
2014 KTM 350 XCF-W ISDE
2007 ST1300, 2008 KLR650, 2008 WR290R Supermoto, 1995 Ninja 250R
My goal in life is to be as good as a person as my dog already thinks I am.
indypup is offline   Reply With Quote
Old 08-26-2012, 12:20 PM   #30307
Bob in Indy
Bob-O
Oddometer: 24
Thanks. Yeah, I know that's what it said, but I guess I was just looking for confirmation from someone who's modified the setting (on the fly) and saw a measurable difference. I just didn't notice a tremendous change when playing around with various settings myself. I see no reason why it wouldn't work that way, was just skeptical based on my experience is all.
Bob Smith
2011 Yamaha WR250R
Old 08-26-2012, 01:50 PM   #30308
jon_l
jon_l's Avatar
Oddometer: 3,272
Originally Posted by duanew1 View Post
My 2003 Z1000 with about 4 times the power and fuel injection does not have any snatchiness. I knew the WR could be better.
Yeah, same with my Honda CBF1000
CBF1000 & PCX150
jon_l is online now   Reply With Quote
Old 08-26-2012, 05:49 PM   #30309
pfy50
Professional nOOb
pfy50's Avatar
Oddometer: 586
Originally Posted by jon_l View Post
So which G2 throttle tamer are you guys buying? Nothing but sport bikes listed.
Get the Dirt Tamer $49.00 http://www.g2ergo.com/g2-tamer-throttle-tube-40.html it's cheaper and just as good for WRR. It has a fixed cam choice, 15% slower A400 cam than the stock rapid cam #100. For extra $20.00 I got the pro model with the delrin bearing to smooth it out a little more. IT does alleviate the snatch throttle some.
My Odyssey: http://www.advrider.com/forums/showthread.php?t=566875
2013 TEX XC,2011 WR250R,2004 KAWA Concours,1994 BMW K1100RS
May the Lord bless you and keep you in all the Dark places you must travel
pfy50 is offline   Reply With Quote
Old 08-26-2012, 07:29 PM   #30310
bradrh
Oddometer: 424
wolfman e-12
Does anyone else have E-12s and a tailrack mounted? I'd love to see photos of how you solved the puzzle.
I loosened up the rack and used all the straps they provided. The rear cinch strap didn't cinch down as easily as it did on my DR due to the shape of the fender, but once I worked it a little it seems to be holding well. The rear wide strap is tucked under the front of the cargo rack.
The 3rd pic down shows the bike with the saddle bags and the renegade duffle
http://www.advrider.com/forums/showthread.php?t=816651
- DR650
- WR250R times 2
bradrh is offline   Reply With Quote
Old 08-27-2012, 03:36 AM   #30311
jon_l
jon_l's Avatar
Oddometer: 3,272
Thanks Brad. I couldn't seem to get the hooks to pull evenly on the WRR tail, so I swapped in an old strap to the rack, and am pleased.
I like the look (and price) of the Renegade Duffel. I have been looking at the small Expedition Dry Duffel too. I have several Seal-Line (canoe) drybags which I could use with Rok-Straps, but I really like the extra tie-down points Wollfman provides.
CBF1000 & PCX150
Old 08-27-2012, 04:38 PM   #30312
jon_l
jon_l's Avatar
Oddometer: 3,272
Kenda Trackmaster K760 questions
Our bike is spec'd for 120/80-18 rear tire.
Rear Trackmasters are all ___/100-18.
Do you guys run the 100/100-18, or the 110/100-18?
Are these tire "true to size" like T-63s, or large diameter like MT-43s?
CBF1000 & PCX150
Old 08-27-2012, 08:30 PM   #30313
Dirtnadvil
Dirtnadvil's Avatar
Oddometer: 830
If you were going to trade your WR away, what would you replace it with?
I have been toying with the thought of getting a different bike for a couple of years but I have sofar been unable to find another bike to replace the WR. I want a carburated bike due to the places we ride.
My needs are basic;
300 lbs or less
50mpg or greater
ability to carry gear
good suspension
reliability
easy to work on* (carby)
6 speed
smooth motor
starter , optional kick start would be nice
30+ hp
decent aftermarket parts
there are other needs but they are not deal breakers. I was wondering what other bikes you have owned that were close to the WR?
Dirtnadvil is offline   Reply With Quote
Old 08-27-2012, 11:03 PM   #30314
andy mac
Oddometer: 56
I 've used both, the 100/100 was too skinny for optimum traction in mud but I was happy with the 110/100. Guessing they are between a T63 and MT43 in height.
Originally Posted by indypup View Post
Nice trail, amazing how video flattens out the hills - it didn't look too steep until you tipped off and rolled so far downhill from your bike
andy mac is offline   Reply With Quote
Old 08-28-2012, 05:24 AM   #30315
zeroselect
Oddometer: 36
Hey Guys and Gals I may have a timing chain or a crank bearing problem.
I have been starting to hear and knocking noise coming from my crank case.
I have installed a Athena BB kit about 2000 miles ago and recently started to hear the noise.
The bike still runs great but the noise is not normal at all.
When idling the noise is the loudest and when I get on the throtttle the noise gets quieter.
The timing chain tensioner has been ordered and when it comes in i'll be opening up the valve cover and check the timing.
From looking at the parts # seem to be that the tensioner has been updated by Yamaha.
Also on the 2 oil changes after the BB kit install I had very fine particles of metal in the oil. I have read here that people who had crank bearing problem had small slivers of metal which it wasn't and I do have a magnetic drain bolt and it seem that none of the fine shiny metal particles attach to the magnet. This seem like its possibly just aluminum particles for the Athena Kit.
zeroselect is offline   Reply With Quote
Times are GMT -7.   It's 06:08 AM.
